Error(0,h.requestMetadata) is not a function
Just trying to create flash from iso.
What should be done?
Today I think that *.iso is bad, as if I use UUI to create a boot-flash, then I get the same kind of error during flash usage.
вс, 18 авг. 2024 г. в 10:17, mrfoxesite via balenaForums <notifications@balena.discoursemail.com>:
That’s what I did :slight_smile:
вс, 18 авг. 2024 г. в 11:00, mrfoxesite via balenaForums <notifications@balena.discoursemail.com>:
Can confirm that this exact thing happens to me on the latest windows 11 version when trying to flash. I tried several different linux distro isos but they are all the same things.
Me too. Trying to flash the latest Ubuntu version, from Windows 11. It must be the Windows platform.
Had the same issue.
Closed balenaEtcher, rerun but as Administrator this time and voila…
Doesn’t work - administrator, compatabilty mode etc… just doesn’t work … Hey Balenda morons what a joke this issue is arround since August - it is October - no fix ? What a garbage soft with garbage support - Hey morrons at Ubuntu this is exactly why your os is not for on the level with normal software produced by normal software companies… write better instructions with the tools that work atleast and not some junk like this baldalenda
It does work on Win 11 Home and Win 11 Pro but it’s flaky - I’ve had that error message too. Rebooted, and in one case where that didn’t work, reinstalled the balenaEtcher software. Was then able to create the .iso boot USB. Strange.
You literally need to give it administrator rights thanks for the answer
same thing happened to me as well opened the app in administration and it worked like magic.
Thank you guys @WesMax
I got the same error using balenaEtcher-1.19.25-x64.AppImage with Linux. Going back to balenaEtcher-1.18.11-x64.AppImage solved the problem for me.
Just dropping this note for users not running Windows…
This worked for me on Windows 10!
Had same issue when trying to Flash a Windows 11 bootable image onto an SD Card With my Linux based Steam Deck running on Steam OS wouldnt work with the newer V1.19.25 but i see someone had similar issues with a linux based system and said just using V1.18.11 sorted there issue and allowed them to Flash there Bootable or what ever and it worked for me so i recommend trying the older version.
First, my thanks to the balena folks for trying to provide this bootmanager. I’m guessing it is a lot harder to make a bootmanager for linux work properly with Windows than it used to.
Working from a Win10 machine I downloaded Etcher and directed it toward a Linux Mint 22 ISO I had already downloaded. It runs for a while and then says:
ā€œError opening source
Something went wrong while opening
C:\Users…\linuxmint-22-cinnamon-64bit.iso.
Error:(0 , h.requestMetadata) is not a function.ā€
LinuxMint specifically directs me to use Etcher, probably because of the UEFI and other hurtles, to try to install on a new Windows 11 machine.
I Do have Admin permission on this machine (though not specifically in the Admin acct…don’t even think I have that password). I have tried TWO different ISOs of this Mint with etcher I downloaded from your site today.
Obviously this is hitting a fair number of people, so it would be nice if the balena staff would kick this up a notch and provide a real fix or, if that is too difficult, at least a better (more helpful) crash/error message?
Just had this. Win 10, run as administrator, full control and bang. Long story short, stick the ISO in your downloads folder and then it works. Anyplace else and no.
Then I got this…
There’s a sneaky windows perms pop up that you might miss and you need to confirm your actions otherwise you get the error.
I get the same error on Kubuntu 24.10 running the etcher 1.19.25 AppImage.
Running with sudo --no-sandbox gives a white window with no content.
Using the .deb or the zip file of etcher 1.19.25 also does not work.
balenaEtcher-1.18.11-x64.AppImage works fine.
I was getting this and admin control wasn’t working so I tried win8 compat mode and it worked. Weird
Having same issue with balenaEtcher-2.1.0-x64.AppImage version on Mint 21.3.
Tested agains many .ISO with no difference.
sudo launch complains with: FATAL:electron_main_delegate.cc(295)] Running as root without --no-sandbox is not supported.
Version balenaEtcher-1.18.11-x64.AppImage runs fine.
I will keep v.1.18-11 and wait for new version to test.
I got this error today after downloading the latest Mac version of Etcher, when trying to use an ISO for Pop_OS! named ā€œpop-os_22.04_amd64_intel_52.isoā€. I renamed the file to just popos.iso and it worked, and flashed successfully. No admin rights changes, nothing else.
Same issue here. with newest version 2.1.0 and Fedora Linux 41. Then, I use .rpm file instead and got problem solved.
