Strange Partition Dimension
Hi everybody, i’m new here so please be nice :slight_smile:
I’m using balenaEtcher for a long time and i think it’s a very great piece of code!
I’m facing a strange issue that i would like to discuss with you.
I’m burning the urbackup restore image ( https://hndl.urbackup.org/Restore/urbackup_restore_2.3.1.iso ): the burning process works well, and the image works fine too but in the Disk management in windows (also fdisk in linux) shows that the partition dimension is just 3MB! (consider that the image is at least 200MB).
Moreover, if i try to create a new partition in the spare space, windows and linux do that, but the usb pen drive will become unbootable: it seems that the operation of creating a new partition overwrites the first partition (maybe because the size is incorrect?)
I also discovered that the old urbackup images works fine (for example this https://hndl.urbackup.org/Restore/urbackup_restore_2.1.1.iso ).
Could you please point me to an idea to solve this issue?
I don’t think it’s a urbackup issue: the image works fine itself.
Hey, we just flashed the same image you shared with us on an SD card. In our case we have obtained different results:
0:     FDisk_partition_scheme                        *31.9 GB    disk2
1:                       0x17                         247.4 MB   disk2s1
2:                 DOS_FAT_12 NO NAME                 30.6 MB    disk2s2
Given the different results, may I ask you to show us the powershell output of Get-Disk or Get-Disk | Where-Object -FilterScript {$_.Bustype -Eq "USB”}? would you also have the opportunity to try with another SD/USB in case the suggested command do not give us the expected result ?
@JSReds first of all thank you for answering me.
I guess you mean, Get-Partition, because Get-Disk gives me this result:
get-disk
Number Friendly Name Serial Number HealthStatus OperationalStatus Total Size Partition
Style
0 INTEL SSDS… BTLA82550EMF512K Healthy Online 476.94 GB GPT
1 Innodisk U… AA00000000000489 Healthy Online 30.22 GB MBR
Instead if i run Get-Partition
Get-Partition
DiskPath: \?\scsi#disk&ven_intel&prod_ssdsckkf512g8#4&68c9c9f&0&000200#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
PartitionNumber DriveLetter Offset Size Type
1 1048576 650 MB System
2 682622976 128 MB Reserved
3 C 816840704 475.2 GB Basic
4 511057068032 990 MB Recovery
DiskPath:
\?\usbstor#disk&ven_innodisk&prod_usb_drive_3me&rev_0917#20180717a67105500005&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
1 362496 2.78 MB Unknown
Ok, i’ve tried also with a different disk (16GB instead of the previous one that was a 32GB) but the result is the same:
Get-Partition
DiskPath: \?\usbstor#disk&ven_kingston&prod_datatraveler_2.0&rev_1.00#0019e02b7592a8c0cfff00ea&0#{53f56307-b6bf-11d
1 D 362496 2.78 MB Unknown
I’m running balenaEtcher 1.4.9 on Windows 10
Hey,
yes I’m sorry I meant Get-Partition.
I did a test also on windows 10 with the latest version of etcher v1.5.79 and the result is the following:
DiskPath:
\\?\usbstor#disk&ven_ts-rdf5&prod_sd__transcend&rev_ts3a#000000000037&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
1                H           32768                                    235.97 MB Unknown
2                            247463936                                 29.22 MB FAT12
Could you please try again by installing the latest version of etcher ?
@JSReds same even with the lastest version
could you please try with a USB mass storage instead of a SD card?
Hey, I did a test also with a USB and that’s the result:
DiskPath:
\\?\usbstor#disk&ven_sandisk&prod_cruzer_edge&rev_1.27#2005244383190d61469e&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
2                I           247463936                                 29.22 MB FAT12
would you by chance have the option to output fdisk -l ?
fdisk seems fine
VirtualBox_2E000300 - Modula Copilot 10_13_03_2020_12_14_26
and if create a new partition from linux
[sorry i can put only image in a post because i’m a new user (forum limitations)]
VirtualBox_2E000300 - Modula Copilot 10_13_03_2020_12_17_11
windows show me right
Unbelievable. Do you have any explanations? I should allow my users to create a partition directly from windows :frowning:
Hey, speaking with the Etcher team, we understood that I see the second partition since deamontools is installed on my PC. What you see is therefore normal, since it is an ISO image. The difference is that etcher copies your disk image to your USB drive and the first bytes of this disk image contain the partition table, while if you create a partition on linux, this partition table is updated or recreated, depends on how you do it.
For more information about it you can have a look here: https://unix.stackexchange.com/questions/259446/how-to-understand-partition-table-on-hybrid-iso-image
I hope that I have been useful to you. Do not hesitate to contact us for any other doubts.
Thanks @JSReds , so what do you suggest in order to create a new partition after burning the iso in Windows? Installing daemontools could help to achieve the result?
To create a partition you don’t need deamontools installed, you only need it if you want to have a correct view when you run the Get-Partition command.
To create a partition using windows you can use DiskPart tool, and to open it you can do the following:
Step 1. Press “Win + R” to open Run box, and input “cmd” in it and hit Enter to open Command Prompt.
Step 2. Type “disk part” and press Enter to open the Diskpart tool.
this is an exampe:
DISKPART> list disk
  N. disk  Status          Dimensions     Availability    Din  GPT
  Disk 0    Online            931 Gbytes         0 byte        *
  Disk 1    Online            238 Gbytes         0 byte        *
  Disk 2    Online             58 Gbytes      58 Gbytes
DISKPART> select Disk 2
Disk 2 is now the selected disk.
DISKPART> list partition
  Partition ###   Type              Dim.     Offset
  Partition 1    Primary           235 Mb    32 Kb
  Partition 2    Primary            29 Mb   236 Mb
DISKPART> create partition primary size=100
Creation of the specified partition completed.
* Partition 0    Primary             100 Mb   266 Mb
Others solutions can be found here:
https://www.diskpart.com/articles/create-bootable-partition-from-iso-1984.html
with DiskPart i have always the same result:
DISKPART> select disk 1
Il disco attualmente selezionato è il disco 1.
Partizione ### Tipo Dim. Offset
Partizione 1 Sistema 2848 Kb 354 Kb
Hey,
in our opinion changing the partition table, the USB key would no longer boot. Unfortunately we can’t tell you for sure what makes those partitions been visible on my windows version. Having said that, unfortunately we cannot help you further on this point as it comes out of our skills.
I’m sorry I wasn’t able to help you as I would.
I wish you a good weekend
Hi @JSReds, i solved it myself, let’s check here http://robertoviola.cloud/2020/03/18/add-a-data-partition-to-a-live-usb-iso/
Thanks again for you support!
Have a nice day!
I’m glad you managed to solve the problem, thank you very much for sharing your research and solution to us.
Remaining at your disposal, I wish you a good day!
