I build balenaOS from the source and the following raw file successfully generated.
./build/tmp/deploy/images/raspberrypi3/resin-image-raspberrypi3-20200401154938.rootfs.resinos-img
I tried to flash the image to an SD card with Etcher but it seems resinos-img type is not supported.
I can use Etcher if I rename it .img but I wonder if I am missing something? Does Etcher support resinos-img file type?
Murat
