after updating my BalenaOS to 2.80.8 it seems liked everything worked well. except dat after 40 minutes the RP (zero) goes offline en I have to physically disconnect the power to reboot it.
bluetooth still works but I can not connect via any other way
I updated the firmware because I had the following issues:
Airplay didn’t work well (stuttering)
Spotify connect the same
and this weird error:
2021-08-09 14-50-11 [Error] (worker) Exception in Controller::worker(): connect: Connection refused
09.08.21 16:50:11 (+0200) snapcast-client 2021-08-09 14-50-11 [Error] (stop) Error in socket shutdown: Socket not connected
every second.
after updating:
loses connection after like 40 minute
I can’t discover the RPI via bluetooth on new devices (which is OK to me)
Airplay works great when connected
Spotify connect still stutters
Still that snap cast client error
When trying to reach the RPI via terminal I get the following error:
dockerInfo: Could not get Docker info
dockerVersion: Could not get Docker version
a lot of issues, haha. hopefully you can help me. Thanks!
