Etcher Portable version 1.5.122.0
Windows 10 version 10.0.22000.194 (Dev Insider version)
Debug output included below
Having trouble writing a Tails image to any USB drive I try and there is no error code or message other than it failed.
It seems to be a write permissions error but I ran as Admin so it shouldn’t be. Also has made the USB drives unusable. Tried reformatting but doesn’t recognize any drive after the Etcher fails. Only way yo recover is to use DiskPart utility.
Any help would be greatly appreciated. Thanks in advance!
Object Output
“results”: {
“bytesWritten”: 0,
“devices”: {
“failed”: 1,
“successful”: 0
“errors”: [
“name”: “Error”,
“description”: “Lexar USB Flash Drive USB Device”,
“code”: “EPERM”,
“syscall”: “write”,
“errno”: -4048,
“device”: “\\.\PhysicalDrive1”
“sourceMetadata”: {
“size”: 1185939456,
“name”: “tails-amd64-4.22.img”,
“blocks”: [
“blocks”: [
“offset”: 0,
“length”: 1185939456
“blockmappedSize”: 1185939456
“averageFlashingSpeed”: null
“cancelled”: false,
“skip”: false
Trace output
Wed Sep 22 2021 13:37:57 GMT-0400 (Eastern Daylight Time) Done ({“image”:{“size”:1185939456,“name”:“tails-amd64-4.22.img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:1183842304,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“34BF027A-8001-4B93-8243-1F9D3DCE7DE7”,“name”:“Tails”,“index”:1}],“extension”:“img”,“path”:“C:\Users\Henry\Downloads\Torrents\Finished Downloads\tails-amd64-4.22-img\tails-amd64-4.22.img”},“drives”:[{“size”:16016998400,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“Lexar USB Flash Drive USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“7870b0cf-0006-487b-9e58-38a5edeaec2f”,“status”:“finished”,“flashInstanceUuid”:“7870b0cf-0006-487b-9e58-38a5edeaec2f”,“errors”:[{“name”:“Error”,“description”:“Lexar USB Flash Drive USB Device”,“code”:“EPERM”,“syscall”:“write”,“errno”:-4048,“device”:"\\.\PhysicalDrive1"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:0,“sourceMetadata”:{“size”:1185939456,“name”:“tails-amd64-4.22.img”,“blocks”:[{“blocks”:[{“offset”:0,“length”:1185939456}]}],“blockmappedSize”:1185939456},“sample”:0.1,“applicationSessionUuid”:“db733cc5-971f-43bc-89d6-5c8792878c08”,“flashingWorkflowUuid”:“f9e7f0ed-faaa-4223-8008-855e34f129d1”})
