Hello!
First of all, I love your guys’ products, and have been having lots of fun messing around with all of your offerings!
That being said, I’m unable to get any sound coming through my hifiberry DAC Plus -Light, which is connected to my Raspberry Pi 4. I’m able to successfully my phone via bluetooth to the Pi, and when I plug an aux cord directly into the Pi (without the HifiBerry), the sounds works as expected. So, I was curious to see if the dtoverlay value of “hifiberry-dacplus” included the “Light” version of the product (https://www.amazon.com/HiFiBerry-DAC-Light/dp/B016YY693C/ref=sr_1_7?dchild=1&keywords=hifiberry+dac&qid=1585597530&sr=8-7)
Or if there needs to be another dtoverlay value added to the list of config values in order to use the Light version.
Below is my current setup and logs, please let me know if you need any additional info or have any questions.
Board: Raspberry Pi 4
balenaOS version: 2.47.1+rev1 (I realize this is a slightly older version, but I was having bluetooth connectivity issues when using the current OS version, so I downgraded. It seems to have fixed my bluetooth issue)
balenaSound version: latest (v2.0.4)
DAC: HifiBerry DAC+ Light
Multi-room is disabled.
Logs and boot config below:
30.03.20 13:14:56 (-0600) Applying boot config: {“arm_64bit”:“1”,“disable_splash”:“1”,“dtoverlay”:[“vc4-fkms-v3d”,“hifiberry-dacplus”],“dtparam”:[“i2c_arm=on”,“spi=on”,“audio=off”],“enable_uart”:“1”,“gpu_mem”:“16”}
30.03.20 13:14:56 (-0600) Applied boot config: {“arm_64bit”:“1”,“disable_splash”:“1”,“dtoverlay”:[“vc4-fkms-v3d”,“hifiberry-dacplus”],“dtparam”:[“i2c_arm=on”,“spi=on”,“audio=off”],“enable_uart”:“1”,“gpu_mem”:“16”}
30.03.20 13:14:57 (-0600) Killing service ‘fleet-supervisor sha256:9ccc9d86670900c397b6d5ec4cb0b91888e98e560045dc977416fafab86b1049’
30.03.20 13:14:57 (-0600) Service is already stopped, removing container ‘fleet-supervisor sha256:9ccc9d86670900c397b6d5ec4cb0b91888e98e560045dc977416fafab86b1049’
30.03.20 13:14:57 (-0600) Killed service ‘fleet-supervisor sha256:9ccc9d86670900c397b6d5ec4cb0b91888e98e560045dc977416fafab86b1049’
30.03.20 13:14:57 (-0600) Killing service ‘airplay sha256:63807713cb4bfc94ef53660d001ce6250df14b425b9eaca61565edc0d92c88a8’
30.03.20 13:15:08 (-0600) Service exited ‘airplay sha256:63807713cb4bfc94ef53660d001ce6250df14b425b9eaca61565edc0d92c88a8’
30.03.20 13:15:08 (-0600) Killed service ‘airplay sha256:63807713cb4bfc94ef53660d001ce6250df14b425b9eaca61565edc0d92c88a8’
30.03.20 13:15:08 (-0600) Killing service ‘spotify sha256:895556865a10587cc790872dd47d695e27d251a6d46846537834df0bab1c72b8’
30.03.20 13:24:24 (-0600) Supervisor starting
30.03.20 13:24:09 (-0600) amixer: Mixer attach default error: No such file or directory
30.03.20 13:24:09 (-0600) Restarting bluetooth service
30.03.20 13:24:12 (-0600) rm: cannot remove ‘/root/.asoundrc’: No such file or directory
30.03.20 13:24:13 (-0600) Bluetooth agent registered
30.03.20 13:24:14 (-0600) Starting bluetooth agent in Secure Simple Pairing Mode (SSPM) - No PIN code provided or invalid
30.03.20 13:24:16 (-0600) Attempting to reconnect to previous bluetooth device: 58:CB:52:5A:4F:AC
30.03.20 13:24:18 (-0600) Device is discoverable as “balenaSound bc3c”
30.03.20 13:24:25 (-0600) Starting service ‘fleet-supervisor sha256:9ccc9d86670900c397b6d5ec4cb0b91888e98e560045dc977416fafab86b1049’
30.03.20 13:24:25 (-0600) Starting service ‘snapcast-client sha256:aae8b03197d9ef9b73ba5de4990034da53da16983d96a547c4318da7503c6b6c’
30.03.20 13:24:25 (-0600) Starting service ‘snapcast-server sha256:0f952419c675f92fc0a85ca02c1b4cc15ae2bc21d329b7e31763013898938f34’
30.03.20 13:24:27 (-0600) Started service ‘fleet-supervisor sha256:9ccc9d86670900c397b6d5ec4cb0b91888e98e560045dc977416fafab86b1049’
30.03.20 13:24:16 (-0600) Multi-room audio is disabled, not starting fleet supervisor.
30.03.20 13:24:26 (-0600) Multi-room audio is disabled, not starting fleet supervisor.
30.03.20 13:24:27 (-0600) Started service ‘snapcast-client sha256:aae8b03197d9ef9b73ba5de4990034da53da16983d96a547c4318da7503c6b6c’
30.03.20 13:24:15 (-0600) Multi-room audio is disabled, not starting snapclient.
30.03.20 13:24:26 (-0600) Multi-room audio is disabled, not starting snapclient.
30.03.20 13:24:27 (-0600) Service exited ‘fleet-supervisor sha256:9ccc9d86670900c397b6d5ec4cb0b91888e98e560045dc977416fafab86b1049’
30.03.20 13:24:27 (-0600) Service exited ‘snapcast-client sha256:aae8b03197d9ef9b73ba5de4990034da53da16983d96a547c4318da7503c6b6c’
30.03.20 13:24:28 (-0600) Started service ‘snapcast-server sha256:0f952419c675f92fc0a85ca02c1b4cc15ae2bc21d329b7e31763013898938f34’
30.03.20 13:24:16 (-0600) Multi-room audio is disabled, not starting snapserver.
30.03.20 13:24:28 (-0600) Multi-room audio is disabled, not starting snapserver.
30.03.20 13:24:30 (-0600) Service exited ‘snapcast-server sha256:0f952419c675f92fc0a85ca02c1b4cc15ae2bc21d329b7e31763013898938f34’
30.03.20 13:27:37 (-0600) ALSA lib confmisc.c:767:(parse_card) cannot find card ‘0’
30.03.20 13:27:37 (-0600) ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
30.03.20 13:27:37 (-0600) ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
30.03.20 13:27:37 (-0600) ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
30.03.20 13:27:37 (-0600) ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
30.03.20 13:27:37 (-0600) ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
30.03.20 13:27:37 (-0600) ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
30.03.20 13:27:37 (-0600) ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM default
30.03.20 13:27:37 (-0600) /usr/bin/bluealsa-aplay: Couldn’t open PCM: No such file or directory
30.03.20 13:27:38 (-0600) ALSA lib confmisc.c:767:(parse_card) cannot find card ‘0’
30.03.20 13:27:38 (-0600) ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
30.03.20 13:27:38 (-0600) ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
30.03.20 13:27:38 (-0600) ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
30.03.20 13:27:38 (-0600) ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
30.03.20 13:27:38 (-0600) ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
30.03.20 13:27:38 (-0600) ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
30.03.20 13:27:38 (-0600) ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM default
30.03.20 13:27:38 (-0600) /usr/bin/bluealsa-aplay: Couldn’t open PCM: No such file or directory
30.03.20 13:27:39 (-0600) ALSA lib confmisc.c:767:(parse_card) cannot find card ‘0’
30.03.20 13:27:39 (-0600) ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
30.03.20 13:27:39 (-0600) ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
30.03.20 13:27:39 (-0600) ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
30.03.20 13:27:39 (-0600) ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
30.03.20 13:27:39 (-0600) ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
30.03.20 13:27:39 (-0600) ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
30.03.20 13:27:39 (-0600) ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM default
30.03.20 13:27:39 (-0600) /usr/bin/bluealsa-aplay: Couldn’t open PCM: No such file or directory
Thank you so much in advance!
