Hello, I am developing an application using https://github.com/balena-io-modules/etcher-sdk
when I run
MOUNTUTILS_DEBUG=1 npm start
and my code runs
etcherSDK.multiWrite.decompressThenFlash({...})
then I see in the log
[mountutils] Reading /proc/mounts
[mountutils] Mount point /dev/sdc2 belongs to drive /dev/sdc
[mountutils] Mount point /dev/sdc1 belongs to drive /dev/sdc
[mountutils] Closing /proc/mounts
[mountutils] Unmounting /media/forest/rootfs...
[mountutils] Unmount MNT_EXPIRE /media/forest/rootfs: EAGAIN
[mountutils] Unmount MNT_EXPIRE /media/forest/rootfs failed: Operation not permitted
[mountutils] Unmount MNT_DETACH /media/forest/rootfs failed: Operation not permitted
[mountutils] Unmount MNT_FORCE /media/forest/rootfs failed: Operation not permitted
[mountutils] Unmounting /media/forest/boot...
[mountutils] Unmount MNT_EXPIRE /media/forest/boot: EAGAIN
[mountutils] Unmount MNT_EXPIRE /media/forest/boot failed: Operation not permitted
[mountutils] Unmount MNT_DETACH /media/forest/boot failed: Operation not permitted
[mountutils] Unmount MNT_FORCE /media/forest/boot failed: Operation not permitted
[mountutils] Unmount complete
and onFail() gets called with “Unmount failed”. This seems weird to me because according to the C code it should return “Unmount failed, access denied” when its a permissions issue: https://github.com/balena-io-modules/mountutils/blob/master/src/worker-unmount.cpp#L28
I am curious how does this work in production for balena etcher? currently I am just debugging on linux but of course I want this to work cross platform later on… this should be documented on https://github.com/balena-io-modules/etcher-sdk!
I will do the work to document it, but help me help you: fill me in on how this works!
