Error(0,h.requestMetadata) is not a function
Error: (O, h.requestMetadata) is not a function
I had the same problem. After reading this long list of posts and seeing no attempt to help from the developer, I tried the “right-click and Run as administrator (even though I was logged in on in Win10 as administrator) and that worked for selecting the file. But then I got another error message when it tried to “Flash”. On a second try, it could not see my memory stick. When I removed it and plugged it back in, it saw the stick, and seemed to work. It finished writing and spent a lot of time verifying until it was almost to the end when it returned with the same error message. I didn’t copy the message and now my USB memory stick seems to be nonfunctional. It was almost new.
Thank you. The right-click suggestion worked to get past that error. Unfortunately the app still didn’t let me create the bootable drive.
I’m not very computer literate but I am fed up trying to load Zorin onto my W10 laptop, I’ve followed instructions to the letter in a popular computer magazine, everything worked fine until I had to insert a memory stick and send Zorin to it using Balenaetcher, all I get is an error message saying “error opening source” ERROR:9)’h.requestMetadata is not a function. I have read many comments for a workaround but none work for me. I’m ready for tossing this laptop in the bin so any help would be greatly appreciated. I downloaded Balena today and I am using a HP Pavillion x360 laptop.
…and it never was (a function).
HAHAHAHA no.
It is not your computer. Its balenaetcher. Place balenaetcher on an external drive, and chuck it into a river.
Hi
Anyone who has Windows 11, version 25H2 (latest version) installed will encounter this error.
To resolve this issue, you need to install Microsoft Visual C++ v14 Redistributable (x64).
run etcher-util application before running balena-etcher applicaation
etcher-util is in the sub-directory of etcher file(resources)
search in files
worked in linux mint
etcher-util log
waiting for connection…
no connections or heartbeat for 10000 ms, terminating // start balena-etcher before timeout
waiting for connection… //another try
connection established… setting up
Ready …
waiting for instruction…
Scan requested
sourceMetadata requested
//it worked
I got this error message too. (Windows 11).
It worked OK after I moved the ISO file from where it was (on the desktop), to the downloads folder.
Thanks to user Nomadros for suggesting this in a previous reply
I had the same issue. I was using windows 10 and trying to etch a file named DigiPi-2.0-1.
What I did to fix the issue was:
  1. rename the image to DigiPi (I removed any hyphens and numbers)
  2. ran Etcher as administrator
Worked fine after that
I was using Revo Uninstaller and noticed that the install comes with both the Windows 10 & 11 version. I uninstalled the Windows 11 version and the program worked as it should.
idk if anyone still having issues but my fix was to put the etcher shortcut and the iso in the same folder. i ran the program as admin pointed it to the ISO and it worked. this was on a windows 10 machine. Hope this helps someone.
Hello! I’ve seen lots of posts about needing to grant admin rights and wanted to provide some clarification on what worked for me.
I received the same Error(0,h.requestMetadata) is not a function when trying to load the .iso on a Win 11 Pro machine. I tried to “Run as Admin” by right-clicking from the Start menu with no luck.
However, running the .exe in my downloads as admin worked. Hope this helps!
This is currently broken in 2.1.7 and at least for macOS Fix macOS ARM image opening in v2.1.7 by zubair-io · Pull Request #4673 · balena-io/etcher · GitHub has been open to fix it. According to that the error is related to the packaged etcher-util sidecar crashing. My hunch is that if/when this sidecar is working, it has permission problems on Windows which is why some are able to get it to work by running it as an admin.
macOS Solutions
You can use the build-in dd command if you’re comfortable on the CLI.
Note: Be very careful when selecting the proper disk to write to as dd overwrites all data on it. I.e. don’t accidentally choose your Mac’s internal drive.
  1. Insert the USB stick.
  2. List disks. diskutil list
  3. Find your USB stick and check the size to confirm you have the right device (e.g. /dev/disk4).
  4. Unmount (not eject) the disk diskutil unmountDisk /dev/disk4(obviously use your disk from step 3)
  5. Write the ISO to the raw device. Note rdisk and not disk below as it is faster sudo dd if=/path/to/your-specific.iso of=/dev/rdisk4 bs=1m
  6. Wait for the command to finish. It gives no progress by default and can take several minutes.
  7. Eject the disk when the command completes. diskutil eject /dev/disk4
I have run this process myself and it succeed.
I have also read that Rasberry Pi Imager or USBImager are good alternatives but I have not tried them myself.
Edit:
I was able to boot from the USB drive and install another OS on my machine so I can confirm this worked end-to-end.
It worked for me so thank you very much
I was having this same problem trying to make a bootable USB Zorin installer from an ISO image on an M2 MacBook Pro running Sonoma 14.7.1 with the latest version of Etcher. Set permissions for full drive access etc. with no luck. Found an older version on Sourceforge.net : file balenaEtcher-2.1.2-arm64.dmg and it worked straight off run directly from the mounted dmg with the ISO in downloads.
If 2.1.2 works, that points more to the packaged etcher-util sidecar regression in 2.1.7 than to the ISO itself. I’d keep 2.1.2 pinned until the fix lands, and get the older installer from the project’s official GitHub releases with a checksum check rather than a third-party mirror. On Windows, the admin workaround is worth trying on the actual Etcher executable, since shortcut elevation can behave differently.
