I recently purchased the Hifiberry Digi+ Pro and i plugged it in on the GPIO like it should
I added the configuration variable ‘BALENA_HOST_CONFIG_dtoverlay’ with value ‘hifiberry-digi’. I also added the environment variable ‘SOUND_OUTPUT’ with the value ‘DAC’.
However there is no sound output with the Airplay or the bluetooth input. the card is recognized with alsamixer (SSH on the audio block). i tried running ‘speaker-test -c1’ (SSH on the audio block) and no sound either.
It appears like the Hifiberry Digi+ Pro isn’t on our list of supported DACs:
But that doesn’t mean it won’t work - it just means we haven’t confirmed it works, and which dtoverlay one would need. I agree that from the hifiberry docs, the hifiberry-digi-pro should work:
Please let us know what you find, and if you have any more issues.
Hello, everything seems to be working perfectly with dtoverlay from Hifiberry. I added an issue on Github incase proper support need to be coded into the software.
