You need a whole USB flash drive to install the system disk? * I think it is ok to use only one partition of usb drive to install
what should I do
Hi
Can you tell us what you are trying to do here? Are you flashing the TU100Pro drive with some OS?
I want to have a Kali Linux on my USB drive and space to store some other files
- The ideal state is F disk for the system and G disk for the other files
Etcher currently does not support flashing individual partitions.
What you could do is use the SDK directly: GitHub - balena-io-modules/etcher-sdk
to write to the partition with:
ts-node ./examples/multi-destination.ts [source file] [partition location]
I’m not actually sure how this will work on windows though, because I’m not sure how to write to an individual partition as a block device, so this might take some time to get it to work.
This is planned for a future release of etcher though, so it will eventually be implemented.
