I saw multiple topics on this, no resolutions found. The image file was hash checked to be good for installation, and when I try to flash, the console spits out:
Wed Jan 05 2022 13:25:56 GMT-0800 (Pacific Standard Time) Write failed ({"image":{"size":1194328064,"name":"tails-amd64-4.24.img","hasMBR":true,"partitions":[{"offset":1048576,"size":1192230912,"type":"C12A7328-F81F-11D2-BA4B-00A0C93EC93B","guid":"34BF027A-8001-4B93-8243-1F9D3DCE7DE7","name":"Tails","index":1}],"extension":"img","path":"<snip>\\Downloads\\tails-amd64-4.24.img"},"drives":[{"size":31009800192,"isVirtual":false,"enumerator":"USBSTOR","logicalBlockSize":512,"raw":"\\\\.\\PhysicalDrive4","error":null,"isReadOnly":false,"displayName":"G:\\","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"\\\\.\\PhysicalDrive4","busVersion":"2.0","isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":null,"mountpoints":[{"path":"G:\\"}],"description":"Patriot Memory USB Device","isUAS":false,"partitionTableType":"mbr"}],"driveCount":1,"uuid":"3423729a-6fa9-4930-8a43-fbd135265d43","status":"failed","flashInstanceUuid":"3423729a-6fa9-4930-8a43-fbd135265d43","error":{"code":1},"sample":0.1,"applicationSessionUuid":"985aee1b-3219-458f-bd67-2b4a9d80b81b","flashingWorkflowUuid":"bc4c4783-5219-400d-bd3e-456153d763a7"})
gui.js:46 {"stack":"Error: Command failed: cmd /c \"<snipped>\\AppData\\Local\\Temp\\etcher\\balena-etcher-electron-58eb5e480531.cmd\"\r\n'chcp' is not recognized as an internal or external command,\r\noperable program or batch file.\r\n'cmd' is not recognized as an internal or external command,\r\noperable program or batch file.\r\n\n at file:///<snipped>/AppData/Local/Programs/balena-etcher/resources/app/generated/gui.js:46:703029\n at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3)","message":"Command failed: cmd /c \"<snipped>\\AppData\\Local\\Temp\\etcher\\balena-etcher-electron-58eb5e480531.cmd\"\r\n'chcp' is not recognized as an internal or external command,\r\noperable program or batch file.\r\n'cmd' is not recognized as an internal or external command,\r\noperable program or batch file.\r\n","code":1,"image":"tails-amd64-4.24.img"}
I had this with an earlier version of etcher, so that did not fix. I can run cmd files in a terminal, so I don’t understand how it could not from here. The drive it is running on (etcher) has 12gb free, would capacity there need to match the stick size (32gb), like a scratch disk for working?
I will try the older Etcher if I can find one.
