Does anyone have any experience using SIM7000 (NB-IoT) module with Balena Fin or Raspberry Pi running Balena OS. It would be greatly appreciated if you could share any configuration.
Currently looking at the following module: https://techship.com/products/simcom-sim7000e-cat-m-nb-iot-pcie/
Aurelien
Hello, we didn’t have the chance to test that specific one, but we did try a sim7600e and that was working fine, so I would guess the same applies to this model.
As far as configuration goes it should be fairly simple, have a look at https://www.balena.io/docs/reference/OS/network/2.x/#cellular-modem-setup which should guide you through the required and let us know if anything is unclear or not working as expected.
