Hi guys,
Scratching my head here.
Trying to write ANY image file to my new NVME USB device results in some very strange partition structure after the write. No errors are received on screen and it validates OK.
Tried without success:
MacOS etcher (latest)
Windows etcher (latest)
Use diskpart to CLEAN drive
pre format as NTFS
pre format as FAT32
different USB ports
various image files
Regardless of the image used or the steps taken above, the resulting partition structure looks like:
https://cdn.discordapp.com/attachments/704640082170085396/871439054221246485/unknown.png
Log:
index.css:1 Failed to load resource: net::ERR_FILE_NOT_FOUND
electron/js2c/renderer_init.js:13 (electron) The remote module is deprecated. Use https://github.com/electron/remote instead.
log @ electron/js2c/renderer_init.js:13
gui.js:90441 _____ _ _
| ___| | | |
| |__ | |_ ___| |__ ___ _ __
| __|| __/ __| '_ \ / _ \ '__|
| |___| || (__| | | | __/ |
\____/ \__\___|_| |_|\___|_|
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.5.121, Type = dmg
gui.js:58408 Sun Aug 01 2021 20:40:18 GMT+0100 (British Summer Time) Application start ({"packageType":"dmg","version":"1.5.121","sample":0.1,"applicationSessionUuid":"c340dc95-a65b-4a13-9bc7-6cd43912da87","flashingWorkflowUuid":"e8c0c07a-394d-4594-b360-242084dd9046"})
gui.js:51110 Sun Aug 01 2021 20:40:40 GMT+0100 (British Summer Time) Open image selector ({"sample":0.1,"applicationSessionUuid":"c340dc95-a65b-4a13-9bc7-6cd43912da87","flashingWorkflowUuid":"e8c0c07a-394d-4594-b360-242084dd9046"})
gui.js:51110 Sun Aug 01 2021 20:40:55 GMT+0100 (British Summer Time) Select image ({"image":{"size":3980394496,"name":"2021-05-07-raspios-buster-armhf.img","hasMBR":true,"partitions":[{"offset":4194304,"size":268435456,"type":12,"index":1},{"offset":272629760,"size":3707764736,"type":131,"index":2}],"extension":"img","path":"/Volumes/1TB WD/2021-05-07-raspios-buster-armhf.img","logo":false,"blockMap":false},"sample":0.1,"applicationSessionUuid":"c340dc95-a65b-4a13-9bc7-6cd43912da87","flashingWorkflowUuid":"e8c0c07a-394d-4594-b360-242084dd9046"})
gui.js:51110 Sun Aug 01 2021 20:41:03 GMT+0100 (British Summer Time) Flash ({"image":{"size":3980394496,"name":"2021-05-07-raspios-buster-armhf.img","hasMBR":true,"partitions":[{"offset":4194304,"size":268435456,"type":12,"index":1},{"offset":272629760,"size":3707764736,"type":131,"index":2}],"extension":"img","path":"/Volumes/1TB WD/2021-05-07-raspios-buster-armhf.img"},"drives":[{"size":500107862016,"isVirtual":false,"enumerator":"DiskArbitration","logicalBlockSize":4096,"raw":"/dev/rdisk3","error":null,"isReadOnly":false,"displayName":"/dev/disk3","blockSize":4096,"isSCSI":false,"isRemovable":false,"device":"/dev/disk3","busVersion":null,"isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":"IODeviceTree:/PCI0@0/XHC1@14","mountpoints":[{"path":"/Volumes/Untitled","label":"Untitled"}],"description":"Netac Mobiledatastar Media","isUAS":null,"partitionTableType":"mbr"}],"driveCount":1,"uuid":"d912d44d-02a7-498b-b799-87148491233a","status":"started","flashInstanceUuid":"d912d44d-02a7-498b-b799-87148491233a","sample":0.1,"applicationSessionUuid":"c340dc95-a65b-4a13-9bc7-6cd43912da87","flashingWorkflowUuid":"e8c0c07a-394d-4594-b360-242084dd9046"})
gui.js:51110 Elevating command: /Applications/balenaEtcher.app/Contents/Frameworks/balenaEtcher Helper (Renderer).app/Contents/MacOS/balenaEtcher Helper (Renderer) /Applications/balenaEtcher.app/Contents/Resources/app-x64/generated/child-writer.js
gui.js:38454 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:51110 Sun Aug 01 2021 20:41:05 GMT+0100 (British Summer Time) SafeWebview loaded ({"event":{"id":1,"url":"https://assets.balena.io/etcher-featured/index.html?borderRight=false&darkBackground=true&etcher-version=1.5.121&api-version=2&optOutAnalytics=false","method":"GET","timestamp":1627846865521.816,"resourceType":"mainFrame","ip":"104.21.29.149","fromCache":false,"statusLine":"HTTP/1.1 200","statusCode":200,"responseHeaders":{"access-control-allow-origin":["*"],"age":["88"],"alt-svc":["h3-27=\":443\"; ma=86400, h3-28=\":443\"; ma=86400, h3-29=\":443\"; ma=86400, h3=\":443\"; ma=86400"],"cache-control":["max-age=600"],"cf-cache-status":["DYNAMIC"],"cf-ray":["67818abd3b27f433-LHR"],"content-encoding":["br"],"content-type":["text/html; charset=utf-8"],"date":["Sun, 01 Aug 2021 19:41:05 GMT"],"expect-ct":["max-age=604800, report-uri=\"https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct\""],"expires":["Thu, 29 Jul 2021 18:31:14 GMT"],"last-modified":["Thu, 29 Jul 2021 18:19:52 GMT"],"nel":["{\"report_to\":\"cf-nel\",\"max_age\":604800}"],"report-to":["{\"endpoints\":[{\"url\":\"https:\\/\\/a.nel.cloudflare.com\\/report\\/v3?s=3OBO%2FvQSbRgqAMg7qMRP6IsBUQOIBEeBmnqvy2yes7MA1T58QZfMLaESCBsgYGC5o5sjz7o%2FJYElM%2BxxGp6MXFE0%2F%2BPmrt0oBxgsBpVDILYWiVGBhIjOCIX2jAJzDpzyswPg\"}],\"group\":\"cf-nel\",\"max_age\":604800}"],"server":["cloudflare"],"vary":["Accept-Encoding"],"via":["1.1 varnish"],"x-cache":["HIT"],"x-cache-hits":["1"],"x-fastly-request-id":["2bd1f7f7f0750986ce3b1711f48c71634fab9c55"],"x-github-request-id":["7F20:AEAB:710754:768F8D:6102F19A"],"x-origin-cache":["HIT"],"x-proxy-cache":["MISS"],"x-served-by":["cache-lcy19283-LCY"],"x-timer":["S1627846865.493882,VS0,VE1"]},"referrer":"","error":"net::OK"},"sample":0.1,"applicationSessionUuid":"c340dc95-a65b-4a13-9bc7-6cd43912da87","flashingWorkflowUuid":"e8c0c07a-394d-4594-b360-242084dd9046"})
gui.js:51110 Successfully connected to IPC server: etcher-server-1643, socket root /var/folders/41/k1h79w5578g859xhk9mf0ldm0000gn/T/
gui.js:51110 Image: /Volumes/1TB WD/2021-05-07-raspios-buster-armhf.img
gui.js:51110 Devices: /dev/disk3
gui.js:51110 Auto blockmapping: true
gui.js:51110 Decompress first: true
gui.js:38454 Flashing 1 device, 1% at 37.00 MB/s (total 37.00 MB/s) eta in 92s with 0 failed devices
gui.js:38454 Flashing 1 device, 2% at 41.10 MB/s (total 41.10 MB/s) eta in 82s with 0 failed devices
gui.js:38454 Flashing 1 device, 3% at 42.70 MB/s (total 42.70 MB/s) eta in 78s with 0 failed devices
gui.js:38454 Flashing 1 device, 4% at 42.70 MB/s (total 42.70 MB/s) eta in 77s with 0 failed devices
gui.js:38454 Flashing 1 device, 6% at 42.20 MB/s (total 42.20 MB/s) eta in 76s with 0 failed devices
gui.js:38454 Flashing 1 device, 7% at 42.30 MB/s (total 42.30 MB/s) eta in 75s with 0 failed devices
gui.js:38454 Flashing 1 device, 8% at 42.30 MB/s (total 42.30 MB/s) eta in 74s with 0 failed devices
gui.js:38454 Flashing 1 device, 10% at 42.30 MB/s (total 42.30 MB/s) eta in 73s with 0 failed devices
gui.js:38454 Flashing 1 device, 11% at 42.80 MB/s (total 42.80 MB/s) eta in 71s with 0 failed devices
gui.js:38454 Flashing 1 device, 13% at 42.30 MB/s (total 42.30 MB/s) eta in 71s with 0 failed devices
gui.js:38454 Flashing 1 device, 14% at 43.40 MB/s (total 43.40 MB/s) eta in 68s with 0 failed devices
gui.js:38454 Flashing 1 device, 15% at 42.90 MB/s (total 42.90 MB/s) eta in 68s with 0 failed devices
gui.js:38454 Flashing 1 device, 16% at 41.30 MB/s (total 41.30 MB/s) eta in 69s with 0 failed devices
gui.js:38454 Flashing 1 device, 17% at 41.70 MB/s (total 41.70 MB/s) eta in 68s with 0 failed devices
gui.js:38454 Flashing 1 device, 19% at 42.90 MB/s (total 42.90 MB/s) eta in 65s with 0 failed devices
gui.js:38454 Flashing 1 device, 20% at 42.30 MB/s (total 42.30 MB/s) eta in 65s with 0 failed devices
gui.js:38454 Flashing 1 device, 21% at 42.20 MB/s (total 42.20 MB/s) eta in 64s with 0 failed devices
gui.js:38454 Flashing 1 device, 23% at 42.40 MB/s (total 42.40 MB/s) eta in 63s with 0 failed devices
gui.js:38454 Flashing 1 device, 24% at 42.30 MB/s (total 42.30 MB/s) eta in 62s with 0 failed devices
gui.js:38454 Flashing 1 device, 25% at 42.80 MB/s (total 42.80 MB/s) eta in 60s with 0 failed devices
gui.js:38454 Flashing 1 device, 26% at 42.80 MB/s (total 42.80 MB/s) eta in 59s with 0 failed devices
gui.js:38454 Flashing 1 device, 28% at 42.80 MB/s (total 42.80 MB/s) eta in 58s with 0 failed devices
gui.js:38454 Flashing 1 device, 29% at 43.30 MB/s (total 43.30 MB/s) eta in 56s with 0 failed devices
gui.js:38454 Flashing 1 device, 30% at 43.30 MB/s (total 43.30 MB/s) eta in 55s with 0 failed devices
gui.js:38454 Flashing 1 device, 31% at 42.80 MB/s (total 42.80 MB/s) eta in 55s with 0 failed devices
gui.js:38454 Flashing 1 device, 32% at 42.20 MB/s (total 42.20 MB/s) eta in 55s with 0 failed devices
gui.js:38454 Flashing 1 device, 34% at 42.20 MB/s (total 42.20 MB/s) eta in 54s with 0 failed devices
gui.js:38454 Flashing 1 device, 35% at 42.80 MB/s (total 42.80 MB/s) eta in 52s with 0 failed devices
gui.js:38454 Flashing 1 device, 36% at 42.40 MB/s (total 42.40 MB/s) eta in 52s with 0 failed devices
gui.js:38454 Flashing 1 device, 38% at 42.80 MB/s (total 42.80 MB/s) eta in 50s with 0 failed devices
gui.js:38454 Flashing 1 device, 39% at 42.80 MB/s (total 42.80 MB/s) eta in 49s with 0 failed devices
gui.js:38454 Flashing 1 device, 40% at 42.70 MB/s (total 42.70 MB/s) eta in 48s with 0 failed devices
gui.js:38454 Flashing 1 device, 41% at 42.80 MB/s (total 42.80 MB/s) eta in 47s with 0 failed devices
gui.js:38454 Flashing 1 device, 43% at 42.80 MB/s (total 42.80 MB/s) eta in 46s with 0 failed devices
gui.js:38454 Flashing 1 device, 44% at 42.80 MB/s (total 42.80 MB/s) eta in 45s with 0 failed devices
gui.js:38454 Flashing 1 device, 45% at 42.80 MB/s (total 42.80 MB/s) eta in 44s with 0 failed devices
gui.js:38454 Flashing 1 device, 46% at 43.30 MB/s (total 43.30 MB/s) eta in 43s with 0 failed devices
gui.js:38454 Flashing 1 device, 48% at 42.80 MB/s (total 42.80 MB/s) eta in 42s with 0 failed devices
gui.js:38454 Flashing 1 device, 49% at 42.80 MB/s (total 42.80 MB/s) eta in 41s with 0 failed devices
gui.js:38454 Flashing 1 device, 50% at 42.80 MB/s (total 42.80 MB/s) eta in 40s with 0 failed devices
gui.js:38454 Flashing 1 device, 51% at 42.70 MB/s (total 42.70 MB/s) eta in 39s with 0 failed devices
gui.js:38454 Flashing 1 device, 53% at 43.30 MB/s (total 43.30 MB/s) eta in 37s with 0 failed devices
gui.js:38454 Flashing 1 device, 54% at 43.40 MB/s (total 43.40 MB/s) eta in 36s with 0 failed devices
gui.js:38454 Flashing 1 device, 55% at 42.90 MB/s (total 42.90 MB/s) eta in 36s with 0 failed devices
gui.js:38454 Flashing 1 device, 56% at 43.40 MB/s (total 43.40 MB/s) eta in 34s with 0 failed devices
gui.js:38454 Flashing 1 device, 58% at 43.40 MB/s (total 43.40 MB/s) eta in 33s with 0 failed devices
gui.js:38454 Flashing 1 device, 58% at 42.80 MB/s (total 42.80 MB/s) eta in 33s with 0 failed devices
gui.js:38454 Flashing 1 device, 60% at 42.80 MB/s (total 42.80 MB/s) eta in 32s with 0 failed devices
gui.js:38454 Flashing 1 device, 61% at 42.90 MB/s (total 42.90 MB/s) eta in 31s with 0 failed devices
gui.js:38454 Flashing 1 device, 63% at 42.80 MB/s (total 42.80 MB/s) eta in 30s with 0 failed devices
gui.js:38454 Flashing 1 device, 63% at 42.70 MB/s (total 42.70 MB/s) eta in 29s with 0 failed devices
gui.js:38454 Flashing 1 device, 65% at 42.70 MB/s (total 42.70 MB/s) eta in 28s with 0 failed devices
gui.js:38454 Flashing 1 device, 66% at 42.80 MB/s (total 42.80 MB/s) eta in 27s with 0 failed devices
gui.js:38454 Flashing 1 device, 67% at 42.30 MB/s (total 42.30 MB/s) eta in 26s with 0 failed devices
gui.js:38454 Flashing 1 device, 69% at 42.90 MB/s (total 42.90 MB/s) eta in 25s with 0 failed devices
gui.js:38454 Flashing 1 device, 70% at 42.80 MB/s (total 42.80 MB/s) eta in 24s with 0 failed devices
gui.js:38454 Flashing 1 device, 71% at 42.80 MB/s (total 42.80 MB/s) eta in 23s with 0 failed devices
gui.js:38454 Flashing 1 device, 72% at 42.80 MB/s (total 42.80 MB/s) eta in 22s with 0 failed devices
gui.js:38454 Flashing 1 device, 73% at 42.80 MB/s (total 42.80 MB/s) eta in 21s with 0 failed devices
gui.js:38454 Flashing 1 device, 75% at 43.40 MB/s (total 43.40 MB/s) eta in 20s with 0 failed devices
gui.js:38454 Flashing 1 device, 76% at 42.70 MB/s (total 42.70 MB/s) eta in 19s with 0 failed devices
gui.js:38454 Flashing 1 device, 77% at 42.60 MB/s (total 42.60 MB/s) eta in 18s with 0 failed devices
gui.js:38454 Flashing 1 device, 79% at 42.70 MB/s (total 42.70 MB/s) eta in 17s with 0 failed devices
gui.js:38454 Flashing 1 device, 80% at 43.30 MB/s (total 43.30 MB/s) eta in 16s with 0 failed devices
gui.js:38454 Flashing 1 device, 82% at 42.80 MB/s (total 42.80 MB/s) eta in 14s with 0 failed devices
gui.js:38454 Flashing 1 device, 82% at 42.90 MB/s (total 42.90 MB/s) eta in 14s with 0 failed devices
gui.js:38454 Flashing 1 device, 84% at 43.00 MB/s (total 43.00 MB/s) eta in 12s with 0 failed devices
gui.js:38454 Flashing 1 device, 85% at 42.30 MB/s (total 42.30 MB/s) eta in 12s with 0 failed devices
gui.js:38454 Flashing 1 device, 86% at 42.30 MB/s (total 42.30 MB/s) eta in 11s with 0 failed devices
gui.js:38454 Flashing 1 device, 87% at 42.80 MB/s (total 42.80 MB/s) eta in 10s with 0 failed devices
gui.js:38454 Flashing 1 device, 89% at 42.80 MB/s (total 42.80 MB/s) eta in 9s with 0 failed devices
gui.js:38454 Flashing 1 device, 90% at 42.90 MB/s (total 42.90 MB/s) eta in 8s with 0 failed devices
gui.js:38454 Flashing 1 device, 91% at 42.90 MB/s (total 42.90 MB/s) eta in 6s with 0 failed devices
gui.js:38454 Flashing 1 device, 92% at 43.30 MB/s (total 43.30 MB/s) eta in 6s with 0 failed devices
gui.js:38454 Flashing 1 device, 94% at 42.80 MB/s (total 42.80 MB/s) eta in 4s with 0 failed devices
gui.js:38454 Flashing 1 device, 95% at 42.20 MB/s (total 42.20 MB/s) eta in 4s with 0 failed devices
gui.js:38454 Flashing 1 device, 96% at 42.80 MB/s (total 42.80 MB/s) eta in 2s with 0 failed devices
gui.js:38454 Flashing 1 device, 97% at 43.30 MB/s (total 43.30 MB/s) eta in 2s with 0 failed devices
gui.js:38454 Flashing 1 device, 99% at 43.30 MB/s (total 43.30 MB/s) eta in 1s with 0 failed devices
gui.js:38454 Verifying 1 device, 0% at 41.50 MB/s (total 41.50 MB/s) eta in 83s with 0 failed devices
gui.js:38454 Verifying 1 device, 2% at 41.80 MB/s (total 41.80 MB/s) eta in 81s with 0 failed devices
gui.js:38454 Verifying 1 device, 3% at 41.80 MB/s (total 41.80 MB/s) eta in 80s with 0 failed devices
gui.js:38454 Verifying 1 device, 4% at 41.80 MB/s (total 41.80 MB/s) eta in 79s with 0 failed devices
gui.js:38454 Verifying 1 device, 5% at 41.80 MB/s (total 41.80 MB/s) eta in 78s with 0 failed devices
gui.js:38454 Verifying 1 device, 6% at 41.80 MB/s (total 41.80 MB/s) eta in 77s with 0 failed devices
gui.js:38454 Verifying 1 device, 7% at 41.80 MB/s (total 41.80 MB/s) eta in 76s with 0 failed devices
gui.js:38454 Verifying 1 device, 9% at 41.80 MB/s (total 41.80 MB/s) eta in 75s with 0 failed devices
gui.js:38454 Verifying 1 device, 10% at 41.70 MB/s (total 41.70 MB/s) eta in 74s with 0 failed devices
gui.js:38454 Verifying 1 device, 11% at 41.70 MB/s (total 41.70 MB/s) eta in 73s with 0 failed devices
gui.js:38454 Verifying 1 device, 13% at 42.30 MB/s (total 42.30 MB/s) eta in 71s with 0 failed devices
gui.js:38454 Verifying 1 device, 14% at 42.30 MB/s (total 42.30 MB/s) eta in 70s with 0 failed devices
gui.js:38454 Verifying 1 device, 15% at 41.80 MB/s (total 41.80 MB/s) eta in 70s with 0 failed devices
gui.js:38454 Verifying 1 device, 16% at 41.80 MB/s (total 41.80 MB/s) eta in 69s with 0 failed devices
gui.js:38454 Verifying 1 device, 17% at 41.70 MB/s (total 41.70 MB/s) eta in 68s with 0 failed devices
gui.js:38454 Verifying 1 device, 19% at 41.80 MB/s (total 41.80 MB/s) eta in 67s with 0 failed devices
gui.js:38454 Verifying 1 device, 20% at 41.70 MB/s (total 41.70 MB/s) eta in 66s with 0 failed devices
gui.js:38454 Verifying 1 device, 21% at 41.70 MB/s (total 41.70 MB/s) eta in 65s with 0 failed devices
gui.js:38454 Verifying 1 device, 22% at 41.80 MB/s (total 41.80 MB/s) eta in 64s with 0 failed devices
gui.js:38454 Verifying 1 device, 23% at 40.70 MB/s (total 40.70 MB/s) eta in 65s with 0 failed devices
gui.js:38454 Verifying 1 device, 25% at 41.80 MB/s (total 41.80 MB/s) eta in 62s with 0 failed devices
gui.js:38454 Verifying 1 device, 26% at 41.40 MB/s (total 41.40 MB/s) eta in 61s with 0 failed devices
gui.js:38454 Verifying 1 device, 27% at 41.40 MB/s (total 41.40 MB/s) eta in 60s with 0 failed devices
gui.js:38454 Verifying 1 device, 28% at 42.40 MB/s (total 42.40 MB/s) eta in 58s with 0 failed devices
gui.js:38454 Verifying 1 device, 29% at 41.80 MB/s (total 41.80 MB/s) eta in 58s with 0 failed devices
gui.js:38454 Verifying 1 device, 31% at 41.80 MB/s (total 41.80 MB/s) eta in 57s with 0 failed devices
gui.js:38454 Verifying 1 device, 32% at 41.30 MB/s (total 41.30 MB/s) eta in 57s with 0 failed devices
gui.js:38454 Verifying 1 device, 33% at 41.70 MB/s (total 41.70 MB/s) eta in 55s with 0 failed devices
gui.js:38454 Verifying 1 device, 34% at 42.20 MB/s (total 42.20 MB/s) eta in 53s with 0 failed devices
gui.js:38454 Verifying 1 device, 35% at 41.80 MB/s (total 41.80 MB/s) eta in 53s with 0 failed devices
gui.js:38454 Verifying 1 device, 37% at 41.70 MB/s (total 41.70 MB/s) eta in 52s with 0 failed devices
gui.js:38454 Verifying 1 device, 38% at 41.70 MB/s (total 41.70 MB/s) eta in 51s with 0 failed devices
gui.js:38454 Verifying 1 device, 39% at 41.70 MB/s (total 41.70 MB/s) eta in 50s with 0 failed devices
gui.js:38454 Verifying 1 device, 41% at 41.70 MB/s (total 41.70 MB/s) eta in 49s with 0 failed devices
gui.js:38454 Verifying 1 device, 42% at 41.80 MB/s (total 41.80 MB/s) eta in 48s with 0 failed devices
gui.js:38454 Verifying 1 device, 43% at 41.80 MB/s (total 41.80 MB/s) eta in 47s with 0 failed devices
gui.js:38454 Verifying 1 device, 44% at 41.30 MB/s (total 41.30 MB/s) eta in 46s with 0 failed devices
gui.js:38454 Verifying 1 device, 46% at 41.80 MB/s (total 41.80 MB/s) eta in 44s with 0 failed devices
gui.js:38454 Verifying 1 device, 47% at 41.80 MB/s (total 41.80 MB/s) eta in 43s with 0 failed devices
gui.js:38454 Verifying 1 device, 48% at 41.20 MB/s (total 41.20 MB/s) eta in 43s with 0 failed devices
gui.js:38454 Verifying 1 device, 49% at 40.60 MB/s (total 40.60 MB/s) eta in 43s with 0 failed devices
gui.js:38454 Verifying 1 device, 50% at 41.10 MB/s (total 41.10 MB/s) eta in 41s with 0 failed devices
gui.js:38454 Verifying 1 device, 52% at 41.20 MB/s (total 41.20 MB/s) eta in 40s with 0 failed devices
gui.js:38454 Verifying 1 device, 53% at 41.30 MB/s (total 41.30 MB/s) eta in 39s with 0 failed devices
gui.js:38454 Verifying 1 device, 54% at 41.90 MB/s (total 41.90 MB/s) eta in 37s with 0 failed devices
gui.js:38454 Verifying 1 device, 55% at 41.90 MB/s (total 41.90 MB/s) eta in 36s with 0 failed devices
gui.js:38454 Verifying 1 device, 57% at 41.90 MB/s (total 41.90 MB/s) eta in 35s with 0 failed devices
gui.js:38454 Verifying 1 device, 57% at 41.80 MB/s (total 41.80 MB/s) eta in 35s with 0 failed devices
gui.js:38454 Verifying 1 device, 59% at 41.70 MB/s (total 41.70 MB/s) eta in 34s with 0 failed devices
gui.js:38454 Verifying 1 device, 60% at 41.70 MB/s (total 41.70 MB/s) eta in 33s with 0 failed devices
gui.js:38454 Verifying 1 device, 61% at 41.70 MB/s (total 41.70 MB/s) eta in 32s with 0 failed devices
gui.js:38454 Verifying 1 device, 63% at 41.60 MB/s (total 41.60 MB/s) eta in 31s with 0 failed devices
gui.js:38454 Verifying 1 device, 64% at 41.80 MB/s (total 41.80 MB/s) eta in 29s with 0 failed devices
gui.js:38454 Verifying 1 device, 65% at 41.90 MB/s (total 41.90 MB/s) eta in 29s with 0 failed devices
gui.js:38454 Verifying 1 device, 66% at 41.80 MB/s (total 41.80 MB/s) eta in 28s with 0 failed devices
gui.js:38454 Verifying 1 device, 67% at 41.70 MB/s (total 41.70 MB/s) eta in 27s with 0 failed devices
gui.js:38454 Verifying 1 device, 69% at 41.80 MB/s (total 41.80 MB/s) eta in 25s with 0 failed devices
gui.js:38454 Verifying 1 device, 70% at 41.80 MB/s (total 41.80 MB/s) eta in 25s with 0 failed devices
gui.js:38454 Verifying 1 device, 71% at 41.80 MB/s (total 41.80 MB/s) eta in 24s with 0 failed devices
gui.js:38454 Verifying 1 device, 72% at 41.20 MB/s (total 41.20 MB/s) eta in 23s with 0 failed devices
gui.js:38454 Verifying 1 device, 73% at 41.10 MB/s (total 41.10 MB/s) eta in 22s with 0 failed devices
gui.js:38454 Verifying 1 device, 74% at 41.60 MB/s (total 41.60 MB/s) eta in 21s with 0 failed devices
gui.js:38454 Verifying 1 device, 76% at 41.60 MB/s (total 41.60 MB/s) eta in 20s with 0 failed devices
gui.js:38454 Verifying 1 device, 77% at 42.20 MB/s (total 42.20 MB/s) eta in 19s with 0 failed devices
gui.js:38454 Verifying 1 device, 78% at 42.30 MB/s (total 42.30 MB/s) eta in 17s with 0 failed devices
gui.js:38454 Verifying 1 device, 79% at 41.30 MB/s (total 41.30 MB/s) eta in 17s with 0 failed devices
gui.js:38454 Verifying 1 device, 81% at 41.70 MB/s (total 41.70 MB/s) eta in 15s with 0 failed devices
gui.js:38454 Verifying 1 device, 82% at 42.20 MB/s (total 42.20 MB/s) eta in 15s with 0 failed devices
gui.js:38454 Verifying 1 device, 83% at 41.80 MB/s (total 41.80 MB/s) eta in 14s with 0 failed devices
gui.js:38454 Verifying 1 device, 84% at 42.30 MB/s (total 42.30 MB/s) eta in 13s with 0 failed devices
gui.js:38454 Verifying 1 device, 86% at 42.20 MB/s (total 42.20 MB/s) eta in 11s with 0 failed devices
gui.js:38454 Verifying 1 device, 87% at 41.80 MB/s (total 41.80 MB/s) eta in 11s with 0 failed devices
gui.js:38454 Verifying 1 device, 88% at 41.70 MB/s (total 41.70 MB/s) eta in 10s with 0 failed devices
gui.js:38454 Verifying 1 device, 89% at 41.60 MB/s (total 41.60 MB/s) eta in 9s with 0 failed devices
gui.js:38454 Verifying 1 device, 90% at 42.20 MB/s (total 42.20 MB/s) eta in 8s with 0 failed devices
gui.js:38454 Verifying 1 device, 92% at 42.30 MB/s (total 42.30 MB/s) eta in 6s with 0 failed devices
gui.js:38454 Verifying 1 device, 93% at 41.80 MB/s (total 41.80 MB/s) eta in 6s with 0 failed devices
gui.js:38454 Verifying 1 device, 94% at 41.80 MB/s (total 41.80 MB/s) eta in 4s with 0 failed devices
gui.js:38454 Verifying 1 device, 95% at 42.40 MB/s (total 42.40 MB/s) eta in 4s with 0 failed devices
gui.js:38454 Verifying 1 device, 96% at 42.30 MB/s (total 42.30 MB/s) eta in 3s with 0 failed devices
gui.js:38454 Verifying 1 device, 98% at 41.70 MB/s (total 41.70 MB/s) eta in 2s with 0 failed devices
gui.js:38454 Verifying 1 device, 99% at 41.70 MB/s (total 41.70 MB/s) eta in 1s with 0 failed devices
gui.js:38454 Verifying 1 device, 100% at 41.90 MB/s (total 41.90 MB/s) eta in 0s with 0 failed devices
gui.js:51110 Finish: 3451912192
gui.js:51110 Terminating IPC server
gui.js:51110 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:51110 Sun Aug 01 2021 20:44:05 GMT+0100 (British Summer Time) Done ({"image":{"size":3980394496,"name":"2021-05-07-raspios-buster-armhf.img","hasMBR":true,"partitions":[{"offset":4194304,"size":268435456,"type":12,"index":1},{"offset":272629760,"size":3707764736,"type":131,"index":2}],"extension":"img","path":"/Volumes/1TB WD/2021-05-07-raspios-buster-armhf.img"},"drives":[{"size":500107862016,"isVirtual":false,"enumerator":"DiskArbitration","logicalBlockSize":4096,"raw":"/dev/rdisk3","error":null,"isReadOnly":false,"displayName":"/dev/disk3","blockSize":4096,"isSCSI":false,"isRemovable":false,"device":"/dev/disk3","busVersion":null,"isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":"IODeviceTree:/PCI0@0/XHC1@14","mountpoints":[{"path":"/Volumes/Untitled","label":"Untitled"}],"description":"Netac Mobiledatastar Media","isUAS":null,"partitionTableType":"mbr"}],"driveCount":1,"uuid":"d912d44d-02a7-498b-b799-87148491233a","status":"finished","flashInstanceUuid":"d912d44d-02a7-498b-b799-87148491233a","errors":[],"devices":{"failed":0,"successful":1},"bytesWritten":3451912192,"sourceMetadata":{"size":3980394496,"name":"2021-05-07-raspios-buster-armhf.img","blocks":[{"blocks":[{"offset":0,"length":324009984}]},{"blocks":[{"offset":406847488,"length":152043520}]},{"blocks":[{"offset":563085312,"length":1929379840}]},{"blocks":[{"offset":2493513728,"length":435159040}]},{"blocks":[{"offset":2929721344,"length":8388608}]},{"blocks":[{"offset":2939158528,"length":11534336}]},{"blocks":[{"offset":2955935744,"length":1048576}]},{"blocks":[{"offset":2959081472,"length":10485760}]},{"blocks":[{"offset":2971664384,"length":1048576}]},{"blocks":[{"offset":2973761536,"length":2097152}]},{"blocks":[{"offset":2976907264,"length":3145728}]},{"blocks":[{"offset":2983198720,"length":89128960}]},{"blocks":[{"offset":3073376256,"length":5242880}]},{"blocks":[{"offset":3079667712,"length":341835776}]},{"blocks":[{"offset":3422552064,"length":1048576}]},{"blocks":[{"offset":3424649216,"length":1048576}]},{"blocks":[{"offset":3426746368,"length":63963136}]},{"blocks":[{"offset":3493855232,"length":69206016}]},{"blocks":[{"offset":3628072960,"length":1048576}]},{"blocks":[{"offset":3896508416,"length":1048576}]}],"blockmappedSize":3451912192},"sample":0.1,"applicationSessionUuid":"c340dc95-a65b-4a13-9bc7-6cd43912da87","flashingWorkflowUuid":"e8c0c07a-394d-4594-b360-242084dd9046"})
gui.js:51110 Sun Aug 01 2021 20:44:06 GMT+0100 (British Summer Time) SafeWebview loaded ({"event":{"id":25,"url":"https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.5.121&api-version=2&optOutAnalytics=false","method":"GET","timestamp":1627847045997.603,"resourceType":"mainFrame","ip":"167.99.246.105","fromCache":false,"statusLine":"HTTP/1.1 200","statusCode":200,"responseHeaders":{"age":["159628"],"cache-control":["public, max-age=0, must-revalidate"],"content-encoding":["br"],"content-length":["6086"],"content-type":["text/html; charset=UTF-8"],"date":["Fri, 30 Jul 2021 23:23:37 GMT"],"etag":["\"6db4596d932d3943745dd6542a3b6050-ssl-df\""],"link":["</webpack-runtime-6b6a39d36587a3729c45.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-42f2600cafd3c0e08aac.js>; rel=preload; as=script, </50c25a04-efe577ee14c9c53bed03.js>; rel=preload; as=script, </73ad3401-e112b47ad7a992b91ac8.js>; rel=preload; as=script, </532a2f07-16f3498dd087ee7288d4.js>; rel=preload; as=script, </app-370a4e8c56161e064dd1.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-4ae9e03f4545d4f1d61b.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-8fcc2f56d20b76e33299.js>; rel=preload; as=script, </edad6859a763f5239c0343c48608d154b87713d6-282649cf8ac0a71046b8.js>; rel=preload; as=script, </component---src-pages-etcher-success-banner-js-c81df2b0c3894e1f37af.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],"referrer-policy":["strict-origin-when-cross-origin"],"server":["Netlify"],"strict-transport-security":["max-age=31536000"],"vary":["Accept-Encoding"],"x-content-type-options":["nosniff"],"x-frame-options":["DENY"],"x-nf-request-id":["01FC1KXCT3VXMG21SH99A5R5ZB"],"x-xss-protection":["1; mode=block"]},"referrer":"","error":"net::OK"},"sample":0.1,"applicationSessionUuid":"c340dc95-a65b-4a13-9bc7-6cd43912da87","flashingWorkflowUuid":"e8c0c07a-394d-4594-b360-242084dd9046"})
Any advice please? Ive been at this for days now!
