Etcher broke my USB stick … or did it?
Same problem as “swifter” on a very little-used SanDisk 128GB USB drive.
I’ve also registered on the forum to throw my hat in the ring.
I have 3 USBs bricked after using Balena Etcher to write iso. I have specifically used iso extracted from arc-23.7.33.img.zip .
I was able intially to boot from the USBs, but after I reconnected them to W10 machine to re-write they stopped working completely.
I have used a bunch of tools to revive them (incl. HP USB formatter tool) but they seem to be completely bricked.
For all USB sticks, the name is: ‘SkyMedi SK6238A BLoader USB Device’ and they all show 64MB/67MB (they are 8GB from different brands - i don’t believe a certain brand is to blame).
The error I get everywhere is: Write error [0x00000079] The semaphore timeout period has expired.
I have also tried to format/reformat using Rufus - no joy.
Here is a print screen from my attempt to restore with Rufus (and the log below).
Log:
Rufus x64 v4.1.2045
Windows version: Windows 10 Home x64 (Build 19045.3208)
Syslinux versions: 4.07/2013-07-25, 6.04/pre1
Grub versions: 0.4.6a, 2.06
System locale ID: 0x0809 (en-GB)
Will use default UI locale 0x0809
SetLGP: Successfully set NoDriveTypeAutorun policy to 0x0000009E
Localization set to ‘en-US’
Notice: The ISO download feature has been deactivated because ‘Check for updates’ is disabled in your settings.
Found USB 2.0 device ‘SkyMedi SK6238A BLoader USB Device’ (1516:1238)
1 device found
No volume information for drive 0x81
Disk type: Removable, Disk size: 67 MB, Sector size: 512 bytes
Cylinders: 8, Tracks per cylinder: 255, Sectors per track: 63
Partition type: SFD (Super Floppy Disk) or unpartitioned
1 device found
Format operation started
Requesting disk access…
No drive letter was assigned…
Will use ‘E:’ as volume mountpoint
Warning: Could not delete partition(s): [0x80070079] The semaphore timeout period has expired.
Opened \.\PhysicalDrive1 for shared write access
Requesting logical volume handle…
Analyzing existing boot records…
Drive does not have a Boot Marker
Clearing MBR/PBR/GPT structures…
Erasing 128 sectors
Retrying in 5 seconds…
Could not reset partitions
Re-mounted volume as E: after error
1 device found
Closed Windows format prompt
1 device found
1 device found
Also, from Event viewer (removed images because “An error occurred: Sorry, new users can only put one embedded media item in a post.”.
I’ve also downloaded “Skymedi SK6238 MPTool 2015-05-08 (SK6238_MPT_20150508)” and it seems to read properly the USB
LE: (as I am limited on how much I can post) after using the tool a bit more, i was able to revive one of the USB’s (i’ll try with the other two), but here are the steps:
  1. Open MPTool
  2. Go to Setup - leave password field empty
  3. Leave auto detect, just change the flash size to the actual size of the disk.
  4. On the right, yu have Erase option - select Erase all
  5. Hit OK
  6. Hit Start
Print screen below.
PS: I’ve deleted my previous post #because
“Multiple errors occurred: 1) We’re sorry, but new users are temporarily limited to 3 replies in the same topic. 2) No more than 3 consecutive replies are allowed. Please edit your previous reply, or wait for someone to reply to you.”
Out of curiosity, why most USB writers don’t have a restore option? If it can destroy a device it should have the option to restore it too. I was in the same shoes couple of years ago, I used a flash drive to install linux and then I couldn’t restore the flash drive into a working condition for some reason using any of the GUI tools until I found out how to dd it with zeros. (it was detected as a cd/dvd rom before) Clearing the MBR/GPT or whatever and creating an empty partition probably wouldn’t take much to implement into this software.
It’s evident that it is a necessary and missing feature.
For peeps having issues restoring their drives, try Fedora Media Writer, if it detects a device when launched, it will show the option to restore it to its original state.
I just lost two drives after trying to flash Batocera. It worked at first, I thought, but then both drives became completely inoperable. I am going to try Rufus. If anyone else has flasher recommendations I’d appreciate it. Though, that may get this post removed. We’ll see.
Welp, that didn’t work…
I’ve been trying to use balenaEtcher to flash Linux Mint. Either the software is broken or Linux Mint, but it gives some kind of security error when trying to boot Linux Mint. Never had this before.
Blockquote
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 119 GB 0 B *
Disk 1 Online 28 GB 25 GB *
Disk 2 Online 7580 MB 3072 KB
DISKPART> select disk 1
Disk 1 is now the selected disk.
DISKPART> create partition primary
DiskPart succeeded in creating the specified partition.
DISKPART> select partition 1
Partition 1 is now the selected partition.
DISKPART> format quick
There is no volume selected.
Please select a volume and try again.
DISKPART>
Appears as a drive in File Explorer that remains inaccessible (prompts to insert a disk). DiskPart is unable to perform a clean or format, chkdsk cannot check it due to its raw state, properties lack the ability to conduct a check, and it remains non-functional on another computer where I attempted to use it.
Nice thanks for sharing this.
Great guide. It would be awesome to have this built-in the Balena Etcher app
Thank you! This unbricked a new USB flash drive I had only used to flash two Linux images yesterday (Ubuntu and MX Linux). I couldn’t flash the third today (Mint). I couldn’t even format the drive in Windows. Thank you!
Balena Etcher creaeted two partitions in my usb and after formatting the read speed is ok but the write speed is around 1MB/s or less. Pls tell if there is a way to restore the write sp
This app is not funny joke, dunno how Ubuntu can recommend it on their site.
Flashed Ubuntu on it recently, but now I need Windows, so I don’t even know if it works or not…
Anyway this Balena soft split my usb into 2 partitions, cannot format either of it in windows, it gave me more headache than smile. Old Rufus from 4 years ago or so did a job and helped me format it…
Cannot recommend, unless you like beta testing.
On top of Download page it should be a red Warning, says it’s beta release and can cause minor problem, see forum for more info…
Anyway I just uninstalled it, it was like 143mb in application list, lol, Rufus its just a 1,55mb
Awesome find! Rufus repaired the drive, I tried the suggestions by Balena and then tried other utilities. Rufus worked!
OK this has to be embarrassing for this dev team. Thank you cosnet for providing a viable resolution.
Hi all. If you are not succeeded with fixing your drive, it is not the end of the story. Just stop trying to do this on Windows. This OS has a lot of limitations when we talk about managing filesystem and storage.
What helped for me :
I have plugged the drive to PC with Ubuntu and used pre installed “Disks” utility to format the drive to NTFS filesystem. I have checked “Erase” so it will take some time.
If this will not help - try another fixes using terminal. But only on Linux or Mac OS - this is the last chance to unbrick.
you broke me brand new usb disk. I found your software promoted by POP OS installation instructions. What a shame… You should simply shut down your website and remove your stupid software from internet. obviously you suck and don’t know what you’re doing. I would sue you if I could.
READ THIS BALENA! YOUR CRAP USB ETCHER PROGRAM SHOULD BE CONSIGNED TO THE DUSTBIN ALONG WITH YOUR PROGRAMMING SKILLS!
HOW DARE YOU CONTINUE PRODUCING THIS SHITE SOFTWARE TO BURN USB DRIVES, BRICKING PEOPLE’S HARDWARE!!!
LESSON LEARNED: BALENA IS SHITE AND SO IS THE SOFTWARE
SOLUTION: USE VMWARE RED HAT LINUX TO READ THE USB DRIVE, IT MAY WORK FOR YOU AND LET YOU GET IT BACK!!!
REPEAT AFTER ME BALENA, BALENA ETCHER IS CRAP!!!
UNBRICKED BY DELETING THE PARTITIONS IN LINUX FDISK AND CREATING NEW ONE IN DOS FORMAT
Just made an account to confirm that this has killed 3 sandisk USB’s. Diskpart can’t find them.
Going to be actively telling people to avoid this software like the plague. The entire thread is developers desperately trying to gaslight its users into not blaming its vibe coded software for shitting the bed.
Genuinely appalled by the mentally stunted reaction from the team here. Like actually concerned for the future of the company.
Use Rufus or literally anything else.
