@ntzovanis Half-correct.
The steps are correct (tough I formated between re-flashing) but I’ve tried it with 2 different SD cards.
I have to take a look if i can flash an USB with debian for example to try on linux. It seems like it is the same comparison issue as you mentioned but out of nowhere with an SD that just worked?
I’ll give it a try and let you know as soon as I finished or failed.
-Florian
Update: I just got home and tried my 64GB sandisk sd again, just for fun.
The interesting thing is, even tough it showed me “flash failed” it managed to validate to 100% and the sd card works.
Here’s my console log
Verifying 1 device, 100% at 11.00 MB/s (total 11.00 MB/s) eta in 0s with 0 failed devices
gui.js:42737 Wed Jun 30 2021 19:47:55 GMT+0200 (Mitteleuropäische Sommerzeit) Flash error ({“image”:{“size”:5887754240,“compressedSize”:1257573092,“hasMBR”:true,“path”:“C:\Users\floje\Downloads\Manjaro-ARM-kde-plasma-pbpro-21.06.img.xz”,“partitions”:[{“offset”:32000000,“size”:224000512,“type”:“EBD0A0A2-B9E5-4433-87C0-68B6B72699C7”,“guid”:“3C86890B-8EA1-4368-886C-09377B746452”,“name”:“primary”,“index”:1},{“offset”:256000512,“size”:5631736832,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“3D2CE76C-0ACB-464E-8CD5-01694C894836”,“name”:“primary”,“index”:2}],“isCompressed”:true,“name”:“Manjaro-ARM-kde-plasma-pbpro-21.06.img”,“isSizeEstimated”:false,“extension”:“xz”},“drives”:[{“size”:63864569856,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive3",“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive3",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“CARDER READER USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“e1139c34-e825-4e7a-8583-bb6f349be2d0”,“flashInstanceUuid”:“e1139c34-e825-4e7a-8583-bb6f349be2d0”,“error”:{“name”:“Error”,“message”:“Unmount failed”,“stack”:“Error: Unmount failed”},“sample”:0.1,“applicationSessionUuid”:“25e260da-34e5-4059-99ff-ebe2dc69be01”,“flashingWorkflowUuid”:“b9af5b6e-70f4-4efd-9ee6-0a61f55a7872”})
gui.js:42737 Finish: 5887754240
gui.js:42737 Terminating IPC server
gui.js:42737 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:42737 Wed Jun 30 2021 19:47:56 GMT+0200 (Mitteleuropäische Sommerzeit) Done ({“image”:{“size”:5887754240,“compressedSize”:1257573092,“hasMBR”:true,“path”:“C:\Users\floje\Downloads\Manjaro-ARM-kde-plasma-pbpro-21.06.img.xz”,“partitions”:[{“offset”:32000000,“size”:224000512,“type”:“EBD0A0A2-B9E5-4433-87C0-68B6B72699C7”,“guid”:“3C86890B-8EA1-4368-886C-09377B746452”,“name”:“primary”,“index”:1},{“offset”:256000512,“size”:5631736832,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“3D2CE76C-0ACB-464E-8CD5-01694C894836”,“name”:“primary”,“index”:2}],“isCompressed”:true,“name”:“Manjaro-ARM-kde-plasma-pbpro-21.06.img”,“isSizeEstimated”:false,“extension”:“xz”},“drives”:[{“size”:63864569856,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive3",“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive3",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“CARDER READER USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“e1139c34-e825-4e7a-8583-bb6f349be2d0”,“status”:“finished”,“flashInstanceUuid”:“e1139c34-e825-4e7a-8583-bb6f349be2d0”,“errors”:[{“name”:“Error”,“description”:“CARDER READER USB Device”,“device”:"\\.\PhysicalDrive3"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:5887754240,“sourceMetadata”:{“isCompressed”:true,“name”:“Manjaro-ARM-kde-plasma-pbpro-21.06.img”,“size”:5887754240,“compressedSize”:1257573092,“isSizeEstimated”:false},“sample”:0.1,“applicationSessionUuid”:“25e260da-34e5-4059-99ff-ebe2dc69be01”,“flashingWorkflowUuid”:“b9af5b6e-70f4-4efd-9ee6-0a61f55a7872”})
gui.js:42737 Wed Jun 30 2021 19:47:56 GMT+0200 (Mitteleuropäische Sommerzeit) SafeWebview loaded ({“event”:{“id”:72,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.5.116&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1625075276269.239,“resourceType”:“mainFrame”,“ip”:“2a05:d014:275:cb02:66df:50b:6e56:a6bf”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“5438”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“br”],“content-length”:[“6087”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Wed, 30 Jun 2021 16:17:24 GMT”],“etag”:["“849d144883e260c53ef1328ed74b9185-ssl-df”"],“link”:["</webpack-runtime-ce0e6738e6853ac14584.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-42f2600cafd3c0e08aac.js>; rel=preload; as=script, </50c25a04-efe577ee14c9c53bed03.js>; rel=preload; as=script, </73ad3401-e112b47ad7a992b91ac8.js>; rel=preload; as=script, </532a2f07-16f3498dd087ee7288d4.js>; rel=preload; as=script, </app-aac6a81a79937d1ac2bd.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-4ae9e03f4545d4f1d61b.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-8fcc2f56d20b76e33299.js>; rel=preload; as=script, </edad6859a763f5239c0343c48608d154b87713d6-282649cf8ac0a71046b8.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-c81df2b0c3894e1f37af.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],“referrer-policy”:[“strict-origin-when-cross-origin”],“server”:[“Netlify”],“status”:[“200”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“01F9F0HWCZ2WTTK2K2MQV2HPYN”],“x-xss-protection”:[“1; mode=block”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“25e260da-34e5-4059-99ff-ebe2dc69be01”,“flashingWorkflowUuid”:“b9af5b6e-70f4-4efd-9ee6-0a61f55a7872”})
