Hi everyone, I was wondering if it will be possible to use balena sound with the new hifiberry amp100 board.
Thank you in advance for your response.
Nathan
Nathan
Here is the list of supported DACs for BalenaSound https://sound.balenalabs.io/docs/audio-interfaces/#dac-boards, please give it a try and let us know if your board is not in the list. It’s simple to add support for a new DAC.
I checked this document before posting, i saw that you use the same project for a lot of different hifiberry cards : hifiberry-dac.
Is it safe to use this project with my new hifiberry-amp100 board?
Nathan,
Hey Nathan,
From Hifiberry’s website, it looks like the dtoverlay for that board is hifiberry-amp100 which we don’t currently support on balenaSound. I would try hifiberry-amp as your BALENA_HOST_CONFIG_dtoverlay setting. It won’t hurt the DAC if it’s wrong, it just won’t produce sound.
If that doesn’t work, and you need support for the correct overlay, let us know and we’ll raise an issue on the sound github repo.
Phil
After a glance over the Amp100 datasheet and product info, it looks to me like you need to use the hifiberry-dacplus DT overlay. The product page says it’s a combination of a DAC+ Pro and a 100W amp. Most of the DAC+ and DAC2 line use hifiberry-dacplus, including the Amp2. Another option to try is hifiberry-dacplushd, in case they used the higher-end DAC chip on that board.
Thank you really much for your answers
I will keep you informed of the results.
Hi everyone, so i tried all the different BALENA_HOST_CONFIG_dtoverlay variables :
What i did is that i took downloaded v2.58.3+rev 1 development version on you website, flashed it on a USB key.
1/Boot the rbpi
2/Changed the BALENA_HOST_CONFIG_dtoverlay variable
3/Shutdown the pi
4/Unplug power
5/Boot again and check results ( I basically send audio through spotify airply & bluetooth)
I tried to disabled Multiroom audio but i still did not get any sound, do you have any idea if i missed something ? The board seems to be detected which is a good sign though…
I checked the logs, the result is the same for all the different variables :
09.01.21 13:09:49 (+0100) audio>
09.01.21 13:09:49 (+0100) audio> — Audio —
09.01.21 13:09:49 (+0100) audio> Starting audio service with settings:
09.01.21 13:09:49 (+0100) audio> - Pulse log level: NOTICE
09.01.21 13:09:49 (+0100) audio> - Default output: AUTO
09.01.21 13:09:49 (+0100) audio> Detected audio cards:
09.01.21 13:09:49 (+0100) audio> 0 ALSA bcm2835_alsa-bcm2835ALSA
09.01.21 13:09:49 (+0100) audio> 1 sndrpihifiberry HifiberryDacp-snd_rpi_hifiberry_dacplus
09.01.21 13:10:05 (+0100) audio> Waiting for sound supervisor to start
09.01.21 13:10:05 (+0100) audio> Setting audio routing rules. Note that this can be changed after startup.
09.01.21 13:10:05 (+0100) audio> Routing ‘balena-sound.input’ to ‘snapcast’.
09.01.21 13:10:05 (+0100) audio> Routing ‘balena-sound.output’ to ‘alsa_output.dac.stereo-fallback’.
09.01.21 13:10:06 (+0100) audio> W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
09.01.21 13:10:08 (+0100) audio> W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
09.01.21 13:10:08 (+0100) audio> W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
Hi Nathan,
Can you tell us more about your setup? What device are you using (e.g. Raspberry Pi 3) and are you using a 32-bit or 64-bit OS on it?
Phil
@nathanh did you ever manage to get the Hifiberry Amp100 running with balenaSound?
Hi everyone, hifiberry seems to have introduced a new dtoverlay specific to this device, called hifiberry-amp100
Anyway i managed to realize what i wanted to do with their own os…
Thank you really much for your help!
hifiberry-amp100 is the correct setting. I’ve tested it. And you should also remove “vc4-kms-v3d” dt overlay setting.
Refer to this setting https://www.hifiberry.com/docs/data-sheets/datasheet-amp100/ and https://www.hifiberry.com/docs/software/configuring-linux-3-18-x/
