Yikes! I might be in over my head.
I was wondering if anyone could help me streamline my steps for success because I’m running into problems but it might be a fundamental misunderstanding of this project.
Goals: Use the hardware I have to build a multi room sync sound system.
Assets:
New Raspberry Pi4 4GB with 128GB SD Card
NUC(s) multiple versions
USB drives
CLEAN network using a default settings router (192, DHCP, PnP, etc) - The only items on this network will be the sound devices and my phone so I can cast Spotify to it. *(this is where I landed last night after troubleshooting for a long time) - I started on a VLAN of my Unifi network where I normally build projects for my tutorials.
My steps:
Created balena account
created NUC fleet
created raspberry pi4 (64bit OS) fleet (Here is my exact model of Pi)
I used Etcher to flash a new SD card which I then put into my Pi.
Here are the settings I used to flash the SD card: Imgur: The magic of the Internet
Next I connected the Pi via ethernet (I even swapped this out at one point) directly to my router.
I can see the device in my console so I believe it has booted and is working. However, it does not seem to be doing anything. It just says: “starting supervisor” Imgur: The magic of the Internet
So, I switched to one of my NUC devices. This one is a NUC5i5MYHE (I have used this as a PLEX server in some of my tutorials) and I wiped the drive just for this project.
I started by going back and creating a new fleet. I chose IntelNUC. I added a device with these settings Imgur: The magic of the Internet
I flashed a USB drive using ETCHER and USB booted the NUC to the USB. I then rebooted the NUC with it directly connected to the network via ETHERNET. I can see it in the console. Imgur: The magic of the Internet
However, it has many failures and restarts. I think I might not have the right NUC.
I really want to get the bare bones “working” tutorial made before the weekend as a deadline. Is it possible you can trim down for me even further? What do I need to do to get this working? I have other hardware. I can try other things. So far I haven’t had any luck deploying this.
Thank you very much for you help.
I accidentally cross posted this when I was having NUC problems. Mods can delete that post. I don’t think I can be helped there.
Thank you!
