NOTE: This release has been pulled due to elevated error rates, and is not available anymore.
Most notably, this release introduces the ability flash multiple devices simultaneously, and fixes some long standing issues, like EINVAL write errors on Linux, and drive cleaning on Windows.
Also, a warning has been added when flashing devices larger than the typical SD card, to further prevent accidental flashing of connected external hard drives.
v1.4.1 - 2018-04-10
Fixes
- Exclude package.json from UI bundle
v1.4.0 - 2018-04-05
Features
- Move the drive selector warning dialog to the flash step
- Display image size for comparison if drive is too small
- Implement writing to multiple destinations simultaneously
- Add colorised multi-writes progress status dots
- Add descriptive name to modal popup windows
- Move CLI write preparation logic into SDK
- Make the drive-selector button orange on warnings
- Warn the user on selection of large drives
- Consolidate low-level components into Etcher SDK
- Use native code to clean drives on Windows
- Increase UV_THREADPOOL_SIZE to allocate 4 threads per CPU
- Add icon next to drive size when compatibility warnings exist
- Display number of active devices while flashing in CLI
- Replace CRC32 checksums with SHA512
- Enable usbboot on Linux if run as root
Fixes
- Improve spacing to the drive-selector warning/error labels
- Line wrap selector size subtitles wholly
- Hide the size label given multiple devices
- Use correct usbboot blob path in AppImages
- Fix EINVAL error on Linux
- Fix enabling debug output
- Fix DevTools opening in docked mode
- Fix menu’s application name
- Fix “Array buffer allocation failed” when flashing some .dmg images
- Log the banner load event to analytics
- Warn on usbboot load error in the console on Linux
- Ensure image/drive size is displayed on new line
- Don’t force-inherit process environment on Windows
Misc
- Replace Helvetica as the main font with Roboto
- Update Electron to v1.7.13
- Add spacing to the drive warning icon
- Use multi-drive methods with drive-list warning button
- Remove unused & deprecated robot protocol
- Update copyright years
- Update instructions in ISSUE_TEMPLATE
- Use Concourse CI for automated release builds
- Only publish production packages to Bintray (remove devel)
- Replace Gitter with Resin.io Forums for support
- Add support for arm64 / armv8 / aarch64 in build scripts
