Hello @bumblebee55 , it looks like the child process that should be writing the image segfaults on your computer.
Could you please try installing etcher (not the portable version) and running the following in a cmd and paste the output here:
set ELECTRON_RUN_AS_NODE=1
C:\Users\user\AppData\Local\Programs\balena-etcher\balenaEtcher C:\Users\user\AppData\Local\Programs\balena-etcher\balenaEtcher\resources\app\generated\child-writer.js
Hi @bumblebee55, did you run Etcher as administrator as @zvin suggested? Did you set the UAC level to the minimum? Just double-checking that those are the logs / errors you get after those potential workarounds
@glayson Have you also tried running as Administrator, similar to the advice offered by Juan above? Your log indicates the child process exits with 3221225477, and some Googling of that leads to discussions about OpenGL and the need to update graphics drivers. What type of a laptop or desktop PC is this you are using?
when i check if there is a recent update i am informed of only one and i have already done this update, some error happens because i am always informed of the same update always
Detailed Description
Purpose
This download installs the System-on-a-Chip (SoC) drivers for Intel® Compute Stick STK1AW32SC, for the following system devices:
Are you by any chance running Chrome Remote Desktop on your Windows 7 machine? It’s known to cause some permission issues, even when running balenaEtcher (and other apps) as Administrator.
Your latest log shows the error code 3221225477 (0xc0000005). This code usually means that your filesystem is corrupted. Could you run the filesystem checker on the usb device? It should help to figure out if the device is damaged.
This guide from Microsoft shows how to do it on Windows 7: https://support.microsoft.com/en-us/help/2641432/check-your-hard-disk-for-errors-in-windows-7
