I have downloaded the latest version of Etcher V1.5.95 on a Windows 10 Home and when I try to install it it hangs forever at “Installing, please wait…” as you can see in the image attached
I have even tried to change the compatibility options here
without any luck.
I had earlier versions of balenaEtcher installed and worked without no problems. The issues started when I tried to upgrade.
Looking forward to hear your thoughts,
Hey there! I’m sorry that you are having issues. Does it work fine if you try to install an older version: https://github.com/balena-io/etcher/releases? If that does work, then it might mean that our latest installer is broken for some reason.
Yes! 1.5.87 installed without problems.
Thanks for testing this out. We’ll take a closer look at it. In the mean-time, installing the latest version of Etcher might work if you completely uninstall the existing Etcher installation first.
I’m having the same issue?
Tried some of the older releases with the same result?
Just hangs at:
And if I try and uninstall I get the following error:
Hey Bob, is it possible that during your tests with several versions there may have been a mixup.
Could you please try to install v1.5.52 again from here https://github.com/balena-io/etcher/releases and then try to uninstall it and see if this trick works for you?
Let us know if you need some extra help.
