I flashed it with the nuc development image. While it goes online somehow, balenaCloud tells me:
host os version unknown
supervisor version empty
ip address empty
When I try to balena ssh, I get:
error: The device '2c4d2fd7f825348523bf535040ecc285' does not support direct host OS access,
please update the device to at least version balenaOS '2.7.5'
Connection to ssh.balena-devices.com closed.
Hello @bvetter,
Are you using the latest intel-nuc image from the balenaCloud dashboard?
Can you try to ssh into the device using ssh root@2c4d2fd.local -p 22222 using an ssh client(not balena ssh) ?
If you are able to ssh into it, you can retrieve the supervisor logs from the device using journalctl -u resin-supervisor --no-pager and paste it here so we have more context what is going on?
the image I used is the latest image from the balenaCloud dashboard. I used a Debian based live USB image to boot the device and flashed the image using dd.
I cannot ssh into the device:
➜ aim-balena-aimbox git:(master) ssh root@25c7929.local -p 22222
ssh_exchange_identification: read: Connection reset by peer
ssh: connect to host 25c7929.local port 22222: Connection refused
It seems the device is stuck in the middle of bootstrapping. Every time I power cycle it, the creates a new device in balenaCloud, but still with the OS info empty. The previously created devices stay orphaned.
I’m not familiar with the device you are trying to flash, but if it behaves in a similar way to the intel NUC then you can use etcher to flash your balenaOS image to a usb stick, and then boot the device from the usb stick (following the steps from the NUC getting started guide https://www.balena.io/docs/learn/getting-started/intel-nuc/nodejs/#provision-device ).
The balenaOS images for NUC will flash the internal storage on first startup from the USB stick.
Ok. If that is the standard installation procedure, maybe it was my fault. I flashed the image directly to the ssd. If the nuc image expects to re-install itself after boot, I probably got confused by what I did.
Interestingly, balenaCloud now displays a new error message for my faulty device: Failed to find any block devices.
I will now proceed as you suggested and give you a feedback.
Bruno
Glad it’s sorted out!
Don’t hesitate to write again if you need anything else though it’s not that difficult to oversee something, even if it’s in the docs.
