Flash Failed: Unmount failed
I could never get balena etcher to work im not quite sure why. Anyways here is what i’ve gathered from the results in the dev console.
cancelled: false
results:
averageFlashingSpeed: 4259847.338273424
bytesWritten: 855977984
devices: {failed: 1, successful: 0}
errors: Array(1)
0: Error: Unmount failed
description: "CARDER READER USB Device"
device: "\\\\.\\PhysicalDrive2"
message: "Unmount failed"
stack: "Error: Unmount failed"
__proto__: Object
length: 1
__proto__: Array(0)
sourceMetadata: {size: 855977984, name: "archlinux-2023.01.01-x86_64.iso", blocks: Array(1), blockmappedSize: 855977984}
__proto__: Object
skip: false
__proto__: Object
If anymore info is needed please ask.
In order to narrow down the issue, I think first we should gather as much info as possible!
  • what operating system are you using
  • what version or versions of etcher have you tried
  • have you confirmed that you get the same issue with multiple SD cards/SD card readers/USB sticks
  • does this happen if you try to flash different images
