I am new to Balena, so this could entirely be a case of me missing an obvious step, apologies if so.
I have raspberry pi zero onto which I have the waveshare 7000E cellular HAT connected via UART. https://www.waveshare.com/sim7000e-nb-iot-hat.htm
On Raspian OS (bull’s eye) the modem works fine after, activating UART on ttyACM0 (using cmdline.txt and Config.txt). I also had to add two udev lines below.
ACTION=="add", KERNEL=="3f201000.serial", ENV{ID_MM_DEVICE_PROCESS}="1"
ACTION=="add|change|move", KERNEL=="ttyAMA0", ENV{ID_MM_TTY_FLOW_CONTROL}="none", ENV{ID_MM_TTY_BAUDRATE}="115200", ENV{ID_MM_CANDIDATE}="1", ENV{ID_MM_DEVICE_PROCESS}="1"
I dial using PPP and I can send AT commands via picom at 11500 baud rate.
Onto Balena,
I made the exact same changes
- Enabled UART and dtoverlays (pi3-miniuart-bt) via fleet configuration.
- I also added a cellular file to the connections folder
- added the UDEV rules via config.json. which show up in /etc/udev/rules.d.
After all this,
a. UART is on serial0 → ttyAMA0 (good)
b. Udev rules show (good) - Example of one below.
root@d3f3c85:/lib/udev# cat /etc/udev/rules.d/64-cellular7000E.rules
c. mmcli -S and mmcli -L show no modem found. (bad)
d. no cellular connection set up (bad, though not a surprise given mmcli shows no modem)
What am I missing/doing wrong? Any one had any success with the waveshare 7000E on Balena using UART?
Happy to provide more info
