Hello folks!
I’m trying to get Wayland on a balenaOS container in our Jetson Nano.
The Dockerfile is just this:
FROM balenalib/jetson-nano-ubuntu:latest-run
WORKDIR /app
RUN install_packages \
evtest \
weston
COPY . ./
ENV INITSYSTEM on
ENV UDEV=1
CMD [ "/bin/bash", "/app/start.sh" ]
The start script is:
#!/bin/bash
export DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket
export XDG_RUNTIME_DIR="/run/shm/wayland"
mkdir -p "$XDG_RUNTIME_DIR"
chmod 0700 "$XDG_RUNTIME_DIR"
/usr/bin/weston --backend=drm-backend.so --tty=1
When the container first starts, it give me a message saying there is no DRM device. After a few restarts, it start saying the /dev/tty1 is already in graphics mode…
Date: 2019-05-28 UTC
[10:54:57.243] weston 3.0.0
http://wayland.freedesktop.org
Bug reports to: https://bugs.freedesktop.org/enter_bug.cgi?product=Wayland&component=weston&version=3.0.0
Build: unknown (not built from git or tarball)
[10:54:57.243] Command line: /usr/bin/weston --backend=drm-backend.so --tty=1
[10:54:57.243] OS: Linux, 4.9.140-l4t-r32.1+g0e2f66e, #1 SMP PREEMPT Thu Apr 25 13:17:54 UTC 2019, aarch64
[10:54:57.243] Starting with no config file.
[10:54:57.243] Output repaint window is 7 ms maximum.
[10:54:57.243] Loading module '/usr/lib/aarch64-linux-gnu/libweston-3/drm-backend.so'
[10:54:57.246] initializing drm backend
[10:54:57.247] logind: not running in a systemd session
[10:54:57.247] logind: cannot setup systemd-logind helper (-61), using legacy fallback
[10:54:57.247] /dev/tty1 is already in graphics mode, is another display server running?
[10:54:57.247] fatal: drm backend should be run using weston-launch binary or as root
[10:54:57.247] fatal: failed to create compositor backend
As you may see on the Dockerfile, we’re using the balenalib image for this board, so I guess the nvidia drivers are already in place…
Can someone give a clue on how to get Wayland to work on this device using BalenaOS?
Thank you!
Hi, I saw that you already opened an issue for this in the balena-wayland playground repo.
I will pass this to the respective team for further investigation.
Yep! I did, thanks! Looking forward to get it working
Hey, we have informed the core maintainer of the library about it, and they will have a look at it when possible. Thanks!
Library? You mean BalenaLib?
Hi @galvesribeiro the balenalib base images don’t install any of the nvidia specific binaries, you will need to install those yourself from whatever PPA nvidia provides for this.
Okey,
Nvidia provides this https://developer.nvidia.com/embedded/dlc/l4t-jetson-driver-package-32-1-jetson-nano driver package, but I have no idea how to install it on the container as it points only on how to build images based on it…
@galvesribeiro the nano is still a very new platform, so I don’t have a good idea of exactly how to do this, but the best place to start is to look at this demo project https://github.com/acostach/nano-sample-app and try adapt it to install the needed packages for wayland.
Oh!! That is great!
Thanks for the tip. Will check on that and report back.
No problem, please let me know how it goes. we are actively learning about the limits and features of this device, so its interesting to know.
No success… Same problem…
I was wondering… On Asus Tinkerboard I have the Mali GPU on /dev/dri/ however, on this board I dont:
root@906686c:/app# ls /dev/
autofs hugepages media0 null pts ram3 tty12 tty38 tty63 urandom
block i2c-0 mem nvhost-as-gpu ptyp0 ram4 tty13 tty39 tty7 vcs
bus i2c-1 memory_bandwidth nvhost-ctrl ptyp1 ram5 tty14 tty4 tty8 vcs1
char i2c-2 min_online_cpus nvhost-ctrl-gpu ptyp2 ram6 tty15 tty40 tty9 vcs2
console i2c-3 mmcblk0 nvhost-ctrl-isp ptyp3 ram7 tty16 tty41 ttyS0 vcs3
constraint_cpu_freq i2c-4 mmcblk0p1 nvhost-ctrl-isp.1 ptyp4 ram8 tty17 tty42 ttyS1 vcs4
constraint_gpu_freq i2c-5 mmcblk0p10 nvhost-ctrl-nvdec ptyp5 ram9 tty18 tty43 ttyS2 vcs5
constraint_online_cpus i2c-6 mmcblk0p11 nvhost-ctrl-vi ptyp6 random tty19 tty44 ttyS3 vcs6
cpu_dma_latency iio:device0 mmcblk0p12 nvhost-ctxsw-gpu ptyp7 rfkill tty2 tty45 ttyTHS1 vcsa
cpu_freq_max initctl mmcblk0p13 nvhost-dbg-gpu ptyp8 rtc tty20 tty46 ttyTHS2 vcsa1
cpu_freq_min input mmcblk0p14 nvhost-gpu ptyp9 rtc0 tty21 tty47 ttyp0 vcsa2
cuse keychord mmcblk0p15 nvhost-isp ptypa rtc1 tty22 tty48 ttyp1 vcsa3
disk kmem mmcblk0p16 nvhost-isp.1 ptypb shm tty23 tty49 ttyp2 vcsa4
emc_freq_min kmsg mmcblk0p2 nvhost-msenc ptypc snd tty24 tty5 ttyp3 vcsa5
fb0 log mmcblk0p3 nvhost-nvdec ptypd stderr tty25 tty50 ttyp4 vcsa6
fb1 loop-control mmcblk0p4 nvhost-nvjpg ptype stdin tty26 tty51 ttyp5 vfio
fd loop0 mmcblk0p5 nvhost-prof-gpu ptypf stdout tty27 tty52 ttyp6 vhci
full loop1 mmcblk0p6 nvhost-sched-gpu quadd tegra-crypto tty28 tty53 ttyp7 watchdog
fuse loop2 mmcblk0p7 nvhost-tsec quadd_auth tegra_camera_ctrl tty29 tty54 ttyp8 watchdog0
gpiochip0 loop3 mmcblk0p8 nvhost-tsecb ram0 tegra_dc_0 tty3 tty55 ttyp9 zero
gpiochip1 loop4 mmcblk0p9 nvhost-tsg-gpu ram1 tegra_dc_1 tty30 tty56 ttypa
gpu_freq_max loop5 mqueue nvhost-vi ram10 tegra_dc_ctrl tty31 tty57 ttypb
gpu_freq_min loop6 mtd0 nvhost-vic ram11 tegra_mipi_cal tty32 tty58 ttypc
hidraw0 loop7 mtd0ro nvmap ram12 tty tty33 tty59 ttypd
hidraw1 mapper mtdblock0 port ram13 tty0 tty34 tty6 ttype
hidraw2 max_cpu_power net ppp ram14 tty1 tty35 tty60 ttypf
hidraw3 max_gpu_power network_latency psaux ram15 tty10 tty36 tty61 uhid
hidraw4 max_online_cpus network_throughput ptmx ram2 tty11 tty37 tty62 uinput
Isn’t that the real problem here?
it looks like there is a /dev/fb0 there. Not sure if this device has dri. What does the standard ubuntu system have and does wayland work there?
Yeah. It works just fine on regular L4T with the drm-backend.so
okay, and does the ubuntu image have /dev/dri? and how is or where is drm-backend.so installed from. In theory if the kernel modules are installed and you get drm-backend.so in your privileged container, it should all work. Its just a matter of figuring out how to install that file.
The backend comes with the weston package installed from apt. I’ll check the /dev/dri in a moment. Out of a PC now
If you can figure out the exact combination of kernel modules and things needed in /dev, im sure we can get it supported eventually.
I just confirmed… NVidia doesn’t mount on /dev/dri… Assuming that Balena is using NVidia-provided kernel, the modules are already there but, the userland lib/firmware files are not.
Regarding the /lib/firmware folder, note that it is possible to “bind mount” it on an app container by setting the io.balena.features.firmware label in the docker-compose.yml file (or using a single-container app with a single Dockerfile):
With that in place, you can add firmware files through your app container. The /lib/firmware folder will be initially mounted “read only” on the app container, but you can remount it “read write” before copying the file with the command:
# on the app container
mount -o remount,rw /lib/firmware
I am assuming that drm-backend.so is a firmware file that would benefit from the process above, and it sounds like we are all assuming that the kernel already has the required modules in place… If the kernel has the required modules and the hardware is present, but a firmware file is missing, it is often the case that an error message can be found in the output of the dmesg command on the host OS.
