I downloaded latest version of portable etcher today and when i open it with or without admin privileges it doesn’t load the gui.
It looks like this:
Thanks for help.
Hi there!
sorry to hear about that, are you trying with v1.5.95 or v1.5.96?
thanks!
It’s 1.5.96
Hi, thanks for that!
Would you mind trying with an older version (like v1.5.81 ) and let us know if it works out? you can find them here: https://github.com/balena-io/etcher/releases
If it works, maybe is the installer broken for some reason.
Portable 1.5.86 works for me.
Thanks for letting us know. We’re working a bug that iimpacts Windows10.
John
Can you tell use what you see from the Electron console (CTRL + SHIFT +i) and tell us which version of Windows you’re using (32 or 64 bits)?
John
My windows is 64bit with the may update and here’s the console log:
electron/js2c/asar.js:140 Uncaught Error: \\?\C:\Users\Luky\AppData\Local\Temp\1coF7Rq7zj1JWCpwfW1DkllrGCO\resources\app\generated\modules\lzma-native\binding-v6.0.1-n-api-win32-ia32\lzma_native.node is not a valid Win32 application.
at process.func (electron/js2c/asar.js:140)
at process.func [as dlopen] (electron/js2c/asar.js:140)
at Object.Module._extensions..node (internal/modules/cjs/loader.js:1034)
at Object.func (electron/js2c/asar.js:140)
at Object.func [as .node] (electron/js2c/asar.js:140)
at Module.load (internal/modules/cjs/loader.js:815)
at Module._load (internal/modules/cjs/loader.js:727)
at Module._load (electron/js2c/asar.js:738)
at Function.Module._load (electron/js2c/asar.js:738)
at Module.require (internal/modules/cjs/loader.js:852)
at require (internal/modules/cjs/helpers.js:74)
at Object.<anonymous> (gui.js:98210)
at __webpack_require__ (gui.js:16)
at gui.js:97784
at Object.<anonymous> (gui.js:98207)
at Object.<anonymous> (gui.js:98208)
