I’m running BalenaOS on a RaspberryPi 4. Attached to this Pi is a touchscreen that has an external power supply and a usb interface to deliver touch events. When this touchscreen is attached to the Pi when the Pi is powered up, it fails to boot. It will startup, show the rainbow splash, then shutdown; this repeats indefinitely.
I grabbed a startup log with a USB to UART adapter and have included it below:
U-Boot 2020.07 (Oct 21 2020 - 11:03:27 +0000)
DRAM: 3.8 GiB
RPI 4 Mode B (0xc03111)
MMC: mmcnr@7e300000: 1, emmc2@7e340000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial
Out: erial
Err: serial
Net: eth0: ethernet@7d580000
PCIe BRCM: link up, 5.0 Gbps x1 (SSC)
starting USB...
Bus xhci_pci: Register 5000420 NbrPorts5
Starting the controller
USB XHCI 1.00
scanning bus xhci_pci for devices... 2 USB Device(s) found
scanning usbfor storage devices... 0 Storage Device(s) found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot scipt /boot.scr
516 bytes read in 11 ms (44.9 KiB/s)
## Executing script at 02400000
DRAM: 3.8 GiB
RPI 4 Model (0xc03111)
In: serial
Out: erial
Err: serial
starting USB...
USB XHCI 1.00
scanning bus xhci_pci for devices... WARN halted endpoint, queueing URB anyway.
Unexpected XHCI event TRB, skipping... (37b64330 00000000 13000000 02008401)
BUG at drivers/usb/host/xhci-ring.c:498/abort_td()!
BUG!
resetting ...
U-Boot 2020.07 (Oct 21 2020 - 11:03:7 +0000)
DRAM: 3.8 GiB
RPI 4 Model B (0xc03111)
In: serial
Out: erial
Err: serial
starting USB...
USB XHCI 1.00
BUG!at drivers/usb/host/xhci-ring.c:498/abort_td()!
resetting ...
Any help or thoughts are appreciated! I’m going to test with other USB devices too. This issue does not occur on Raspbian/Ubuntu images, so I’ll grab some output from those too.
