Hey there, I’ve been trying to get my feet wet with BalenaOS.
I just got myself an Intel NUC, and I’ve been trying to follow the instructions at https://www.balena.io/os/docs/intel-nuc/getting-started/ using the current (2.50.1 rev1) Intel NUC dev image. While not everything happens preceisely as described, things seem to work up until the push.
When I try to “balena push balena.local”, I get
Could not communicate with local mode device at address 192.168.1.113
Additional information may be available with the `--debug` flag.
For help, visit our support forums: https://forums.balena.io
For bug reports or feature requests, see: https://github.com/balena-io/balena-cli/issues/
And with the --debug flag I get this:
Missing applicationOrDevice
Error: Missing applicationOrDevice
at C:\Program Files\balena-cli\client\node_modules\capitano\build\signature.js:150:29
at C:\Program Files\balena-cli\client\node_modules\capitano\node_modules\async\lib\async.js:181:20
at Immediate.iterate (C:\Program Files\balena-cli\client\node_modules\capitano\node_modules\async\lib\async.js:262:13)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
Looking at some older posts, I logged in using ssh and ran a few commands. Firstly, I noticed that when I asked for the “balena-engine version”, there seemed to be a problem with the engine daemon:
Client:
Version: 18.09.17-dev
API version: 1.39
Go version: go1.10.8
Git commit: 2ab17e0536b6a4528b33c75e8f350447e9882af0
Built: Mon May 11 15:17:45 2020
OS/Arch: linux/amd64
Experimental: false
Cannot connect to the balenaEngine daemon at unix:///var/run/balena-engine.sock. Is the balenaEngine daemon running?
Then, running some commands from an earlier post:
root@balena:~# balena-engine ps -a
root@balena:~# journalctl -u resin-supervisor --no-pager
-- Logs begin at Tue 2020-07-21 23:28:47 UTC, end at Tue 2020-07-21 23:56:45 UTC. --
Jul 21 23:35:21 localhost systemd[1]: Dependency failed for Balena supervisor.
Jul 21 23:35:21 localhost systemd[1]: resin-supervisor.service: Job resin-supervisor.service/start failed with result 'dependency'.
Jul 21 23:43:41 balena systemd[1]: Dependency failed for Balena supervisor.
Jul 21 23:43:41 balena systemd[1]: resin-supervisor.service: Job resin-supervisor.service/start failed with result 'dependency'.
So, I’m hoping that someone can give me a hand, and help me to work out what’s up.
(A bit of honesty, I’ve also tried using Balena Cloud, but been unable to get past post provisioning; I’ve returned to this, as it seems more self-contained.)
Update: I have also noticed that when I restart the machine (after doing a “shutdown now” from the ssh logon), it still takes a very lonig time doing the “expand resin-data partition” step (perhaps half an hour or so). Is that to be expected? It feels like this is indicating something hasn’t been fully set up at this point.
Take care,
Caligari
