Write error to USB (MacOS)
I used balenaEtcher last year to flash this image to SDcard (USB): ev3-micropython-v2.0.0-sd-card-image.img. It worked well. Trying to reinstall new version this year now I get the attached error message: “Something went wrong. If it is a compressed image, please check that the archive is not corrupted…retry.” I’m now using v1.4.45.
I’m now using v1.5.45.
Hi, can you tell us if there are any logs in dev console? You can open it with CTRL - SHIFT - I
I got the same problem with macOS 10.15.6. while trying to write ubuntu iso (downloaded again)
Etcher has full disk access (security settings )
Log
Thu Aug 20 2020 20:41:54 GMT+0200 (Mitteleuropäische Sommerzeit) Write failed ({“image”:"/Users/andre/Downloads/ubuntu-20.04.1-desktop-amd64.iso",“drives”:[{“size”:64023257088,“isVirtual”:false,“enumerator”:“DiskArbitration”,“logicalBlockSize”:512,“raw”:"/dev/rdisk2",“error”:null,“isReadOnly”:false,“displayName”:"/dev/disk2",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"/dev/disk2",“busVersion”:null,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:“IODeviceTree:/PCI0@0/XHC1@14”,“mountpoints”:[{“path”:"/Volumes/UNTITLED",“label”:“UNTITLED”}],“description”:“SanDisk Extreme Media”,“isUAS”:null}],“driveCount”:1,“uuid”:“6af3c268-63fc-43d3-a378-a9d2dec478af”,“status”:“failed”,“flashInstanceUuid”:“6af3c268-63fc-43d3-a378-a9d2dec478af”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“description”:“Please try again, and contact the Etcher team if the problem persists”,“report”:false},“sample”:0.1,“applicationSessionUuid”:“69bae34a-d0f2-4559-a5ad-97b8fe7add72”,“flashingWorkflowUuid”:“7a36fae0-51c7-4e38-9f91-e6776d8e97e4”})
gui.js:48791 {“stack”:“Error: The writer process ended unexpectedly\n at createError (file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js:62964:23)\n at createUserError (file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js:62975:16)\n at Server. (file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js:79641:28)”,“message”:“The writer process ended unexpectedly”,“description”:“Please try again, and contact the Etcher team if the problem persists”,“report”:false,“image”:“ubuntu-20.04.1-desktop-amd64.iso”}
console. @ gui.js:48791
gui.js:5626 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
Hi, please could you let me know what version of Etcher you are using?
Phil
Hi, its Version 1.5.103, download yesterday.
The solution is to disable SIP. Afterwards it worked without any problems.
Great! Thanks for letting us know.
Here’s the error I get:
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 {“stack”:“Error: EPERM: operation not permitted, open ‘/Users/josephmccormick/Desktop/Education/Engineering/EV3/ev3dev-stretch-ev3-generic-2020-04-10.img.zip’”,“message”:“EPERM: operation not permitted, open ‘/Users/josephmccormick/Desktop/Education/Engineering/EV3/ev3dev-stretch-ev3-generic-2020-04-10.img.zip’”,“name”:“Error”,“code”:“EPERM”,“syscall”:“open”,“errno”:-1,“image”:“ev3dev-stretch-ev3-generic-2020-04-10.img.zip”}
console.(anonymous function) @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58
logException @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/resin-corvus/src/resin-corvus.js:233
flashImageToDrive @ gui.js:8755
_tickCallback @ internal/process/next_tick.js:68
async function (async)
flashImageToDrive @ gui.js:8683
callCallback @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:149
wrapped @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:444
invokeGuardedCallbackDev @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:199
invokeGuardedCallback @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:256
invokeGuardedCallbackAndCatchFirstError @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:270
executeDispatch @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:561
executeDispatchesInOrder @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:583
executeDispatchesAndRelease @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:680
executeDispatchesAndReleaseTopLevel @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:688
forEachAccumulated @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:662
runEventsInBatch @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:816
runExtractedEventsInBatch @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:824
handleTopLevel @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:4822
batchedUpdates$1 @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:19904
batchedUpdates @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:2150
dispatchEvent @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:4901
interactiveUpdates$1 @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:19959
interactiveUpdates @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:2169
dispatchInteractiveEvent @ /Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:4878
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Flash results {cancelled: false}
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Terminating IPC server
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Mon Aug 24 2020 09:32:37 GMT+0800 (CST) Modal accepted ({“name”:“warning”,“value”:true,“applicationSessionUuid”:“45ae1c11-12d6-450a-9c7d-50b12442323f”,“flashingWorkflowUuid”:“6414dcfa-f50f-4800-be72-743f7d8fb3f9”,“sample”:0.1})
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Mon Aug 24 2020 09:32:37 GMT+0800 (CST) Restart after failure ({“applicationSessionUuid”:“45ae1c11-12d6-450a-9c7d-50b12442323f”,“flashingWorkflowUuid”:“6414dcfa-f50f-4800-be72-743f7d8fb3f9”,“sample”:0.1})
Thanks for your help!
…also I’m using macOS 10.15.5
Hi @jfrancismccormick,
the problem you mentioned seems to be related to this issue: https://github.com/balena-io/etcher/issues/2843
If this still gives you the problem, I would suggest trying with sudo /Applications/balenaEtcher.app/Contents/MacOS/balenaEtcher as described in the above issue.
If this does not work and if not already tried, you can try the above solution suggested which is to disable the SIP (System Integrity Protection) as described here https://www.macworld.co.uk/how-to/mac/how-turn-off-mac-os-x-system-integrity-protection-rootless-3638975/
That was it. I turned off the SIP and it worked. Thanks! Joseph
