Wifi on raspberry pi 3 a+, supported?
For my Raspberry Pi 3 A+, I added a new device from the dashboard. Choose RPi3 as board, os version 2.36, and then chose wifi+ethernet, provided ssd name and password. Used etcher to create SD card and then boot. OS booted, but then network-wise seemed to time-out (supervisor0: link is not ready & wlan0: link is not ready). Is the RPi 3A+ supposed to work with the wifi option?
Hey @bonometric, our OS should work with wifi, both 2.4GHz and 5GHz. Could you confirm that the wifi credentials are correct? Check if your router is identifying the device and giving it an IP address. You can get more info here: Change wifi credentials
