[Error] Failed to load resource: the server responded with a status of 400 ( (application(1831696), line 0) https://api.balena-cloud.com/v6/application(1831696)
[Error] Unhandled Promise Rejection: Error: Timed out
promiseEmptyOnRejected (1.8b139c2c29005bbb5cfb.js:2:2147109)
promiseReactionJob
This error means that the API is sending an object instead of a string.
Could you please open the browser console and check what the console is printing? There should be all the description of the error and you will get the content of the object that generates this error.
Could you please share it with us to understand what happens?
@maggie0002 we detected a UI bug that can be related with this issue! We created a github issue, so when we are going to solve this, we will let you know!
Error!Operation failed with: Request error: Can't delete application(s) 1831696 because following devices are still running releases that belong to these application(s): 95d725433c64af130c67a54b12cd0813, 097c117ce959c19dcd5c8205ec825972
There are no devices in the fleet I am trying to delete. The device numbers that are listed have been moved to another fleet.
This error is occurring because while you moved the devices to a different fleet (let’s call it Fleet B), the devices are still running the release of their original fleet (Fleet A). We are aware of this bug and can let you know when it has been resolved. Until then, in order to be able to delete Fleet A, the devices you moved to Fleet B must download a new release
Hello, I know it’s been a while but I just wanted to let you know that yesterday we deployed a new version of the API which should make it possible to delete a fleet (FleetA) where a device that has been moved from FleetA to another fleet (FleetB) is still running a release from FleetA. If you are still experiencing the issue we discussed in this ticket of being unable to delete a fleet such as FleetA, you should be able to do so now. Thank you for your patience and please let us know if you have any feedback or questions
