I’ve tried creating a Boot Stick for a Sophos Firewall and it just doesn’t have any progress. I’ve also been able to observe that diskpart doesn’t react if i try using that instead as long as any usb drive is attached to my system and rufus won’t show up for ages after starting it only so long as i have a usb drive attached.
Being unable to create a Bootable Drive in case i have to reimage my firewall is relatively worrying so i’d appreciate anything that points me into the right direction.
What do you mean with “just doesn’t have any progress”? Do you mean that flashing stalls at 0%? Sounds like a broken USB drive to me, have you tried another?
I mean its stuck on “Starting…” i’ve tried different USB drives, differend usb ports on my pc and even a different, freshly installed PC for that matter. i tried using a windows iso instead and the same thing happens. i confirmed the windows iso works with the same usb drive from the microsoft boot usb tool to create a bootable stick
What OS is this on? Which balenaEtcher version are you using? Also can you please clarify what do you mean with “diskpart doesn’t react if i try using that instead as long as any usb drive is attached to my system”? Does “dd” work?
-OS is Windows 10
-Balena Etcher v1.5.109
-diskpart is stuck on “on computer: computername”, doesn’T go to the next line so that i can actually send any commands
hi there, balenaEtcher has a console where you can see any error messages that may occur.
Open and focus on Etcher, and press Ctr+Shift+i to open the console. If any errors show up, that may help find out if the problem is with Etcher, or something else completely
Upon opening the Console the following error was printed:
gui.js:56295 {“stack”:“Error: The specified module could not be found.\r\n\\?\C:\Users\no\AppData\Local\Programs\balena-etcher\resources\app\generated\modules\winusb-driver-generator\build\Release\Generator.node\n at process.func [as dlopen] (electron/js2c/asar.js:140:31)\n at Object.Module._extensions…node (internal/modules/cjs/loader.js:1034:18)\n at Object.func [as .node] (electron/js2c/asar.js:140:31)\n at Module.load (internal/modules/cjs/loader.js:815:32)\n at Module._load (internal/modules/cjs/loader.js:727:14)\n at Function.Module._load (electron/js2c/asar.js:769:28)\n at Module.require (internal/modules/cjs/loader.js:852:19)\n at require (internal/modules/cjs/helpers.js:74:18)\n at Object. (file:///C%3A/Users/no/AppData/Local/Programs/balena-etcher/resources/app/generated/gui.js:36755:22)\n at webpack_require (file:///C%3A/Users/no/AppData/Local/Programs/balena-etcher/resources/app/generated/gui.js:16:27)”,“message”:“The specified module could not be found.\r\n\\?\C:\Users\no\AppData\Local\Programs\balena-etcher\resources\app\generated\modules\winusb-driver-generator\build\Release\Generator.node”}
I get that a file is missing but thats about it.
Hi there, there is a thread on the forums suggesting this issue be down to missing Microsoft dependencies. Can you please check if the appropriate dependencies for your version of windows are installed? Also, making sure that the ether build matches the OS (i.e. 32 vs 64 bit).
Installed the vcredist for my 64bit windows now the Error in console is gone but i still don’t get over “starting…” tried running as administrator again too and according to the dependancy checker im missing all of the following files which seems pretty excessive to me:
- API-MS-WIN-APPMODEL-RUNTIME-L1-1-0.DLL
- API-MS-WIN-APPMODEL-UNLOCK-L1-1-0.DLL
- API-MS-WIN-CORE-APIQUERY-L1-1-0.DLL
- API-MS-WIN-CORE-APIQUERY-L1-1-1.DLL
- API-MS-WIN-CORE-APPCOMPAT-L1-1-0.DLL
- API-MS-WIN-CORE-APPCOMPAT-L1-1-1.DLL
- API-MS-WIN-CORE-APPINIT-L1-1-0.DLL
- API-MS-WIN-CORE-ATOMS-L1-1-0.DLL
- API-MS-WIN-CORE-CALENDAR-L1-1-0.DLL
- API-MS-WIN-CORE-COM-L1-1-0.DLL
- API-MS-WIN-CORE-COM-L1-1-1.DLL
- API-MS-WIN-CORE-COM-MIDLPROXYSTUB-L1-1-0.DLL
- API-MS-WIN-CORE-COMM-L1-1-0.DLL
- API-MS-WIN-CORE-CONSOLE-L1-1-0.DLL
- API-MS-WIN-CORE-CONSOLE-L1-2-0.DLL
- API-MS-WIN-CORE-CONSOLE-L1-2-1.DLL
- API-MS-WIN-CORE-CONSOLE-L2-1-0.DLL
- API-MS-WIN-CORE-CONSOLE-L2-2-0.DLL
- API-MS-WIN-CORE-CONSOLE-L3-2-0.DLL
- API-MS-WIN-CORE-CRT-L1-1-0.DLL
- API-MS-WIN-CORE-CRT-L2-1-0.DLL
- API-MS-WIN-CORE-DATETIME-L1-1-0.DLL
- API-MS-WIN-CORE-DATETIME-L1-1-1.DLL
- API-MS-WIN-CORE-DATETIME-L1-1-2.DLL
- API-MS-WIN-CORE-DEBUG-L1-1-0.DLL
- API-MS-WIN-CORE-DEBUG-L1-1-1.DLL
- API-MS-WIN-CORE-DELAYLOAD-L1-1-0.DLL
- API-MS-WIN-CORE-DELAYLOAD-L1-1-1.DLL
- API-MS-WIN-CORE-ERRORHANDLING-L1-1-0.DLL
- API-MS-WIN-CORE-ERRORHANDLING-L1-1-2.DLL
- API-MS-WIN-CORE-ERRORHANDLING-L1-1-3.DLL
- API-MS-WIN-CORE-FIBERS-L1-1-0.DLL
- API-MS-WIN-CORE-FIBERS-L1-1-1.DLL
- API-MS-WIN-CORE-FIBERS-L2-1-0.DLL
- API-MS-WIN-CORE-FIBERS-L2-1-1.DLL
- API-MS-WIN-CORE-FILE-L1-1-0.DLL
- API-MS-WIN-CORE-FILE-L1-2-0.DLL
- API-MS-WIN-CORE-FILE-L1-2-1.DLL
- API-MS-WIN-CORE-FILE-L1-2-2.DLL
- API-MS-WIN-CORE-FILE-L2-1-0.DLL
- API-MS-WIN-CORE-FILE-L2-1-1.DLL
- API-MS-WIN-CORE-FILE-L2-1-2.DLL
- API-MS-WIN-CORE-FILE-L2-1-3.DLL
- API-MS-WIN-CORE-HANDLE-L1-1-0.DLL
- API-MS-WIN-CORE-HEAP-L1-1-0.DLL
- API-MS-WIN-CORE-HEAP-L2-1-0.DLL
- API-MS-WIN-CORE-HEAP-OBSOLETE-L1-1-0.DLL
- API-MS-WIN-CORE-INTERLOCKED-L1-1-0.DLL
- API-MS-WIN-CORE-IO-L1-1-0.DLL
- API-MS-WIN-CORE-IO-L1-1-1.DLL
- API-MS-WIN-CORE-JOB-L1-1-0.DLL
- API-MS-WIN-CORE-JOB-L2-1-0.DLL
- API-MS-WIN-CORE-KERNEL32-LEGACY-L1-1-0.DLL
- API-MS-WIN-CORE-KERNEL32-LEGACY-L1-1-1.DLL
- API-MS-WIN-CORE-KERNEL32-LEGACY-L1-1-2.DLL
- API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-0.DLL
- API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-1.DLL
- API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-2.DLL
- API-MS-WIN-CORE-LARGEINTEGER-L1-1-0.DLL
- API-MS-WIN-CORE-LIBRARYLOADER-L1-1-0.DLL
- API-MS-WIN-CORE-LIBRARYLOADER-L1-2-0.DLL
- API-MS-WIN-CORE-LIBRARYLOADER-L1-2-1.DLL
- API-MS-WIN-CORE-LIBRARYLOADER-L1-2-2.DLL
- API-MS-WIN-CORE-LIBRARYLOADER-L2-1-0.DLL
- API-MS-WIN-CORE-LOCALIZATION-L1-1-0.DLL
- API-MS-WIN-CORE-LOCALIZATION-L1-2-0.DLL
- API-MS-WIN-CORE-LOCALIZATION-L1-2-2.DLL
- API-MS-WIN-CORE-LOCALIZATION-L2-1-0.DLL
- API-MS-WIN-CORE-LOCALIZATION-OBSOLETE-L1-2-0.DLL
- API-MS-WIN-CORE-LOCALIZATION-PRIVATE-L1-1-0.DLL
- API-MS-WIN-CORE-LOCALREGISTRY-L1-1-0.DLL
- API-MS-WIN-CORE-MEMORY-L1-1-0.DLL
- API-MS-WIN-CORE-MEMORY-L1-1-1.DLL
- API-MS-WIN-CORE-MEMORY-L1-1-2.DLL
- API-MS-WIN-CORE-MEMORY-L1-1-3.DLL
- API-MS-WIN-CORE-MISC-L1-1-0.DLL
- API-MS-WIN-CORE-NAMEDPIPE-L1-1-0.DLL
- API-MS-WIN-CORE-NAMEDPIPE-L1-2-1.DLL
- API-MS-WIN-CORE-NAMEDPIPE-L1-2-2.DLL
- API-MS-WIN-CORE-NAMESPACE-L1-1-0.DLL
- API-MS-WIN-CORE-NORMALIZATION-L1-1-0.DLL
- API-MS-WIN-CORE-PATH-L1-1-0.DLL
- API-MS-WIN-CORE-PRIVATEPROFILE-L1-1-0.DLL
- API-MS-WIN-CORE-PROCESSENVIRONMENT-L1-1-0.DLL
- API-MS-WIN-CORE-PROCESSENVIRONMENT-L1-2-0.DLL
- API-MS-WIN-CORE-PROCESSSNAPSHOT-L1-1-0.DLL
- API-MS-WIN-CORE-PROCESSTHREADS-L1-1-0.DLL
- API-MS-WIN-CORE-PROCESSTHREADS-L1-1-1.DLL
- API-MS-WIN-CORE-PROCESSTHREADS-L1-1-2.DLL
- API-MS-WIN-CORE-PROCESSTHREADS-L1-1-3.DLL
- API-MS-WIN-CORE-PROCESSTOPOLOGY-L1-1-0.DLL
- API-MS-WIN-CORE-PROFILE-L1-1-0.DLL
- API-MS-WIN-CORE-PSAPI-ANSI-L1-1-0.DLL
- API-MS-WIN-CORE-PSAPI-L1-1-0.DLL
- API-MS-WIN-CORE-QUIRKS-L1-1-0.DLL
- API-MS-WIN-CORE-REALTIME-L1-1-0.DLL
- API-MS-WIN-CORE-REGISTRY-L1-1-0.DLL
- API-MS-WIN-CORE-REGISTRY-L1-1-1.DLL
- API-MS-WIN-CORE-REGISTRY-L2-1-0.DLL
- API-MS-WIN-CORE-REGISTRYUSERSPECIFIC-L1-1-0.DLL
- API-MS-WIN-CORE-RTLSUPPORT-L1-1-0.DLL
- API-MS-WIN-CORE-SHLWAPI-LEGACY-L1-1-0.DLL
- API-MS-WIN-CORE-SHLWAPI-OBSOLETE-L1-1-0.DLL
- API-MS-WIN-CORE-SIDEBYSIDE-L1-1-0.DLL
- API-MS-WIN-CORE-STRING-L1-1-0.DLL
- API-MS-WIN-CORE-STRING-L2-1-0.DLL
- API-MS-WIN-CORE-STRING-L2-1-1.DLL
- API-MS-WIN-CORE-STRING-OBSOLETE-L1-1-0.DLL
- API-MS-WIN-CORE-STRINGANSI-L1-1-0.DLL
- API-MS-WIN-CORE-SYNCH-L1-1-0.DLL
- API-MS-WIN-CORE-SYNCH-L1-2-0.DLL
- API-MS-WIN-CORE-SYNCH-L1-2-1.DLL
- API-MS-WIN-CORE-SYSINFO-L1-1-0.DLL
- API-MS-WIN-CORE-SYSINFO-L1-2-0.DLL
- API-MS-WIN-CORE-SYSINFO-L1-2-1.DLL
- API-MS-WIN-CORE-SYSINFO-L1-2-3.DLL
- API-MS-WIN-CORE-SYSTEMTOPOLOGY-L1-1-0.DLL
- API-MS-WIN-CORE-SYSTEMTOPOLOGY-L1-1-1.DLL
- API-MS-WIN-CORE-THREADPOOL-L1-2-0.DLL
- API-MS-WIN-CORE-THREADPOOL-LEGACY-L1-1-0.DLL
- API-MS-WIN-CORE-THREADPOOL-PRIVATE-L1-1-0.DLL
- API-MS-WIN-CORE-TIMEZONE-L1-1-0.DLL
- API-MS-WIN-CORE-TOOLHELP-L1-1-0.DLL
- API-MS-WIN-CORE-URL-L1-1-0.DLL
- API-MS-WIN-CORE-UTIL-L1-1-0.DLL
- API-MS-WIN-CORE-VERSION-L1-1-0.DLL
- API-MS-WIN-CORE-VERSION-L1-1-1.DLL
- API-MS-WIN-CORE-VERSION-PRIVATE-L1-1-0.DLL
- API-MS-WIN-CORE-VERSIONANSI-L1-1-0.DLL
- API-MS-WIN-CORE-VERSIONANSI-L1-1-1.DLL
- API-MS-WIN-CORE-WINDOWSERRORREPORTING-L1-1-0.DLL
- API-MS-WIN-CORE-WINDOWSERRORREPORTING-L1-1-1.DLL
- API-MS-WIN-CORE-WINDOWSERRORREPORTING-L1-1-2.DLL
- API-MS-WIN-CORE-WINRT-ERROR-L1-1-0.DLL
- API-MS-WIN-CORE-WINRT-ERROR-L1-1-1.DLL
- API-MS-WIN-CORE-WINRT-L1-1-0.DLL
- API-MS-WIN-CORE-WINRT-STRING-L1-1-0.DLL
- API-MS-WIN-CORE-WOW64-L1-1-0.DLL
- API-MS-WIN-CORE-WOW64-L1-1-1.DLL
- API-MS-WIN-CORE-XSTATE-L2-1-0.DLL
- API-MS-WIN-CORE-XSTATE-L2-1-1.DLL
- API-MS-WIN-CRT-LOCALE-L1-1-0.DLL
- API-MS-WIN-CRT-MATH-L1-1-0.DLL
- API-MS-WIN-CRT-PRIVATE-L1-1-0.DLL
- API-MS-WIN-CRT-RUNTIME-L1-1-0.DLL
- API-MS-WIN-CRT-STRING-L1-1-0.DLL
- API-MS-WIN-CRT-TIME-L1-1-0.DLL
- API-MS-WIN-DEVICES-CONFIG-L1-1-1.DLL
- API-MS-WIN-DOWNLEVEL-KERNEL32-L1-1-0.DLL
- API-MS-WIN-DX-D3DKMT-L1-1-0.DLL
- API-MS-WIN-DX-D3DKMT-L1-1-1.DLL
- API-MS-WIN-DX-D3DKMT-L1-1-3.DLL
- API-MS-WIN-DX-D3DKMT-L1-1-4.DLL
- API-MS-WIN-EVENTING-CLASSICPROVIDER-L1-1-0.DLL
- API-MS-WIN-EVENTING-PROVIDER-L1-1-0.DLL
- API-MS-WIN-EVENTLOG-LEGACY-L1-1-0.DLL
- API-MS-WIN-GDI-DPIINFO-L1-1-0.DLL
- API-MS-WIN-GDI-INTERNAL-UAP-L1-1-0.DLL
- API-MS-WIN-HTTP-TIME-L1-1-0.DLL
- API-MS-WIN-MM-MISC-L1-1-0.DLL
- API-MS-WIN-MM-MME-L1-1-0.DLL
- API-MS-WIN-MM-TIME-L1-1-0.DLL
- API-MS-WIN-SECURITY-ACTIVEDIRECTORYCLIENT-L1-1-0.DLL
- API-MS-WIN-SECURITY-APPCONTAINER-L1-1-0.DLL
- API-MS-WIN-SECURITY-BASE-L1-1-0.DLL
- API-MS-WIN-SECURITY-BASE-L1-2-0.DLL
- API-MS-WIN-SECURITY-CAPABILITY-L1-1-0.DLL
- API-MS-WIN-SECURITY-CREDENTIALS-L1-1-0.DLL
- API-MS-WIN-SECURITY-CRYPTOAPI-L1-1-0.DLL
- API-MS-WIN-SECURITY-GROUPPOLICY-L1-1-0.DLL
- API-MS-WIN-SECURITY-ISOLATEDCONTAINER-L1-1-0.DLL
- API-MS-WIN-SECURITY-LSAPOLICY-L1-1-0.DLL
- API-MS-WIN-SECURITY-SDDL-L1-1-0.DLL
- API-MS-WIN-SECURITY-SYSTEMFUNCTIONS-L1-1-0.DLL
- API-MS-WIN-SERVICE-MANAGEMENT-L1-1-0.DLL
- API-MS-WIN-SHCORE-COMHELPERS-L1-1-0.DLL
- API-MS-WIN-SHCORE-OBSOLETE-L1-1-0.DLL
- API-MS-WIN-SHCORE-PATH-L1-1-0.DLL
- API-MS-WIN-SHCORE-REGISTRY-L1-1-0.DLL
- API-MS-WIN-SHCORE-SCALING-L1-1-1.DLL
- API-MS-WIN-SHCORE-STREAM-L1-1-0.DLL
- API-MS-WIN-SHCORE-SYSINFO-L1-1-0.DLL
- API-MS-WIN-SHCORE-TASKPOOL-L1-1-0.DLL
- API-MS-WIN-SHCORE-UNICODEANSI-L1-1-0.DLL
- API-MS-WIN-SHELL-CHANGENOTIFY-L1-1-0.DLL
- API-MS-WIN-SHELL-SHELLCOM-L1-1-0.DLL
- API-MS-WIN-SHELL-SHELLFOLDERS-L1-1-0.DLL
- API-MS-WIN-SHLWAPI-WINRT-STORAGE-L1-1-1.DLL
- API-MS-WIN-STATESEPARATION-HELPERS-L1-1-0.DLL
- API-MS-WIN-STORAGE-EXPORTS-EXTERNAL-L1-1-0.DLL
- API-MS-WIN-STORAGE-EXPORTS-INTERNAL-L1-1-0.DLL
- EXT-MS-WIN-DX-D3DKMT-DXCORE-L1-1-0.DLL
- EXT-MS-WIN-USP10-L1-1-0.DLL
- API-MS-WIN-APPMODEL-IDENTITY-L1-2-0.DLL
- API-MS-WIN-APPMODEL-RUNTIME-INTERNAL-L1-1-1.DLL
- API-MS-WIN-APPMODEL-RUNTIME-INTERNAL-L1-1-2.DLL
- API-MS-WIN-APPMODEL-RUNTIME-INTERNAL-L1-1-3.DLL
- API-MS-WIN-APPMODEL-RUNTIME-L1-1-1.DLL
- API-MS-WIN-APPMODEL-RUNTIME-L1-1-2.DLL
- API-MS-WIN-APPMODEL-STATE-L1-2-0.DLL
- API-MS-WIN-BASE-UTIL-L1-1-0.DLL
- API-MS-WIN-CONTAINERS-CMCLIENT-L1-1-0.DLL
- API-MS-WIN-CORE-COM-L1-1-2.DLL
- API-MS-WIN-CORE-COM-L2-1-1.DLL
- API-MS-WIN-CORE-COM-PRIVATE-L1-1-0.DLL
- API-MS-WIN-CORE-COM-PRIVATE-L1-1-1.DLL
- API-MS-WIN-CORE-COM-PRIVATE-L1-2-0.DLL
- API-MS-WIN-CORE-COM-PRIVATE-L1-3-0.DLL
- API-MS-WIN-CORE-DEBUG-MINIDUMP-L1-1-0.DLL
- API-MS-WIN-CORE-FEATURESTAGING-L1-1-0.DLL
- API-MS-WIN-CORE-MARSHAL-L1-1-0.DLL
- API-MS-WIN-CORE-MEMORY-L1-1-5.DLL
- API-MS-WIN-CORE-PERFCOUNTERS-L1-1-0.DLL
- API-MS-WIN-CORE-PRIVATEPROFILE-L1-1-1.DLL
- API-MS-WIN-CORE-PROCESSTOPOLOGY-OBSOLETE-L1-1-0.DLL
- API-MS-WIN-CORE-PSM-APP-L1-1-0.DLL
- API-MS-WIN-CORE-PSM-APPNOTIFY-L1-1-0.DLL
- API-MS-WIN-CORE-PSM-KEY-L1-1-0.DLL
- API-MS-WIN-CORE-REALTIME-L1-1-1.DLL
- API-MS-WIN-CORE-REGISTRY-L1-1-2.DLL
- API-MS-WIN-CORE-REGISTRY-PRIVATE-L1-1-0.DLL
- API-MS-WIN-CORE-SHUTDOWN-L1-1-0.DLL
- API-MS-WIN-CORE-SYNCH-ANSI-L1-1-0.DLL
- API-MS-WIN-CORE-SYSINFO-L2-1-0.DLL
- API-MS-WIN-CORE-WINRT-ERRORPRIVATE-L1-1-0.DLL
- API-MS-WIN-CORE-WINRT-PROPERTYSETPRIVATE-L1-1-0.DLL
- API-MS-WIN-CORE-WINRT-PROPERTYSETPRIVATE-L1-1-1.DLL
- API-MS-WIN-CORE-WINRT-REGISTRATION-L1-1-0.DLL
- API-MS-WIN-CORE-WINRT-ROBUFFER-L1-1-0.DLL
- API-MS-WIN-COREUI-SECRUNTIME-L1-1-0.DLL
- API-MS-WIN-CRT-CONVERT-L1-1-0.DLL
- API-MS-WIN-CRT-ENVIRONMENT-L1-1-0.DLL
- API-MS-WIN-CRT-FILESYSTEM-L1-1-0.DLL
- API-MS-WIN-CRT-HEAP-L1-1-0.DLL
- API-MS-WIN-CRT-PROCESS-L1-1-0.DLL
- API-MS-WIN-CRT-STDIO-L1-1-0.DLL
- API-MS-WIN-CRT-UTILITY-L1-1-0.DLL
- API-MS-WIN-DEVICES-QUERY-L1-1-0.DLL
- API-MS-WIN-DEVICES-QUERY-L1-1-1.DLL
- API-MS-WIN-DOWNLEVEL-ADVAPI32-L1-1-0.DLL
- API-MS-WIN-DOWNLEVEL-ADVAPI32-L1-1-1.DLL
- API-MS-WIN-DOWNLEVEL-ADVAPI32-L2-1-0.DLL
- API-MS-WIN-DOWNLEVEL-NORMALIZ-L1-1-0.DLL
- API-MS-WIN-DOWNLEVEL-OLE32-L1-1-0.DLL
- API-MS-WIN-DOWNLEVEL-SHELL32-L1-1-0.DLL
- API-MS-WIN-DOWNLEVEL-SHLWAPI-L1-1-0.DLL
- API-MS-WIN-DOWNLEVEL-SHLWAPI-L2-1-0.DLL
- API-MS-WIN-DOWNLEVEL-USER32-L1-1-0.DLL
- API-MS-WIN-DOWNLEVEL-VERSION-L1-1-0.DLL
- API-MS-WIN-DWMAPI-L1-1-0.DLL
- API-MS-WIN-EVENTING-CONSUMER-L1-1-0.DLL
- API-MS-WIN-EVENTING-CONSUMER-L1-1-1.DLL
- API-MS-WIN-EVENTING-CONTROLLER-L1-1-0.DLL
- API-MS-WIN-EVENTING-LEGACY-L1-1-0.DLL
- API-MS-WIN-EVENTING-OBSOLETE-L1-1-0.DLL
- API-MS-WIN-EVENTING-TDH-L1-1-0.DLL
- API-MS-WIN-MM-JOYSTICK-L1-1-0.DLL
- API-MS-WIN-MM-MISC-L1-1-1.DLL
- API-MS-WIN-MM-MISC-L2-1-0.DLL
- API-MS-WIN-NETWORKING-INTERFACECONTEXTS-L1-1-0.DLL
- API-MS-WIN-NTUSER-SYSPARAMS-L1-1-0.DLL
- API-MS-WIN-OLE32-IE-L1-1-0.DLL
- API-MS-WIN-OOBE-NOTIFICATION-L1-1-0.DLL
- API-MS-WIN-POWER-BASE-L1-1-0.DLL
- API-MS-WIN-POWER-SETTING-L1-1-0.DLL
- API-MS-WIN-RO-TYPERESOLUTION-L1-1-0.DLL
- API-MS-WIN-RTCORE-NTUSER-CLIPBOARD-L1-1-0.DLL
- API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-0.DLL
- API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-1.DLL
- API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-4.DLL
- API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-7.DLL
- API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-9.DLL
- API-MS-WIN-RTCORE-NTUSER-SHELL-L1-1-0.DLL
- API-MS-WIN-RTCORE-NTUSER-SYNCH-L1-1-0.DLL
- API-MS-WIN-RTCORE-NTUSER-WINDOW-L1-1-0.DLL
- API-MS-WIN-RTCORE-NTUSER-WINEVENT-L1-1-0.DLL
- API-MS-WIN-RTCORE-NTUSER-WMPOINTER-L1-1-0.DLL
- API-MS-WIN-SECURITY-ACCESSHLPR-L1-1-0.DLL
- API-MS-WIN-SECURITY-ACTIVEDIRECTORYCLIENT-L1-1-1.DLL
- API-MS-WIN-SECURITY-AUDIT-L1-1-0.DLL
- API-MS-WIN-SECURITY-AUDIT-L1-1-1.DLL
- API-MS-WIN-SECURITY-BASE-L1-2-1.DLL
- API-MS-WIN-SECURITY-BASE-PRIVATE-L1-1-0.DLL
- API-MS-WIN-SECURITY-BASE-PRIVATE-L1-1-1.DLL
- API-MS-WIN-SECURITY-CREDENTIALS-L2-1-0.DLL
- API-MS-WIN-SECURITY-ISOLATEDCONTAINER-L1-1-1.DLL
- API-MS-WIN-SECURITY-ISOLATIONPOLICY-L1-2-0.DLL
- API-MS-WIN-SECURITY-LOGON-L1-1-0.DLL
- API-MS-WIN-SECURITY-LOGON-L1-1-1.DLL
- API-MS-WIN-SECURITY-LSALOOKUP-ANSI-L2-1-0.DLL
- API-MS-WIN-SECURITY-LSALOOKUP-L1-1-0.DLL
- API-MS-WIN-SECURITY-LSALOOKUP-L1-1-1.DLL
- API-MS-WIN-SECURITY-LSALOOKUP-L1-1-2.DLL
- API-MS-WIN-SECURITY-LSALOOKUP-L2-1-0.DLL
- API-MS-WIN-SECURITY-PROVIDER-L1-1-0.DLL
- API-MS-WIN-SECURITY-SDDLPARSECOND-L1-1-0.DLL
- API-MS-WIN-SERVICE-CORE-L1-1-0.DLL
- API-MS-WIN-SERVICE-CORE-L1-1-1.DLL
- API-MS-WIN-SERVICE-CORE-L1-1-2.DLL
- API-MS-WIN-SERVICE-CORE-L1-1-4.DLL
- API-MS-WIN-SERVICE-MANAGEMENT-L2-1-0.DLL
- API-MS-WIN-SERVICE-PRIVATE-L1-1-0.DLL
- API-MS-WIN-SERVICE-PRIVATE-L1-1-2.DLL
- API-MS-WIN-SERVICE-PRIVATE-L1-1-3.DLL
- API-MS-WIN-SERVICE-PRIVATE-L1-1-4.DLL
- API-MS-WIN-SERVICE-WINSVC-L1-1-0.DLL
- API-MS-WIN-SHCORE-REGISTRY-L1-1-1.DLL
- API-MS-WIN-SHCORE-SCALING-L1-1-0.DLL
- API-MS-WIN-SHCORE-STREAM-WINRT-L1-1-0.DLL
- API-MS-WIN-SHCORE-THREAD-L1-1-0.DLL
- API-MS-WIN-SHELL-ASSOCIATIONS-L1-1-1.DLL
- API-MS-WIN-SHELL-NAMESPACE-L1-1-0.DLL
- API-MS-WIN-SHELL-SHDIRECTORY-L1-1-0.DLL
- API-MS-WIN-SHLWAPI-IE-L1-1-0.DLL
- EMCLIENT.DLL
- EXT-MS-MF-PAL-L2-1-0.DLL
- EXT-MS-ONECORE-APPDEFAULTS-L1-1-0.DLL
- EXT-MS-ONECORE-APPMODEL-EMCLIENT-L1-1-0.DLL
- EXT-MS-ONECORE-APPMODEL-STATEREPOSITORY-CACHE-L1-1-0.DLL
- EXT-MS-ONECORE-APPMODEL-STATEREPOSITORY-INTERNAL-L1-1-1.DLL
- EXT-MS-ONECORE-DCOMP-L1-1-0.DLL
- EXT-MS-ONECORE-HLINK-L1-1-0.DLL
- EXT-MS-ONECORE-ORIENTATION-L1-1-0.DLL
- EXT-MS-ONECORE-SERVICE-DEVICEDIRECTORY-CLAIMS-L1-1-0.DLL
- EXT-MS-ONECORE-SHELLCHROMEAPI-L1-1-0.DLL
- EXT-MS-WIN-ADSI-ACTIVEDS-L1-1-0.DLL
- EXT-MS-WIN-ADVAPI32-ENCRYPTEDFILE-L1-1-0.DLL
- EXT-MS-WIN-ADVAPI32-HWPROF-L1-1-0.DLL
- EXT-MS-WIN-ADVAPI32-LSA-L1-1-0.DLL
- EXT-MS-WIN-ADVAPI32-MSI-L1-1-0.DLL
- EXT-MS-WIN-ADVAPI32-NPUSERNAME-L1-1-0.DLL
- EXT-MS-WIN-ADVAPI32-NTMARTA-L1-1-0.DLL
- EXT-MS-WIN-ADVAPI32-PSM-APP-L1-1-0.DLL
- EXT-MS-WIN-ADVAPI32-REGISTRY-L1-1-0.DLL
- EXT-MS-WIN-ADVAPI32-REGISTRY-L1-1-1.DLL
- EXT-MS-WIN-ADVAPI32-SAFER-L1-1-0.DLL
- EXT-MS-WIN-APPCOMPAT-AEINV-L1-1-0.DLL
- EXT-MS-WIN-APPCOMPAT-AEPIC-L1-1-0.DLL
- EXT-MS-WIN-APPCOMPAT-APPHELP-L1-1-0.DLL
- EXT-MS-WIN-APPMODEL-APPEXECUTIONALIAS-L1-1-0.DLL
- EXT-MS-WIN-APPMODEL-APPEXECUTIONALIAS-L1-1-1.DLL
- EXT-MS-WIN-APPMODEL-DAXCORE-L1-1-0.DLL
- EXT-MS-WIN-APPMODEL-DEPLOYMENT-L1-1-0.DLL
- EXT-MS-WIN-APPMODEL-RESTRICTEDAPPCONTAINER-INTERNAL-L1-1-0.DLL
- EXT-MS-WIN-APPMODEL-STATE-EXT-L1-2-0.DLL
- EXT-MS-WIN-APPMODEL-USERCONTEXT-L1-1-0.DLL
- EXT-MS-WIN-APPMODEL-VIEWSCALEFACTOR-L1-1-0.DLL
- EXT-MS-WIN-APPXDEPLOYMENTCLIENT-APPXDEPLOY-L1-1-0.DLL
- EXT-MS-WIN-APPXDEPLOYMENTCLIENT-APPXDEPLOYONECORE-L1-1-0.DLL
- EXT-MS-WIN-AUDIOCORE-PAL-L1-2-0.DLL
- EXT-MS-WIN-AUTHZ-CONTEXT-L1-1-0.DLL
- EXT-MS-WIN-AUTHZ-REMOTE-L1-1-0.DLL
- EXT-MS-WIN-BIOMETRICS-WINBIO-CORE-L1-1-0.DLL
- EXT-MS-WIN-COM-CLBCATQ-L1-1-0.DLL
- EXT-MS-WIN-COM-COML2-L1-1-1.DLL
- EXT-MS-WIN-COM-OLE32-L1-1-0.DLL
- EXT-MS-WIN-COM-OLE32-L1-1-1.DLL
- EXT-MS-WIN-COM-OLE32-L1-1-2.DLL
- EXT-MS-WIN-COM-OLE32-L1-1-3.DLL
- EXT-MS-WIN-COM-OLE32-L1-1-4.DLL
- EXT-MS-WIN-COM-OLE32-L1-1-5.DLL
- EXT-MS-WIN-COM-PSMREGISTER-L1-1-0.DLL
- EXT-MS-WIN-COM-SUSPENDRESILIENCY-L1-1-0.DLL
- EXT-MS-WIN-CORE-PKEYHELPER-L1-1-0.DLL
- EXT-MS-WIN-CORE-WINRT-REMOTE-L1-1-0.DLL
- EXT-MS-WIN-DESKTOPAPPX-L1-1-3.DLL
- EXT-MS-WIN-DEVMGMT-DM-L1-1-0.DLL
- EXT-MS-WIN-DEVMGMT-DM-L1-1-1.DLL
- EXT-MS-WIN-DEVMGMT-POLICY-L1-1-0.DLL
- EXT-MS-WIN-DEVMGMT-POLICY-L1-1-1.DLL
- EXT-MS-WIN-DIRECT2D-DESKTOP-L1-1-0.DLL
- EXT-MS-WIN-DOMAINJOIN-NETJOIN-L1-1-0.DLL
- EXT-MS-WIN-DWMAPI-EXT-L1-1-0.DLL
- EXT-MS-WIN-DWMAPIDXGI-EXT-L1-1-0.DLL
- EXT-MS-WIN-DX-D3DKMT-GDI-L1-1-0.DLL
- EXT-MS-WIN-DXCORE-L1-1-0.DLL
- EXT-MS-WIN-EDPUTIL-POLICY-L1-1-0.DLL
- EXT-MS-WIN-EDPUTIL-POLICY-L1-1-1.DLL
- EXT-MS-WIN-ELS-ELSCORE-L1-1-0.DLL
- EXT-MS-WIN-EVENTING-RUNDOWN-L1-1-0.DLL
- EXT-MS-WIN-FAMILYSAFETY-CHILDACCOUNT-L1-1-0.DLL
- EXT-MS-WIN-FECLIENT-ENCRYPTEDFILE-L1-1-0.DLL
- EXT-MS-WIN-FECLIENT-ENCRYPTEDFILE-L1-1-1.DLL
- EXT-MS-WIN-FECLIENT-ENCRYPTEDFILE-L1-1-2.DLL
- EXT-MS-WIN-FECLIENT-ENCRYPTEDFILE-L1-1-3.DLL
- EXT-MS-WIN-FIREWALLAPI-WEBPROXY-L1-1-0.DLL
- EXT-MS-WIN-FVEAPI-QUERY-L1-1-0.DLL
- EXT-MS-WIN-GDI-CLIPPING-L1-1-0.DLL
- EXT-MS-WIN-GDI-DC-CREATE-L1-1-0.DLL
- EXT-MS-WIN-GDI-DC-L1-2-0.DLL
- EXT-MS-WIN-GDI-DC-L1-2-1.DLL
- EXT-MS-WIN-GDI-DEVCAPS-L1-1-0.DLL
- EXT-MS-WIN-GDI-DRAW-L1-1-0.DLL
- EXT-MS-WIN-GDI-DRAW-L1-1-1.DLL
- EXT-MS-WIN-GDI-DRAW-L1-1-2.DLL
- EXT-MS-WIN-GDI-DRAW-L1-1-3.DLL
- EXT-MS-WIN-GDI-FONT-L1-1-0.DLL
- EXT-MS-WIN-GDI-FONT-L1-1-1.DLL
- EXT-MS-WIN-GDI-FONT-L1-1-2.DLL
- EXT-MS-WIN-GDI-FONT-L1-1-3.DLL
- EXT-MS-WIN-GDI-GDIPLUS-L1-1-0.DLL
- EXT-MS-WIN-GDI-INTERNAL-DESKTOP-L1-1-0.DLL
- EXT-MS-WIN-GDI-INTERNAL-DESKTOP-L1-1-1.DLL
- EXT-MS-WIN-GDI-INTERNAL-DESKTOP-L1-1-2.DLL
- EXT-MS-WIN-GDI-INTERNAL-DESKTOP-L1-1-3.DLL
- EXT-MS-WIN-GDI-METAFILE-L1-1-0.DLL
- EXT-MS-WIN-GDI-METAFILE-L1-1-1.DLL
- EXT-MS-WIN-GDI-METAFILE-L1-1-2.DLL
- EXT-MS-WIN-GDI-PATH-L1-1-0.DLL
- EXT-MS-WIN-GDI-PRINT-L1-1-0.DLL
- EXT-MS-WIN-GDI-PRIVATE-L1-1-0.DLL
- EXT-MS-WIN-GDI-RENDER-L1-1-0.DLL
- EXT-MS-WIN-GDI-WCS-L1-1-0.DLL
- EXT-MS-WIN-GPAPI-GROUPPOLICY-L1-1-0.DLL
- EXT-MS-WIN-GUI-DUI70-L1-1-0.DLL
- EXT-MS-WIN-IMM-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-APPCOMPAT-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-DATETIME-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-ERRORHANDLING-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-FILE-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-LOCALIZATION-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-PACKAGE-CURRENT-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-PACKAGE-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-PACKAGE-L1-1-2.DLL
- EXT-MS-WIN-KERNEL32-QUIRKS-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-QUIRKS-L1-1-1.DLL
- EXT-MS-WIN-KERNEL32-REGISTRY-L1-1-0.DLL
- EXT-MS-WIN-KERNEL32-SIDEBYSIDE-L1-1-0.DLL
- EXT-MS-WIN-KERNELBASE-PROCESSTHREAD-L1-1-0.DLL
- EXT-MS-WIN-MININPUT-INPUTHOST-L1-1-0.DLL
- EXT-MS-WIN-MM-MSACM-L1-1-0.DLL
- EXT-MS-WIN-MM-PEHELPER-L1-1-0.DLL
- EXT-MS-WIN-MPR-MULTIPLEPROVIDERROUTER-L1-1-0.DLL
- EXT-MS-WIN-MRMCORER-RESMANAGER-L1-1-0.DLL
- EXT-MS-WIN-NETWORKING-WCMAPI-L1-1-0.DLL
- EXT-MS-WIN-NETWORKING-WLANAPI-L1-1-0.DLL
- EXT-MS-WIN-NETWORKING-WLANSTORAGE-L1-1-0.DLL
- EXT-MS-WIN-NEWDEV-CONFIG-L1-1-0.DLL
- EXT-MS-WIN-NTDSAPI-ACTIVEDIRECTORYCLIENT-L1-1-0.DLL
- EXT-MS-WIN-NTDSAPI-ACTIVEDIRECTORYCLIENT-L1-1-1.DLL
- EXT-MS-WIN-NTUSER-DC-ACCESS-EXT-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-DIALOGBOX-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-DRAW-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-DRAW-L1-1-1.DLL
- EXT-MS-WIN-NTUSER-DRAW-L1-1-2.DLL
- EXT-MS-WIN-NTUSER-GUI-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-KEYBOARD-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-MENU-L1-1-2.DLL
- EXT-MS-WIN-NTUSER-MESSAGE-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-MESSAGE-L1-1-1.DLL
- EXT-MS-WIN-NTUSER-MESSAGE-L1-1-2.DLL
- EXT-MS-WIN-NTUSER-MISC-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-MISC-L1-2-0.DLL
- EXT-MS-WIN-NTUSER-MISC-L1-5-0.DLL
- EXT-MS-WIN-NTUSER-MISC-L1-5-1.DLL
- EXT-MS-WIN-NTUSER-MOUSE-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-PRIVATE-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-PRIVATE-L1-1-1.DLL
- EXT-MS-WIN-NTUSER-PRIVATE-L1-2-0.DLL
- EXT-MS-WIN-NTUSER-PRIVATE-L1-3-1.DLL
- EXT-MS-WIN-NTUSER-PRIVATE-L1-3-2.DLL
- EXT-MS-WIN-NTUSER-PRIVATE-L1-3-3.DLL
- EXT-MS-WIN-NTUSER-RECTANGLE-EXT-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-ROTATIONMANAGER-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-SERVER-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-STRING-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-SYNCH-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-UICONTEXT-EXT-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-WINDOW-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-WINDOW-L1-1-1.DLL
- EXT-MS-WIN-NTUSER-WINDOW-L1-1-2.DLL
- EXT-MS-WIN-NTUSER-WINDOW-L1-1-3.DLL
- EXT-MS-WIN-NTUSER-WINDOWCLASS-L1-1-0.DLL
- EXT-MS-WIN-NTUSER-WINDOWSTATION-L1-1-0.DLL
- EXT-MS-WIN-ODBC-ODBC32-L1-1-0.DLL
- EXT-MS-WIN-OLE32-BINDCTX-L1-1-0.DLL
- EXT-MS-WIN-OLE32-IE-EXT-L1-1-0.DLL
- EXT-MS-WIN-OLE32-OLEAUTOMATION-L1-1-0.DLL
- EXT-MS-WIN-OLEACC-L1-1-1.DLL
- EXT-MS-WIN-PRINTER-PRNTVPT-L1-1-0.DLL
- EXT-MS-WIN-PROFILE-EXTENDER-L1-1-0.DLL
- EXT-MS-WIN-PROFILE-USERENV-L1-1-0.DLL
- EXT-MS-WIN-PROFILE-USERENV-L1-1-1.DLL
- EXT-MS-WIN-RAS-RASAPI32-L1-1-0.DLL
- EXT-MS-WIN-RAS-TAPI32-L1-1-1.DLL
- EXT-MS-WIN-RDR-DAVHLPR-L1-1-0.DLL
- EXT-MS-WIN-REINFO-QUERY-L1-1-0.DLL
- EXT-MS-WIN-RESOURCEMANAGER-CRM-L1-2-0.DLL
- EXT-MS-WIN-RESOURCES-DEPLOYMENT-L1-1-0.DLL
- EXT-MS-WIN-RESOURCES-LANGUAGEOVERLAY-L1-1-0.DLL
- EXT-MS-WIN-RESOURCES-LANGUAGEOVERLAY-L1-1-1.DLL
- EXT-MS-WIN-RO-TYPERESOLUTION-L1-1-0.DLL
- EXT-MS-WIN-RPC-SSL-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-GDI-DEVCAPS-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-GDI-OBJECT-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-GDI-RGN-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-GDI-RGN-L1-1-1.DLL
- EXT-MS-WIN-RTCORE-MINUSER-INPUT-L1-1-1.DLL
- EXT-MS-WIN-RTCORE-MINUSER-PRIVATE-EXT-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-CURSOR-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-DC-ACCESS-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-DPI-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-DPI-L1-2-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-DPI-L1-2-1.DLL
- EXT-MS-WIN-RTCORE-NTUSER-IAM-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-INTEGRATION-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-SYNCH-EXT-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-SYSCOLORS-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-SYSPARAMS-L1-1-0.DLL
- EXT-MS-WIN-RTCORE-NTUSER-WINDOW-EXT-L1-1-0.DLL
- EXT-MS-WIN-SECUR32-TRANSLATENAME-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-AUTHZ-HELPER-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-CAPAUTHZ-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-CAPAUTHZ-L1-1-1.DLL
- EXT-MS-WIN-SECURITY-CHAMBERS-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-CREDUI-INTERNAL-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-CREDUI-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-CREDUI-L1-1-1.DLL
- EXT-MS-WIN-SECURITY-CRYPTUI-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-CRYPTUI-L1-1-1.DLL
- EXT-MS-WIN-SECURITY-EFS-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-EFSWRT-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-EFSWRT-L1-1-1.DLL
- EXT-MS-WIN-SECURITY-NGC-LOCAL-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-WINSCARD-L1-1-0.DLL
- EXT-MS-WIN-SECURITY-WINSCARD-L1-1-1.DLL
- EXT-MS-WIN-SESSION-USERMGR-L1-1-0.DLL
- EXT-MS-WIN-SESSION-USERTOKEN-L1-1-0.DLL
- EXT-MS-WIN-SESSION-WINSTA-L1-1-0.DLL
- EXT-MS-WIN-SESSION-WTSAPI32-L1-1-0.DLL
- EXT-MS-WIN-SETUPAPI-CLASSINSTALLERS-L1-1-0.DLL
- EXT-MS-WIN-SETUPAPI-CLASSINSTALLERS-L1-1-1.DLL
- EXT-MS-WIN-SETUPAPI-CLASSINSTALLERS-L1-1-2.DLL
- EXT-MS-WIN-SETUPAPI-INF-L1-1-0.DLL
- EXT-MS-WIN-SETUPAPI-INF-L1-1-1.DLL
- EXT-MS-WIN-SHELL-DIRECTORY-L1-1-0.DLL
- EXT-MS-WIN-SHELL-EMBEDDEDMODE-L1-1-0.DLL
- EXT-MS-WIN-SHELL-SHELL32-L1-2-0.DLL
- EXT-MS-WIN-SHELL-SHLWAPI-L1-1-0.DLL
- EXT-MS-WIN-SHELL-TABBEDTITLEBAR-L1-1-0.DLL
- EXT-MS-WIN-SHELL32-SHELLCOM-L1-1-0.DLL
- EXT-MS-WIN-SHELL32-SHELLFOLDERS-L1-1-0.DLL
- EXT-MS-WIN-SMBSHARE-BROWSERCLIENT-L1-1-0.DLL
- EXT-MS-WIN-STORAGE-SENSE-L1-1-0.DLL
- EXT-MS-WIN-STORAGE-SENSE-L1-2-0.DLL
- EXT-MS-WIN-SXS-OLEAUTOMATION-L1-1-0.DLL
- EXT-MS-WIN-TSF-MSCTF-L1-1-0.DLL
- EXT-MS-WIN-TSF-MSCTF-L1-1-1.DLL
- EXT-MS-WIN-UI-VIEWMANAGEMENT-L1-1-0.DLL
- EXT-MS-WIN-WER-REPORTING-L1-1-0.DLL
- EXT-MS-WIN-WER-UI-L1-1-0.DLL
- EXT-MS-WIN-WER-XBOX-L1-1-0.DLL
- EXT-MS-WIN-WEVTAPI-EVENTLOG-L1-1-0.DLL
- EXT-MS-WIN-WINRT-DEVICE-ACCESS-L1-1-0.DLL
- EXT-MS-WIN-WINRT-STORAGE-L1-1-0.DLL
- EXT-MS-WIN-WLAN-ONEXUI-L1-1-0.DLL
- EXT-MS-WIN-WLAN-SCARD-L1-1-0.DLL
- EXT-MS-WIN-WWAN-WWAPI-L1-1-0.DLL
- EXT-MS-WIN-WWAN-WWAPI-L1-1-1.DLL
- EXT-MS-WINDOWSCORE-DEVICEINFO-L1-1-0.DLL
- HVSIFILETRUST.DLL
- IESHIMS.DLL
Hi @idfke, do you see any other logs in the console?
By the way, which Etcher installer variant did you use (portable one or installer)?
I see that couple of other users reported a similar problem here: https://github.com/balena-io/etcher/issues/3031
I wonder if you hit the same issue. The latest comment says that re-downloading the file fixed the issue. Could you try that yourself? (in case the file you have originally is corrupted for some reason)
I tried redownloading the file and tried a different iso and tried both the portable and the installed version, all of which still results in the same problem. I don’t see any more errors in the console. I get the following output:
Version = 1.5.109, Type = portable
gui.js:56225 Wed Sep 16 2020 14:18:44 GMT+0200 (Mitteleuropäische Sommerzeit) Application start ({“packageType”:“portable”,“version”:“1.5.109”,“sample”:0.1,“applicationSessionUuid”:“baa84550-32a5-454e-90c8-f976c0f748f4”,“flashingWorkflowUuid”:“aba203d9-e33e-4775-8827-5a7fbd95b3c4”})
gui.js:48927 Wed Sep 16 2020 14:18:48 GMT+0200 (Mitteleuropäische Sommerzeit) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“baa84550-32a5-454e-90c8-f976c0f748f4”,“flashingWorkflowUuid”:“aba203d9-e33e-4775-8827-5a7fbd95b3c4”})
gui.js:48927 Wed Sep 16 2020 14:18:50 GMT+0200 (Mitteleuropäische Sommerzeit) Select image ({“image”:{“size”:556793856,“name”:“HW-18.0.0_GA-Build379-379.iso”,“hasMBR”:true,“partitions”:[{“offset”:126976,“size”:2097152,“type”:239,“index”:1}],“extension”:“iso”,“path”:“C:\Users\no\Downloads\HW-18.0.0_GA-Build379-379.iso”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“baa84550-32a5-454e-90c8-f976c0f748f4”,“flashingWorkflowUuid”:“aba203d9-e33e-4775-8827-5a7fbd95b3c4”})
gui.js:48927 Wed Sep 16 2020 14:19:09 GMT+0200 (Mitteleuropäische Sommerzeit) Toggle drive ({“drive”:{“size”:7801405440,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“USB Disk 2.0 USB Device”,“isUAS”:false},“previouslySelected”:false,“sample”:0.1,“applicationSessionUuid”:“baa84550-32a5-454e-90c8-f976c0f748f4”,“flashingWorkflowUuid”:“aba203d9-e33e-4775-8827-5a7fbd95b3c4”})
gui.js:48927 Wed Sep 16 2020 14:19:10 GMT+0200 (Mitteleuropäische Sommerzeit) Flash ({“image”:{“size”:556793856,“name”:“HW-18.0.0_GA-Build379-379.iso”,“hasMBR”:true,“partitions”:[{“offset”:126976,“size”:2097152,“type”:239,“index”:1}],“extension”:“iso”,“path”:“C:\Users\no\Downloads\HW-18.0.0_GA-Build379-379.iso”},“drives”:[{“size”:7801405440,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“USB Disk 2.0 USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“e63d0a7e-0887-4811-84b2-a38ce4bdfe23”,“status”:“started”,“flashInstanceUuid”:“e63d0a7e-0887-4811-84b2-a38ce4bdfe23”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“sample”:0.1,“applicationSessionUuid”:“baa84550-32a5-454e-90c8-f976c0f748f4”,“flashingWorkflowUuid”:“aba203d9-e33e-4775-8827-5a7fbd95b3c4”})
gui.js:48927 Elevating command: C:\Users\no\AppData\Local\Temp\1hVR46FOVs1RGjCHJvmVdNi7ZrZ\balenaEtcher.exe C:\Users\no\AppData\Local\Temp\1hVR46FOVs1RGjCHJvmVdNi7ZrZ\resources\app\generated\child-writer.js
gui.js:6038 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:48927 Wed Sep 16 2020 14:19:11 GMT+0200 (Mitteleuropäische Sommerzeit) SafeWebview loaded ({“event”:{“id”:1,“url”:“https://www.balena.io/etcher/featured 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:[“*”],“age”:[“149”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“5d3a88ce7974d443-HAM”],“cf-request-id”:[“053873d50e0000d44399357200000001”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Wed, 16 Sep 2020 12:19:11 GMT”],“expect-ct”:[“max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct\”“],“expires”:[“Wed, 16 Sep 2020 00:31:51 GMT”],“last-modified”:[“Tue, 18 Aug 2020 09:51:57 GMT”],“server”:[“cloudflare”],“status”:[“200”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“3”],“x-fastly-request-id”:[“65fbfeea1322fb607434b04a1e7401232ede3847”],“x-github-request-id”:[“67D8:D891:493734:52F857:5F615A9F”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-fra19156-FRA”],“x-timer”:[“S1600258752.790786,VS0,VE0”]},“referrer”:”",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“baa84550-32a5-454e-90c8-f976c0f748f4”,“flashingWorkflowUuid”:“aba203d9-e33e-4775-8827-5a7fbd95b3c4”})
gui.js:48927 Successfully connected to IPC server: etcher-server-18036, socket root C:\Users\no\AppData\Local\Temp
gui.js:48927 Image: C:\Users\no\Downloads\HW-18.0.0_GA-Build379-379.iso
gui.js:48927 Devices: \.\PhysicalDrive1
gui.js:48927 Umount on success: true
gui.js:48927 Validate on success: true
gui.js:48927 Auto blockmapping: true
gui.js:48927 Decompress first: true
Just a thought, but do you by any chance have Chrome Remote Desktop installed on your Windows 10 machine? It has a way of distorting permissions that can prevent balenaEtcher from working properly. If so, try uninstalling CRD, rebooting and trying again.
John
I don’t have CRD installed.
Hello there,
The amount of missing dependencies is indeed too long, which may also explain the lack of reaction from diskpart and rufus.
Have you tried minimizing this list already?
- If yes, how does it look now?
- If no, you don’t have to tackle them one by one, check for and Install Windows Updates usually retrieves the missing DLLs
I can also suggest you to try to flash this image using another Machine if at all available to you
Updated my Windows and now I’m apparently missing 25 additional DLL-dependancies. I’ve also tried running both versions on another machine and im running into the same Problem there.
Hello, are you able to install any of the missing DDLs? Since the list is now shorter it might be possible to look for the ones that are missing and try to instal them?
I mean the list is longer than before but sure i could go looking for the now 587 missing DLLs I’m just not really sure how or where to find them.
Hi, I looked for some of the dependencies in the list and I could find this post in Microsoft’s forums Missing api-ms-win-core-* DLLs which suggests that a major upgrade should give the system the missing DLLs:
The only supported way to get those DLLs is to do a major Windows upgrade (e.g. from Windows 7 to Windows 10).
I see you’re already on Windows 10, so if you don’t see any major upgrades available I wouldn’t know how to proceed. (e.g. May 2020’s update was the latest iirc but I’m not sure about it being a “major” update)
Regardless, it’s best that you seek for more information on Microsoft’s forums because it’s really weird that diskpart doesn’t work and we can’t do much unfortunately
how to fix the missing file ext-ms-win-wwan-wwapi-l1-1-0.dll would that help to download and instal it once again?
ext-ms-win-wwan-wwapi-l1-1-0.dll is part of Windows. Your Windows installation is probably damaged.
