@llp can you please provide the link to the other post? We’d like to make sure we’re following up on this.
Same problem with my Windows 7 installation.
Solution:
I installed an old portable version balenaEtcher-Portable-1.5.28-x64.exe
Worked OK since. All I wanted is to burn an eMMC card for an SBC.
Why bother about the version ?
Hi.
I tried today the latest version on my 2 win7 pc’s with ESU updates. Both failed to start.
I also test the same version on a win11 pc. it works.
index.css:1 Failed to load resource: net::ERR_FILE_NOT_FOUND
electron/js2c/renderer_init.js:13 (electron) The remote module is deprecated. Use GitHub - electron/remote: Bridge JavaScript objects from the main process to the renderer process in Electron. instead.
log @ electron/js2c/renderer_init.js:13
electron/js2c/asar_bundle.js:5 Uncaught Error: Den angitte prosedyren ble ikke funnet.
\?\C:\Users\ME/AppData\Local\Programs\balena-etcher\resources\app\generated\modules\usb\prebuilds\binding\node.napi.node
at process.func [as dlopen] (electron/js2c/asar_bundle.js:5)
at Object.Module._extensions…node (internal/modules/cjs/loader.js:1138)
at Object.func [as .node] (electron/js2c/asar_bundle.js:5)
at Module.load (internal/modules/cjs/loader.js:935)
at Module._load (internal/modules/cjs/loader.js:776)
at Function.f._load (electron/js2c/asar_bundle.js:5)
at Function.o._load (electron/js2c/renderer_init.js:33)
at Module.require (internal/modules/cjs/loader.js:959)
at require (internal/modules/cjs/helpers.js:88)
at Object.defineProperty.value (gui.js:1)
gui.js:1 Uncaught Error: Den angitte prosedyren ble ikke funnet.
\?\C:\Users\Me\AppData\Local\Programs\balena-etcher\resources\app\generated\modules\usb\prebuilds\binding\node.napi.node
Regards
Gartner
Same issue with Win7x64 machine and both portable and install latest version 1.10.2. Unplugged all usb drives but still only got a blank white box. I just found and tried to launch v.1.10.6 but had the same result - blank white box. No USB drives attached. Windows Events log shows this data:
Faulting application name: balenaEtcher-Setup-1.10.2.exe, version: 1.10.2.0, time stamp: 0x5c157f86
Faulting module name: System.dll, version: 0.0.0.0, time stamp: 0x5c157efa
Exception code: 0xc0000005
Fault offset: 0x00001581
Faulting process id: 0x6758
Faulting application start time: 0x01d908d6e6e71f47
Faulting application path: E:\balenaEtcher-Setup-1.10.2.exe
Faulting module path: C:\Users\ADMINI~1\AppData\Local\Temp\nsf43EC.tmp\System.dll
Report Id: 283f4362-74ca-11ed-a057-00ac808132fa
I am getting the same thing on Linux Mint 20.3 Cinnamon 64-bit
I tried redownloading it, and it was still a blank window.
Hello
To clarify a bit while we’re working on it :
I tested 1.10.6 on ubuntu 18, 20 and 22 and it works as it should.
Latest known working version for win 7 is : 1.7.9.
Newer version won’t work on win7 due to dependency on nodejs 14 (which drops support for win7).
@eisolson what version did you tried ?
I used 1.10.2 - the default download when I went to https://www.balena.io/etcher/.
I was in a rush - did google send me to the wrong site?
Where can I find 1.10.6?
That’s the site . But it looks out of date compared to GitHub : Release v1.10.6 · balena-io/etcher · GitHub
Hi there,
Same here - I updated the Balena Etcher version to the one available at balenaEtcher - Flash OS images to SD cards & USB drives for Windows and it just displays a blank screen.
Running windows 7.
Any ideas?
I tried to download a previous version but cannot find any oficial one online.
You can try different releases from the github page: Releases · balena-io/etcher · GitHub
The latest 1.18.11 opens a completely blank window (just the window frame, and all white background inside) on Windows 7 64-bit Home, even though it installs without any errors or warnings. Really weird, never seen anything like this kind of an issue with any other application.
If it is not supposed to install / run on Win-7, the installation should warn and refuse to proceed.
What is the latest version that was supposed to be Win-7-compatible?
Downgrading to 1.5.56 brings up a working application.
