I have a custom board that has a PCIe-USB3 chip on board and works properly (confirmed with Raspberry Pi OS with 5.10 kernel). When I try to boot using Balena OS (newly built) the device doesn’t boot, nothing comes out of the console after “Starting kernel …”. When I take the exact same CM4 and put on any other board without a PCIe device, it boots properly. I’ve even tried with the under development 5.10 branch of raspberrypi balenaOS, same result. Here are the boot logs:
Working:
U-Boot 2021.04-rc3 (Mar 03 2021 - 15:10:4 +0000)
DRAM: 2 GiB
RPI Compute Module 4 (0xb03140)
MMC: mmcnr@7e300000: 1, emmc2@7e340000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial
Err: serial
Net: eth0: ethernet@7d580000
PCIe BRCM: link down
starting USB...
No working controllers found
switch to partitions #0, OK
mmc0(part ) is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
516 bytes read in 10 ms (49.8 KiB/s)
## Executing script at 02400000
Scanning mc usb devices 0 1 2
24 bytes read in 13 ms (1000 Bytes/s)
Found resin image on mmc 0
Loading resinOS_uEnv.txt from mmc device 0 partiion 1
Failed to load 'resinOS_uEnv.txt'
Loading extra_uEnv.txt from mmc device 0 partition 1
0 bytes read in 11 ms (0 Bytes/s)
Import etra_uEnv.txt in environment
Loading bootcount.env from mmc device 0 partition 1
Failed to load 'bootcount.env'
No bootcount.envfile. Setting bootcount=0 in environment
12469316 bytes read in 558 ms (21.3 MiB/s)
Uncompressed size: 28365312 = 0x1B0D200
## FlattenedDevice Tree blob at 2eff4100
Booting using the fdt blob at 0x2eff4100
Using Device Tree in place at 000000002eff410, end 000000002f002f6d
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.4.83-v8 (oe-user@oe-host) (gcc version 9.3.0 (GCC)) #1 SMP PREEMPT Mon Dec 14 12:43:54 UTC 2020
[ 0.000000] Machine model: Raspberry Pi Compute Module 4 Rev 1.0
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
Not working:
U-Boo 2021.04-rc3 (Mar 03 2021 - 15:10:34 +0000)
DRAM: 2 GiB
In: serial
Err: serial
PCIe BRCM: link up, 5.0 Gbps x1 (SSC)
starting USB...
Bus xhci_pci: Register 4000840 NbrPorts 4
Starting the contoller
USB XHCI 1.10
scanning bus xhci_pci for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Stoage Device(s) found
mmc0(part 0) is current device
Scanning mmc 0:1...
516 bytes read in 11 s (44.9 KiB/s)
Scanning mmc usb devices 0 1 2
24 bytes read in 14 ms (1000 Bytes/s)
Found resin image on mc 0
Loading resinOS_uEnv.txt from mmc device 0 partition 1
Loading extra_uEnv.txt from mmc devic 0 partition 1
0 bytes read in 12 ms (0 Bytes/s)
Import extra_uEnv.txt in environment
Loading bootcount.env from mmc device 0 patition 1
No bootcount.env file. Setting bootcount=0 in environment
12469316 bytes read in 558 ms (21.3 MB/s)
## Flattened Device Tree blob at 2eff4100
Booting using the fdt blob at 0x2eff100
Using Device Tree in place at 000000002eff4100, end 000000002f002f6d
Starting kernel ...
Any suggestions on places to look? Thanks.
