Hi @iian-lauc, are you talking about a version of Etcher being buggy?
Yes Mam I thought its unofficial (i apologize for that)
Etc
I hope balena etcher will be fix for manjaro or arch user…
Thank you.
Hi - could you confirm which version of Etcher you’re having issues with?
A file has been uploaded using Jellyfish: Jellyfish
Hi, not sure what ‘Aur version’ is. On etcher, can you click the setting icon (top right) and then check the version on the left?
Hi, I Checked it its aur.
Hi, I understand you downloaded etcher from AUR, but can you mention what exactly you’re facing issue with ?
I was asking if balena will have a snap version,
Because the aur version corrupts half of os you flashed even tho the specs of my pc same as requied.
thanks for understanding.
That’s all. : )
Hi, you should be able to use the .AppImage on most versions of linux: Releases · balena-io/etcher · GitHub
Can you try this and if it doesn’t work let us know? I believe snap packages just package the .AppImages anyway.
Hi @zwhitchcox ,
No it won’t work app image is made of electron and electron dont work on arch and manjaro’s
According the the Arch docs, electron does work on Manjaro/Arch. Have you actually tried it, or are you just speculating?
I was just asking,
If there is actually arch balena
if it was official,
I downloaded it and it doesnt work
Blank Screen only
Thank you
