Using USB regularly after / Unflashing
So i ran BalenaEtcher to get Tails on my USB, and it did so. I then realized Tails does not run on m1 macs. How do i undo this process so I can use my USB regularly? Since now my usb does not show up when plugged in.
Hello, you can check out the “Using MacOS” section of “How to Recover a USB Drive or SD Card” in this blog post to restore your USB: Etcher broke my USB stick … or did it?
