hi i have 240 gb ssd kingston drive and im using SABRENT to connect it to the computer im trying to flash a hiveos-0.6-205-stable@210715 but im receiving an error massage i tried with the image file and with the zip file from hiveos site but both giving me same flash failed massage
Hi, what version of etcher are you using?
Also, it would be helpful if you could include the Console logs from your flashing process. In Etcher, press Control+Shift+I to open up the Developer Tools, go to console, then start your flash. Copy/Paste those logs here, so we can have a look at where it is failing. One other note, if you have any antivirus or security utilities running, it might be a good to disable them, as they sometimes interfere and try to prevent write access to devices.
Hi, I`m having similar problem, here you can find logs:
ppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js
gui.js:35 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:46 Sun Mar 27 2022 13:44:17 GMT+0200 (czas środkowoeuropejski letni) SafeWebview loaded ({“event”:{“id”:1,“url”:“Etcher Featured Project 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:["*"],“age”:[“234”],“alt-svc”:[“h3=”:443"; ma=86400, h3-29=":443"; ma=86400"],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“6f27df8378367539-LHR”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Sun, 27 Mar 2022 11:44:15 GMT”],“expect-ct”:[“max-age=604800, report-uri=“https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct””],“expires”:[“Fri, 25 Mar 2022 21:29:16 GMT”],“fastly-original-body-size”:[“450”],“last-modified”:[“Wed, 16 Mar 2022 22:03:28 GMT”],“nel”:["{“success_fraction”:0,“report_to”:“cf-nel”,“max_age”:604800}"],“report-to”:["{“endpoints”:[{“url”:“https:\/\/a.nel.cloudflare.com\/report\/v3?s=RC6GNk1mCRW%2Bknnk4clw0%2FXVR7hSPUUPWuOUkl%2FX7HFWUvN26KwxkG2dlq0yI7xTP3Ew3%2FOG8q4nFzDdojZP05VB2KcDs8AaudNxkq%2BehTiVOrQa90RMsJnO3P4B7hmeXkzw”}],“group”:“cf-nel”,“max_age”:604800}"],“server”:[“cloudflare”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“25679a178595b4953d2f1219c84126e9f1f2d8b3”],“x-github-request-id”:[“12FA:0548:25FE64:517499:623E31D4”],“x-origin-cache”:[“HIT”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-lcy19281-LCY”],“x-timer”:[“S1648381456.926651,VS0,VE1”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“451a1197-1174-4730-8b28-f70f9220fe15”,“flashingWorkflowUuid”:“62a85874-819e-4086-881e-a94407887efa”})
gui.js:46 Successfully connected to IPC server: etcher-server-17852, socket root C:\Users\Psche\AppData\Local\Temp
gui.js:46 Image: C:\Users\Psche\Downloads\hiveos-0.6-212-stable@211201.img
gui.js:46 Devices: \.\PhysicalDrive1
gui.js:46 Auto blockmapping: true
gui.js:46 Decompress first: true
gui.js:35 Flashing 1 device, 0% at 0.30 MB/s (total 0.30 MB/s) eta in 23223s with 0 failed devices
gui.js:46 Sun Mar 27 2022 13:47:05 GMT+0200 (czas środkowoeuropejski letni) Flash error ({“image”:{“size”:7549747200,“name”:“hiveos-0.6-212-stable@211201.img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:20971520,“type”:“EBD0A0A2-B9E5-4433-87C0-68B6B72699C7”,“guid”:“03661D4C-E4F0-460F-9521-B8131E40507B”,“name”:“HIVE”,“index”:1},{“offset”:22020096,“size”:1048576,“type”:“21686148-6449-6E6F-744E-656564454649”,“guid”:“EAE4D79F-FF2A-4E00-A028-E2A605E42E95”,“name”:“BIOS boot partition”,“index”:2},{“offset”:23068672,“size”:41943040,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“F497799C-3108-4810-868E-CADC44FB7503”,“name”:“EFI System”,“index”:3},{“offset”:65011712,“size”:7484718592,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“901FB7C5-4726-4763-81E2-694B642F4A9F”,“name”:“HiveOS root filesystem”,“index”:4}],“extension”:“img”,“path”:“C:\Users\Psche\Downloads\hiveos-0.6-212-stable@211201.img”},“drives”:[{“size”:240057409536,“isVirtual”:false,“enumerator”:“SCSI”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:"\\.\PhysicalDrive1",“blockSize”:4096,“isSCSI”:true,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:false,“devicePath”:null,“mountpoints”:,“description”:“SSDPR-CL 100-240-G3 SCSI Disk Device”,“isUAS”:true,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“81f0cd35-566b-481a-b937-2bbebe21f087”,“flashInstanceUuid”:“81f0cd35-566b-481a-b937-2bbebe21f087”,“error”:{“name”:“Error”,“message”:“ETIMEDOUT: connection timed out, write”,“stack”:“Error: ETIMEDOUT: connection timed out, write”,“code”:“ETIMEDOUT”,“syscall”:“write”,“errno”:-4039},“sample”:0.1,“applicationSessionUuid”:“451a1197-1174-4730-8b28-f70f9220fe15”,“flashingWorkflowUuid”:“62a85874-819e-4086-881e-a94407887efa”})
gui.js:35 Flashing 0 devices, 0% at 0.30 MB/s (total 0.00 MB/s) eta in 23223s with 1 failed device
gui.js:46 Finish: 65536
gui.js:46 Terminating IPC server
gui.js:46 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:46 Sun Mar 27 2022 13:47:08 GMT+0200 (czas środkowoeuropejski letni) Done ({“image”:{“size”:7549747200,“name”:“hiveos-0.6-212-stable@211201.img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:20971520,“type”:“EBD0A0A2-B9E5-4433-87C0-68B6B72699C7”,“guid”:“03661D4C-E4F0-460F-9521-B8131E40507B”,“name”:“HIVE”,“index”:1},{“offset”:22020096,“size”:1048576,“type”:“21686148-6449-6E6F-744E-656564454649”,“guid”:“EAE4D79F-FF2A-4E00-A028-E2A605E42E95”,“name”:“BIOS boot partition”,“index”:2},{“offset”:23068672,“size”:41943040,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“F497799C-3108-4810-868E-CADC44FB7503”,“name”:“EFI System”,“index”:3},{“offset”:65011712,“size”:7484718592,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“901FB7C5-4726-4763-81E2-694B642F4A9F”,“name”:“HiveOS root filesystem”,“index”:4}],“extension”:“img”,“path”:“C:\Users\Psche\Downloads\hiveos-0.6-212-stable@211201.img”},“drives”:[{“size”:240057409536,“isVirtual”:false,“enumerator”:“SCSI”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:"\\.\PhysicalDrive1",“blockSize”:4096,“isSCSI”:true,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:false,“devicePath”:null,“mountpoints”:,“description”:“SSDPR-CL 100-240-G3 SCSI Disk Device”,“isUAS”:true,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“81f0cd35-566b-481a-b937-2bbebe21f087”,“status”:“finished”,“flashInstanceUuid”:“81f0cd35-566b-481a-b937-2bbebe21f087”,“errors”:[{“name”:“Error”,“description”:“SSDPR-CL 100-240-G3 SCSI Disk Device”,“code”:“ETIMEDOUT”,“syscall”:“write”,“errno”:-4039,“device”:"\\.\PhysicalDrive1"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:65536,“sourceMetadata”:{“size”:7549747200,“name”:“hiveos-0.6-212-stable@211201.img”,“blocks”:[{“blocks”:[{“offset”:0,“length”:106954752}]},{“blocks”:[{“offset”:108003328,“length”:3145728}]},{“blocks”:[{“offset”:116391936,“length”:9437184}]},{“blocks”:[{“offset”:126877696,“length”:94371840}]},{“blocks”:[{“offset”:223346688,“length”:1048576}]},{“blocks”:[{“offset”:228589568,“length”:2097152}]},{“blocks”:[{“offset”:231735296,“length”:1048576}]},{“blocks”:[{“offset”:233832448,“length”:3145728}]},{“blocks”:[{“offset”:238026752,“length”:1048576}]},{“blocks”:[{“offset”:240123904,“length”:7340032}]},{“blocks”:[{“offset”:248512512,“length”:5242880}]},{“blocks”:[{“offset”:254803968,“length”:1048576}]},{“blocks”:[{“offset”:256901120,“length”:1048576}]},{“blocks”:[{“offset”:258998272,“length”:1048576}]},{“blocks”:[{“offset”:262144000,“length”:2097152}]},{“blocks”:[{“offset”:265289728,“length”:2097152}]},{“blocks”:[{“offset”:270532608,“length”:5242880}]},{“blocks”:[{“offset”:276824064,“length”:14680064}]},{“blocks”:[{“offset”:294649856,“length”:14680064}]},{“blocks”:[{“offset”:312475648,“length”:4194304}]},{“blocks”:[{“offset”:317718528,“length”:2097152}]},{“blocks”:[{“offset”:321912832,“length”:1048576}]},{“blocks”:[{“offset”:324009984,“length”:2097152}]},{“blocks”:[{“offset”:327155712,“length”:1048576}]},{
gui.js:46 Sun Mar 27 2022 13:47:09 GMT+0200 (czas środkowoeuropejski letni) SafeWebview loaded ({“event”:{“id”:26,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.7.8&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1648381629186.206,“resourceType”:“mainFrame”,“ip”:“3.125.252.47”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“73505”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“br”],“content-length”:[“6201”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Sat, 26 Mar 2022 15:22:02 GMT”],“etag”:["“f5e918e79186e1742e64fca613096f38-ssl-df”"],“link”:["</webpack-runtime-089d98f9359977565314.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-004503f2df4bb68d43f8.js>; rel=preload; as=script, </50c25a04-a68e3217d6ce65727bd7.js>; rel=preload; as=script, </73ad3401-ecb0d3613fde52e78ca5.js>; rel=preload; as=script, </532a2f07-f1ad28da1825cfcce2c7.js>; rel=preload; as=script, </app-d3f2c796bc2e57a8750f.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7d
