Hi, I don’t know if it is the updates, but he downloaded the HA image and I try to do the procedure with balenaetcher and I make an error telling me the file is corrupted, I have already downloaded 3 HA images and balena only tells me that enough or that the file is damaged!
Hi, can you please provide a link to the image you are trying to flash so that we can try it and diagnose the issue. Also does it work the second time if you click retry? Thank you.
Hi could you please share with us the following context so that we are able to troubleshoot?
- The Etcher version you’re running.
- The operating system you’re running Etcher in.
- Relevant logging output, if any, from DevTools, which you can open by pressing Ctrl+Shift+I or Cmd+Alt+I depending on your platform.
Georgia
