My Etcher claims 1.5.5
My etcher claims to be Version 1.5.5…
is that why it does not work? starts writing an img, but ends as quick as starting.
Any suggestions??
Running Windows 10 pro latest build.
I use the installed version.
some time ago it did work quite well with my first octopi server on an older raspi…
Hey @Jay0Hunter welcome to the forums.
Please could you try using the latest version of Etcher which you can always find on our site at https://www.balena.io/etcher or on GitHub at https://github.com/balena-io/etcher/releases/latest
At the time of writing this is v1.5.33.
Although, you could also try running the version you have with administrative privileges - right click on the icon and click ‘Run as administrator’.
Let us know how this goes.
Thank you for your immediate reply.
That is the latest download directly from the balenaEtcher Site.
I am also surprised, because anywhere you look highest version seems to be 1.5.33.
Did not know i can download from the future! :wink:
Ahh I see what you mean! v1.5.5 is an older version released on 28th February, v1.5.33 is the latest, released only a couple of days ago. Don’t think of the version number as a decimal number but instead that each of the three numbers can increment on their own in MAJOR.MINOR.PATCH format. You can see (and download) all of the releases here: https://github.com/balena-io/etcher/tags
That being said, I’ve just downloaded the version for Windows from the main site and it gave me v1.5.33 so I am not sure how you obtained such an old version.
Fancy! Found that new one on the repository.
Thank you for your immediate help -
sadly it did not work out - still get that drop out after some seconds.
Will stay after that. but now its bed time. Good night!
You’re welcome! On Windows you can use CTRL - SHIFT - I to access the developer console and see any error messages in the log in more detail. If there are any errors here feel free to post them so we can investigate further.
I also have this problem, using Etcher version 1.5.33 downloaded directly via Firefox, on win 10, version 1803, build 17134.407. This was after multiple failures other methods where Etcher wouldn’t write to the USB (16GB Kingston Data Traveler G4). So now I’m looking for a post I read which said a user with the same problem succeeded using Etcher version 1.2 which I’ve just downloaded using the URL from chrisys. I’ll let you all Know if I’m successful.
hey, thanks for the report! For Etcher 1.5.33, when you have the flash failure, what happens there exactly? Can you also see if the debug console has any information / errors listed? You can get there by pressing Ctrl+Shift+I when Etcher is open.
Also opened an issue on the Etcher issue tracker, feel free to add any extra information if you have:
Hey there!
Thank you for that much interest in this topic - i’m truely impressed of that much response!
Actually I found a WoA (WorkAround) that solved the problem of not getting the image onto the MicroSD.
What i did:
I remebered the last time(with the same source of BalenaEtcher, i did the flashing on my laptop.
this time i tried to do it with my desktop - and got stuck with the issue named in the topic.
First i downloaded the latest release of Etcher, second i did a new Windows ADMIN account (the actual WoA) and ran that new installation on the virgin account.
That worked out like a charme!
Can’t remember when, but i already had some similar issue with other software also.
Haven’t checked the reports after got the image flashed,
would you mind closing this topic?
THANKS AGAIN TO ALL PARTICIPANTS! :slight_smile: :thumbsup:
@imrehg:
try to accuire these information you ask for the next days.
Thank you for sharing your workaround.
We fixed a similar issue in the latest version(s), but it happened on Linux iirc.
Please let us know when you check the console so we can debug further!
Etcher version: v1.5.33
Operating system and architecture: Windows 10
Image flashed: octopi-stretch-lite-0.16.0.zip
Do you see any meaningful error information in the DevTools? ?
User report…not sure what you mean
I try to post any suggestions where i could find helpful information for you!
EDIT:
You ask for the console:
|  ___| |     | |
| |__ | |_ ___| |__   ___ _ __
|  __|| __/ __| '_ \ / _ \ '__|
| |___| || (__| | | |  __/ |
\____/ \__\___|_| |_|\___|_|
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.5.33, Type = nsis
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:08:57 GMT+0200 (Mitteleuropäische Sommerzeit) Application start ({"packageType":"nsis","version":"1.5.33","applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:08:58 GMT+0200 (Mitteleuropäische Sommerzeit) SafeWebview loaded ({"event":{"fromCache":false,"headers":{"Accept":"text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8","Upgrade-Insecure-Requests":"1","User-Agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) balena-etcher/1.5.33 Chrome/69.0.3497.128 Electron/4.1.5 Safari/537.36"},"id":10,"method":"GET","referrer":"","resourceType":"mainFrame","responseHeaders":{"Accept-Ranges":["bytes"],"Cache-Control":["public, max-age=0"],"Connection":["keep-alive"],"Content-Encoding":["gzip"],"Content-Type":["text/html; charset=UTF-8"],"Date":["Mon, 06 May 2019 19:08:54 GMT"],"Etag":["W/\"3a720-16a8dd0e618\""],"Last-Modified":["Mon, 06 May 2019 15:43:59 GMT"],"Server":["Cowboy"],"Transfer-Encoding":["chunked"],"Vary":["Accept-Encoding"],"Via":["1.1 vegur, 1.1 vegur"]},"statusCode":200,"statusLine":"HTTP/1.1 200 OK","timestamp":1557169738717.266,"url":"https://www.balena.io/etcher/success-banner/?etcher-version=1.5.33&api-version=2&optOutAnalytics=false"},"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:12 GMT+0200 (Mitteleuropäische Sommerzeit) Open image selector ({"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:16 GMT+0200 (Mitteleuropäische Sommerzeit) Select image ({"image":{"size":2187330560,"compressedSize":589653270,"logo":false,"name":"2018-11-13-octopi-stretch-lite-0.16.0.img","hasMBR":true,"partitions":[{"offset":4194304,"size":46005248,"type":12,"index":1},{"offset":50331648,"size":2136998912,"type":131,"index":2}],"path":"S:\\Patric Jaeger\\Downloads\\__Tronxy X5 Printer\\OctoPie\\octopi-stretch-lite-0.16.0.zip","extension":"zip","blockMap":false},"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:17 GMT+0200 (Mitteleuropäische Sommerzeit) Flashing 0 devices, 0% at null MB/s (total null MB/s) eta in undefineds with 0 failed devices
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:17 GMT+0200 (Mitteleuropäische Sommerzeit) Flash ({"image":"S:\\Patric Jaeger\\Downloads\\__Tronxy X5 Printer\\OctoPie\\octopi-stretch-lite-0.16.0.zip","drives":[{"size":15560867840,"isVirtual":false,"enumerator":"USBSTOR","logicalBlockSize":512,"raw":"\\\\.\\PhysicalDrive5","error":null,"isReadOnly":false,"displayName":"G:\\","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"\\\\.\\PhysicalDrive5","busVersion":"2.0","isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":null,"mountpoints":[{"path":"G:\\"}],"description":"Generic STORAGE DEVICE USB Device","isUAS":false}],"driveCount":1,"uuid":"f648adfd-e8fb-4724-9cf2-d11c70a41d6b","status":"started","flashInstanceUuid":"f648adfd-e8fb-4724-9cf2-d11c70a41d6b","unmountOnSuccess":true,"validateWriteOnSuccess":true,"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Elevating command: C:\Users\Patric\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:18 GMT+0200 (Mitteleuropäische Sommerzeit) SafeWebview loaded ({"event":{"fromCache":false,"headers":{"Accept":"text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8","Upgrade-Insecure-Requests":"1","User-Agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) balena-etcher/1.5.33 Chrome/69.0.3497.128 Electron/4.1.5 Safari/537.36"},"id":46,"method":"GET","referrer":"","resourceType":"mainFrame","responseHeaders":{"access-control-allow-origin":["*"],"age":["367"],"cache-control":["max-age=600"],"cf-ray":["4d2d3f586f809abc-FRA"],"content-encoding":["br"],"content-type":["text/html; charset=utf-8"],"date":["Mon, 06 May 2019 19:09:14 GMT"],"expect-ct":["max-age=604800, report-uri=\"https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct\""],"expires":["Mon, 06 May 2019 10:48:22 GMT"],"last-modified":["Mon, 06 May 2019 10:37:58 GMT"],"server":["cloudflare"],"status":["200"],"vary":["Accept-Encoding"],"via":["1.1 varnish"],"x-cache":["HIT"],"x-cache-hits":["1"],"x-fastly-request-id":["481a173f9494b865e89de6e250b542f3448e2c93"],"x-github-request-id":["A0CC:2C79:3DFCD5:51A28E:5CD00E9F"],"x-served-by":["cache-hhn1542-HHN"],"x-timer":["S1557169755.950485,VS0,VE1"]},"statusCode":200,"statusLine":"HTTP/1.1 200","timestamp":1557169758582.8928,"url":"https://assets.balena.io/etcher-featured/index.html?etcher-version=1.5.33&api-version=2&optOutAnalytics=false"},"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:18 GMT+0200 (Mitteleuropäische Sommerzeit) Flashing 0 devices, 0% at null MB/s (total null MB/s) eta in undefineds with 0 failed devices
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Successfully connected to IPC server: etcher-server-10316, socket root S:\Patric Jaeger\AppData\Local\Temp\
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Image: S:\Patric Jaeger\Downloads\__Tronxy X5 Printer\OctoPie\octopi-stretch-lite-0.16.0.zip
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Devices: \\.\PhysicalDrive5
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Umount on success: true
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Validate on success: true
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:32 GMT+0200 (Mitteleuropäische Sommerzeit) Flash error ({"error":{"name":"Error","message":"Couldn't clean the drive, Command failed: diskpart s Patric Jaeger\\AppData\\Local\\Temp\\298a654ee8fb.tmp\n (code 2147942487)","stack":"Error: Couldn't clean the drive, Command failed: diskpart s Patric Jaeger\\AppData\\Local\\Temp\\298a654ee8fb.tmp\n (code 2147942487)\n    at Object.<anonymous> (C:\\Users\\Patric\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\etcher-sdk\\build\\diskpart.js:92:23)\n    at Generator.throw (<anonymous>)\n    at rejected (C:\\Users\\Patric\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\etcher-sdk\\build\\diskpart.js:20:65)"},"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","flashInstanceUuid":"f648adfd-e8fb-4724-9cf2-d11c70a41d6b","image":"S:\\Patric Jaeger\\Downloads\\__Tronxy X5 Printer\\OctoPie\\octopi-stretch-lite-0.16.0.zip","drives":[{"size":15560867840,"isVirtual":false,"enumerator":"USBSTOR","logicalBlockSize":512,"raw":"\\\\.\\PhysicalDrive5","error":null,"isReadOnly":false,"displayName":"G:\\","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"\\\\.\\PhysicalDrive5","busVersion":"2.0","isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":null,"mountpoints":[{"path":"G:\\"}],"description":"Generic STORAGE DEVICE USB Device","isUAS":false}],"driveCount":1,"uuid":"f648adfd-e8fb-4724-9cf2-d11c70a41d6b","unmountOnSuccess":true,"validateWriteOnSuccess":true,"sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Finish: 0
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Flash results Object
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Terminating IPC server
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:32 GMT+0200 (Mitteleuropäische Sommerzeit) Open modal ({"name":"warning","applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:38 GMT+0200 (Mitteleuropäische Sommerzeit) Modal accepted ({"name":"warning","value":false,"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:40 GMT+0200 (Mitteleuropäische Sommerzeit) Navigate ({"to":"settings","from":"main","applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:45 GMT+0200 (Mitteleuropäische Sommerzeit) Toggle setting ({"setting":"errorReporting","value":false,"dangerous":false,"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:46 GMT+0200 (Mitteleuropäische Sommerzeit) Toggle setting ({"setting":"errorReporting","value":true,"dangerous":false,"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:47 GMT+0200 (Mitteleuropäische Sommerzeit) Navigate ({"to":"main","from":"settings","applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:52 GMT+0200 (Mitteleuropäische Sommerzeit) Open external link ({"url":"https://github.com/resin-io/etcher/blob/master/SUPPORT.md","applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:09:56 GMT+0200 (Mitteleuropäische Sommerzeit) Open external link ({"url":"https://github.com/balena-io/etcher/blob/master/CHANGELOG.md","applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:12:20 GMT+0200 (Mitteleuropäische Sommerzeit) Open image selector ({"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:12:25 GMT+0200 (Mitteleuropäische Sommerzeit) Select image ({"image":{"size":2187330560,"compressedSize":589653270,"logo":false,"name":"2018-11-13-octopi-stretch-lite-0.16.0.img","hasMBR":true,"partitions":[{"offset":4194304,"size":46005248,"type":12,"index":1},{"offset":50331648,"size":2136998912,"type":131,"index":2}],"path":"S:\\Patric Jaeger\\Downloads\\__Tronxy X5 Printer\\OctoPie\\octopi-stretch-lite-0.16.0.zip","extension":"zip","blockMap":false},"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:12:27 GMT+0200 (Mitteleuropäische Sommerzeit) Open modal ({"name":"drive-selector","applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:12:31 GMT+0200 (Mitteleuropäische Sommerzeit) Toggle drive ({"drive":{"size":15560867840,"isVirtual":false,"enumerator":"USBSTOR","logicalBlockSize":512,"raw":"\\\\.\\PhysicalDrive5","error":null,"isReadOnly":false,"displayName":"G:\\","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"\\\\.\\PhysicalDrive5","busVersion":"2.0","isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":null,"mountpoints":[{"path":"G:\\"}],"description":"Generic STORAGE DEVICE USB Device","isUAS":false},"previouslySelected":false,"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:12:33 GMT+0200 (Mitteleuropäische Sommerzeit) Modal accepted ({"name":"drive-selector","applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:12:56 GMT+0200 (Mitteleuropäische Sommerzeit) Flashing 0 devices, 0% at null MB/s (total null MB/s) eta in undefineds with 0 failed devices
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:12:56 GMT+0200 (Mitteleuropäische Sommerzeit) Flash ({"image":"S:\\Patric Jaeger\\Downloads\\__Tronxy X5 Printer\\OctoPie\\octopi-stretch-lite-0.16.0.zip","drives":[{"size":15560867840,"isVirtual":false,"enumerator":"USBSTOR","logicalBlockSize":512,"raw":"\\\\.\\PhysicalDrive5","error":null,"isReadOnly":false,"displayName":"G:\\","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"\\\\.\\PhysicalDrive5","busVersion":"2.0","isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":null,"mountpoints":[{"path":"G:\\"}],"description":"Generic STORAGE DEVICE USB Device","isUAS":false}],"driveCount":1,"uuid":"9105d469-a054-42c1-b7eb-61ff32799069","status":"started","flashInstanceUuid":"9105d469-a054-42c1-b7eb-61ff32799069","unmountOnSuccess":true,"validateWriteOnSuccess":true,"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:12:56 GMT+0200 (Mitteleuropäische Sommerzeit) SafeWebview loaded ({"event":{"fromCache":false,"headers":{"Accept":"text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8","Upgrade-Insecure-Requests":"1","User-Agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) balena-etcher/1.5.33 Chrome/69.0.3497.128 Electron/4.1.5 Safari/537.36"},"id":218,"method":"GET","referrer":"","resourceType":"mainFrame","responseHeaders":{"access-control-allow-origin":["*"],"age":["585"],"cache-control":["max-age=600"],"cf-ray":["4d2d44abcdca9abc-FRA"],"content-encoding":["br"],"content-type":["text/html; charset=utf-8"],"date":["Mon, 06 May 2019 19:12:53 GMT"],"expect-ct":["max-age=604800, report-uri=\"https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct\""],"expires":["Mon, 06 May 2019 10:48:22 GMT"],"last-modified":["Mon, 06 May 2019 10:37:58 GMT"],"server":["cloudflare"],"status":["200"],"vary":["Accept-Encoding"],"via":["1.1 varnish"],"x-cache":["HIT"],"x-cache-hits":["3"],"x-fastly-request-id":["e9ed4dec089045ed8d9d7ae8794710ba0ba08015"],"x-github-request-id":["A0CC:2C79:3DFCD5:51A28E:5CD00E9F"],"x-served-by":["cache-hhn1520-HHN"],"x-timer":["S1557169973.093452,VS0,VE0"]},"statusCode":200,"statusLine":"HTTP/1.1 200","timestamp":1557169976739.9312,"url":"https://assets.balena.io/etcher-featured/index.html?etcher-version=1.5.33&api-version=2&optOutAnalytics=false"},"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:13:10 GMT+0200 (Mitteleuropäische Sommerzeit) Flash error ({"error":{"name":"Error","message":"Couldn't clean the drive, Command failed: diskpart s Patric Jaeger\\AppData\\Local\\Temp\\fa0d590724d4.tmp\n (code 2147942487)","stack":"Error: Couldn't clean the drive, Command failed: diskpart s Patric Jaeger\\AppData\\Local\\Temp\\fa0d590724d4.tmp\n (code 2147942487)\n    at Object.<anonymous> (C:\\Users\\Patric\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\etcher-sdk\\build\\diskpart.js:92:23)\n    at Generator.throw (<anonymous>)\n    at rejected (C:\\Users\\Patric\\AppData\\Local\\Programs\\balena-etcher\\resources\\app.asar\\node_modules\\etcher-sdk\\build\\diskpart.js:20:65)"},"applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","flashInstanceUuid":"9105d469-a054-42c1-b7eb-61ff32799069","image":"S:\\Patric Jaeger\\Downloads\\__Tronxy X5 Printer\\OctoPie\\octopi-stretch-lite-0.16.0.zip","drives":[{"size":15560867840,"isVirtual":false,"enumerator":"USBSTOR","logicalBlockSize":512,"raw":"\\\\.\\PhysicalDrive5","error":null,"isReadOnly":false,"displayName":"G:\\","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"\\\\.\\PhysicalDrive5","busVersion":"2.0","isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":null,"mountpoints":[{"path":"G:\\"}],"description":"Generic STORAGE DEVICE USB Device","isUAS":false}],"driveCount":1,"uuid":"9105d469-a054-42c1-b7eb-61ff32799069","unmountOnSuccess":true,"validateWriteOnSuccess":true,"sample":0.1})
C:\Users\Patric\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Mon May 06 2019 21:13:10 GMT+0200 (Mitteleuropäische Sommerzeit) Open modal ({"name":"warning","applicationSessionUuid":"5756705c-dc03-4f98-8dbc-71eabaac5297","flashingWorkflowUuid":"073546cd-3759-46b0-a7c2-5e42c1aabd13","sample":0.1})
Hope the last post helps!
Hi @Jay0Hunter
Thanks for the extra details.
Will investigate this and get back to you.
Hello, could you please try Etcher 1.5.34 ?
@├zvin
I jumped over 1.5.34 and retested 1.5.39 (at least this is shown in the lower right etcher corner)
and it seems everything works like a charme, even without changing to an account with virgin user! :smiley::+1::+1:
You and your team do an outstanding job!!!
THANK YOU!
