My versions:
$ balena --version
11.36.0
$ node --version
v14.4.0
I have found that I can’t download any OSes for raspberrypi4 using the Balena CLI.
Some outputs:
Firstly, downloading using the menu:
$ balena os download raspberrypi4-64 -o pi.img --version menu
Getting device operating system for raspberrypi4-64
? Select the OS version: v2.41.0+rev4.prod
No such version for the device type
Secondly, simply trying to pull down the latest version:
$ balena os download raspberrypi4-64 -o pi.img --version latest
Thirdly, trying a different version string:
$ balena os download raspberrypi4-64 -o pi.img --version 2.46
version.replace is not a function
I am feeling a bit at a loss here; it was hard to find the slug, but if the sane defaults aren’t available for download either, I’m not sure if I can trust the CLI.
The reason I was looking for version 2.46 btw, was to see if I could get an older version to connect to OpenBalena, as I saw in some other thread that there’s issues with balenaOS after version 2.46 when connecting with an openBalena server.
