Etcher v1.4.3 release
The latest Etcher is out, get it from etcher.io
This release introduces the ability flash multiple devices simultaneously, and fixes some long standing issues, like EINVAL write errors on Linux.
Also, a warning has been added when flashing devices larger than the typical SD card, to further prevent accidental flashing of connected external hard drives.
Due to previous patch releases being unpublished, here’s the changelog for all of them together:
v1.4.3 - 2018-04-19
Fixes
  • Fix blob handling for usbboot
v1.4.2 - 2018-04-18
Features
  • Make the progress button blue on verification
  • Display succeeded and failed devices on finish screen
Fixes
  • Exclude RAID devices from drive selection list
  • Display untitled device when device lacks description
  • Prefix multiple devices label with quantity
  • Fix handling of errors over IPC
  • Fix usbboot blob loading
  • Revert using native binding to clean disks on Windows
v1.4.1 - 2018-04-10
Fixes
  • Exclude package.json from UI bundle
v1.4.0 - 2018-04-05
Features
  • Move the drive selector warning dialog to the flash step
  • Display image size for comparison if drive is too small
  • Implement writing to multiple destinations simultaneously
  • Add colorised multi-writes progress status dots
  • Move CLI write preparation logic into SDK
  • Make the drive-selector button orange on warnings
  • Warn the user on selection of large drives
  • Consolidate low-level components into Etcher SDK
  • Use native code to clean drives on Windows
  • Increase UV_THREADPOOL_SIZE to allocate 4 threads per CPU
  • Add icon next to drive size when compatibility warnings exist
  • Display number of active devices while flashing in CLI
  • Replace CRC32 checksums with SHA512
  • Enable usbboot on Linux if run as root
Fixes
  • Improve spacing to the drive-selector warning/error labels
  • Line wrap selector size subtitles wholly
  • Hide the size label given multiple devices
  • Use correct usbboot blob path in AppImages
  • Fix EINVAL error on Linux
  • Fix enabling debug output
  • Fix DevTools opening in docked mode
  • Fix menu’s application name
  • Fix “Array buffer allocation failed” when flashing some .dmg images
  • Log the banner load event to analytics
  • Warn on usbboot load error in the console on Linux
  • Ensure image/drive size is displayed on new line
  • Don’t force-inherit process environment on Windows
Misc
  • Replace Helvetica as the main font with Roboto
  • Update Electron to v1.7.13
  • Add spacing to the drive warning icon
  • Use multi-drive methods with drive-list warning button
  • Remove unused & deprecated robot protocol
  • Update copyright years
  • Update instructions in ISSUE_TEMPLATE
  • Use Concourse CI for automated release builds
  • Only publish production packages to Bintray (remove devel)
  • Replace Gitter with Resin.io Forums for support
  • Add support for arm64 / armv8 / aarch64 in build scripts
  • Add descriptive name to modal popup windows
