helium-nebra-indoor2 New rock pi no beacon
Hello, I have a problem with a Nebra miner V2 that got a new rock pi, according to nebra everything is fine, but the device is not receiving anything, sending works. the HUT on another original nebra pi works immediately, so it must be something wrong with the new PI
greetings from Germany
mark
Hello @Lipper welcome to the balena community!
What do you see in the logs?
If you get into the Terminal > miner (or gateway_rs) service and query helium_gateway info name router and share the logs?
UUID
3b24117
3b241175716dcffa58618ce720e8f130_diagnostics_2023.04.22_21.32.12+0000.txt (53.2 KB)
api_port": 48484,
“ip_address”: “192.168.8.190 fd04:d3b5:98e3:bf00:3811:fdcf:9c02:353d”,
“os_version”: “balenaOS 2.108.25+rev1”,
“mac_address”: “B2:11:F1:B9:CF:43 08:FB:EA:E0:5A:F6”,
“supervisor_version”: “14.4.10”,
“update_pending”: false,
“update_failed”: false,
“update_downloaded”: false,
“commit”: “0c7ba6e018b8439a6bc801e1aff367c6”,
“status”: “Idle”,
“download_progress”: null
rockchip op1 pi4
 Failed	User service 'helium-miner' is restarting unexpectedly, count: 1
@Lipper could you please share the lines around the logs to get context?
on the other hand, could you please try this? :point_down:
Captura de pantalla 2023-04-25 a les 10.05.51
“router”: {
“connected”: true,
“uri”: “http://mainnet-router.helium.io:8080/”
“name”: “sleepy-vanilla-kookaburra”
/opt/nebra-gatewayrs #
I apologize, I’ve only been dealing with this for a few days, not my word
helium-nebra-indoor2_simple-snow-25.04.23_11_30_08_(+0200).txt (118.8 KB)
3b241175716dcffa58618ce720e8f130_diagnostics_2023.04.25_09.41.39+0000.txt (429.2 KB)
@Lipper do you still see the same logs from the miner service?
Could you please confirm what do you see on the logs?
3b241175716dcffa58618ce720e8f130_diagnostics_2023.04.26_09.33.42+0000.txt (376.8 KB)
Standard error
diagnose failed: exit code undefined
stderr:
— diagnose 4.22.13 —
— NOTE: not all commands are expected to succeed on all device types —
— COMMANDS —
— prefixing commands with ‘date --utc --rfc-3339=ns ; /usr/bin/time -o /dev/stdout timeout --preserve-status --kill-after=20 -v 10 bash -c’ —
— echo === BALENA === —
— curl --unix-socket /var/run/balena.sock http://./debug/pprof/goroutine?debug=2 —
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
100 151k 0 151k 0 0 4598k 0 --:–:-- --:–:-- --:–:-- 4598k
— balena --version —
— balena images —
— balena ps -a —
— balena stats --all --no-stream —
— balena system df —
— balena volume ls —
— balena network ls —
— systemctl status balena --no-pager —
— journalctl --no-pager --no-hostname -n 200 -a -u balena —
— journalctl --no-pager --no-hostname -n 1000 -at balenad —
— balena inspect $(balena ps --all --quiet | tr “\n” " ") | jq “del(..Config.Env)” —
— balena network inspect $(balena network ls --quiet | tr “\n” " ") —
— test -f /mnt/state/balena-engine-storage-migration.log && cat /mnt/state/balena-engine-storage-migration.log —
— echo === BOOT === —
— systemd-analyze —
e[0;1;31mBootup is not yet finished (org.freedesktop.systemd1.Manager.FinishTimestampMonotonic=0).e[0m
e[0;1;31mPlease try again later.e[0m
e[0;1;31mHint: Use ‘systemctl list-jobs’ to see active jobse[0m
— systemd-analyze critical-chain —
— echo === HARDWARE === —
— cat /proc/cpuinfo —
— cat /proc/device-tree/model —
— cat /proc/meminfo —
— ps —
— top -b -n 1 —
— cat /var/log/provisioning-progress.log —
cat: /var/log/provisioning-progress.log: No such file or directory
— df -h —
— df -ih —
— for i in /sys/class/thermal/thermal* ; do if [ -e $i/temp ]; then echo $i && cat $i/temp; fi ; done —
— for i in /sys/class/mmc_host/mmc*/mmc* ; do if [ -e $i/oemid ]; then echo $i; for j in manfid oemid name hwrev fwrev; do printf $j: && cat $i/$j; done; fi; done —
— free -h —
— ls -l /dev —
— lsusb -vvv —
can’t get debug descriptor: Resource temporarily unavailable
can’t get device qualifier: Resource temporarily unavailable
— mmcli -L —
— mount —
— uname -a —
— echo === NETWORK === —
— /sbin/ip addr —
— cat /etc/resolv.conf —
— cat /proc/net/dev —
— cat /proc/net/snmp —
— cat /proc/net/udp —
— CURL_CA_BUNDLE=/tmp/tmp.d65aYFDWIj curl https://api.balena-cloud.com/ping —
100 2 100 2 0 0 4 0 --:–:-- --:–:-- --:–:-- 4
— CURL_CA_BUNDLE=/tmp/tmp.d65aYFDWIj curl https://www.google.co.uk —
@Lipper i meant the logs from the balenaCloud dashboard (not diagnostics)
well… on the file you shared i see a log of errors from your miner. Did you update to the latest version of Nebra?
on the other hand, did you add device variables such as REGION_OVERRIDE or VARIANT?
no logs miner service … But another miner who worked logs
helium-nebra-indoor2_simple-snow-26.04.23_11_46_21_(+0200).txt (118.3 KB)
could you please grant support access and share your UUID? Thanks!
Yes, I’ve also been writing with the Nebra people for weeks, new image recreated nothing helped… that’s why I downloaded the Nebra balena software.
No, I haven’t changed anything
