Yikes this has been going on for years?!?
So I followed the instructions in the main article, and I had a bunch of windows from microsoft windows pop up saying It wasn’t going to work and I needed to format through them. I ignored them and followed the instructions in the main article, and I have both of my USB’s back. Yay.
Now.
What I did that caused this in the first place, I was using Balena Etcher on a Lenovo Windows 11 computer to flash the image of linex mint (which I verified, downloaded via john hopkins and verified before flashing) onto my flash drive. I have done this before on a different computer using etcher and had no issues (that computer had windows 10).
The two usb sticks I was using were a lexar by micron, and a no name chinese stick I’ve had forever.
Both are now restored, and I’m going to go back in and try again with one of them.
Seems like some people are recommending Rufus? So I may try that, not sure.
Dear Balena Team, please fix this, it’s been going on way to long from the look of things. Could it be that windows 11 is nerfing your software somehow?
I’ll update this once I’m further along.
Round 2
USB stick one: I notice that Windows Command asks for permission to change the drive when I begin the balena etcher flash process. Denying this stops the program.
Etch completed
The USB no longer appears under drives.
Pulled stick out
Reinserted
“Microsoft Windows You need to format the disk in drive D before you can use it, do you want to format it?”
Format disk or cancel
hit cancel
Error box
“Location is not available”
D: is not accessable
The volume does not contain a recognized file system.
Please make sure that all required file system drivers are loaded and that the volume is not corrupted"
When I look at the properties of the USB drive I find it now shows
Used space 0 bytes
Free space 0 bytes
I go to Optimize drives
this USB has been renamed and it now shows
"\?\Volume(07896644-3e61 -4841 -b41b-ca3f44823cce)
It says the type is a hard disk drive
“Current status optimization not available (file system type not supported”
Soooo. I’m not very good at this stuff which is why I’m putting this all up here so someone smarter can figure it out. However I have a theory.
My theory is essentially that Windows has nerfed the Balena software to prevent people switching to linex. Reading other forums etc. it seems that some people when this happens, if they plug the USB stick into a computer running Linex, than linex can read it no problem. When I do try to format it it says that it is write protected.
So for now I’m going to try using this article to fix my USB drive again.
The same thing happens as before when I get to the part where I type
“create partition primary”
Windows interjects and pops up the blank dialog and then a smaller dialog box that says
“You need to format the drive in D before you can use it.
Do you want to format it?”
Ignore that entirely, use alt-tab to switch back to your command window, and then your Browser window with your instructions
continue with the instructions in the above article
I complete the instructions with out event and after
“format quick”
Just like that I have a working USB stick back again.
I think what’s happening is that when the etcher is used somehow it’s changing the format to something windows can’t read. Which leads to the belief that the drive is “bricked”
At least for me, that’s what has gone on.
…sigh…
