mschm
1
Hi
I can download BalenaOS 2.12.7+rev2.dev for UP board from either https://www.balena.io/os/#download or balenaCloud. However, https://github.com/balena-os/resin-up-board/releases lists much newer releases than that.
What is the reason for recent releases not being “released” and how can I download and use them for development?
Keep up the great work!!
Hi @mschm,
You can download the latest release for UP board BalenaOS 2.29.0+rev2 from the https://www.balena.io/os/#download link or from the dashboard.
Not all versions from github are released to production since some of them have some problems or are intermediary releases.
In order for a release to reach production it first needs to be tested by us. If all goes fine in testing the version will be released in production.
If someone wants a version from github it needs to pull the sources and he can compile the release on his own.
Regards!
