Elevating command: C:\Users\deepak sharda\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\deepak sharda\AppData\Local\Programs\balena-etcher\resources\app
gui.js:5613 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:122098 Successfully connected to IPC server: etcher-server-8760, socket root C:\Users\DEEPAK~1\AppData\Local\Temp
gui.js:122098 Image: C:\Users\deepak sharda\Downloads\ubuntu-20.04-desktop-amd64.iso
gui.js:122098 Devices: \.\PhysicalDrive2
gui.js:122098 Umount on success: true
gui.js:122098 Validate on success: true
gui.js:122098 Auto blockmapping: true
gui.js:122098 Decompress first: true
gui.js:122098 Thu Jun 04 2020 11:04:07 GMT+0530 (India Standard Time) SafeWebview loaded ({“event”:{“id”:1,“url”:“https://assets.balena.io/etcher-featured/index.html?etcher-version=1.5.95&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1591248847297.048,“resourceType”:“mainFrame”,“ip”:“104.31.82.157”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:["*"],“age”:[“145”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“59df4879a96706e1-LHR”],“cf-request-id”:[“031f6ba00c000006e1540e4200000001”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Thu, 04 Jun 2020 05:34:08 GMT”],“expect-ct”:[“max-age=604800, report-uri=“https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct””],“expires”:[“Wed, 03 Jun 2020 04:27:29 GMT”],“last-modified”:[“Mon, 01 Jun 2020 19:09:20 GMT”],“server”:[“cloudflare”],“status”:[“200”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“e8f83e9722bda0959d4748bf8f3edbf0601f5e61”],“x-github-request-id”:[“A746:1BA6:B09E08:D9AE9C:5ED72458”],“x-origin-cache”:[“HIT”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-lcy19237-LCY”],“x-timer”:[“S1591248849.925974,VS0,VE1”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“d84ca668-2950-47e0-8f4e-b7bd1d2ab39b”,“flashingWorkflowUuid”:“11644bf5-3469-43d9-a210-e528fbe55640”})
gui.js:122098 Thu Jun 04 2020 11:04:17 GMT+0530 (India Standard Time) Flash error ({“image”:“C:\Users\deepak sharda\Downloads\ubuntu-20.04-desktop-amd64.iso”,“drives”:[{“size”:8166703104,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive2",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“hp v165w USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“98fbc7b1-4d30-4ad4-adeb-c7edf8122652”,“flashInstanceUuid”:“98fbc7b1-4d30-4ad4-adeb-c7edf8122652”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“name”:“Error”,“message”:“Couldn’t clean the drive, spawn diskpart ENOENT (code ENOENT)”,“stack”:“Error: Couldn’t clean the drive, spawn diskpart ENOENT (code ENOENT)\n at Object.exports.clean (C:\Users\deepak sharda\AppData\Local\Programs\balena-etcher\resources\app\generated\etcher.js:54612:27)\n at async BlockDevice._open (C:\Users\deepak sharda\AppData\Local\Programs\balena-etcher\resources\app\generated\etcher.js:20269:13)\n at async BlockDevice.open (C:\Users\deepak sharda\AppData\Local\Programs\balena-etcher\resources\app\generated\etcher.js:7350:21)\n at async deepak sharda\AppData\Local\Programs\balena-etcher\resources\app\generated\etcher.js:27354:21”},“sample”:0.1,“applicationSessionUuid”:“d84ca668-2950-47e0-8f4e-b7bd1d2ab39b”,“flashingWorkflowUuid”:“11644bf5-3469-43d9-a210-e528fbe55640”})
gui.js:122098 Finish: 0
gui.js:122098 Terminating IPC server
gui.js:122098 Flash results {results: {…}, cancelled: false}cancelled: falseresults: {bytesWritten: 0, devices: {…}, errors: Array(1), sourceMetadata: {…}}proto: Object
gui.js:122098 Thu Jun 04 2020 11:04:17 GMT+0530 (India Standard Time) Write failed ({“image”:“C:\Users\deepak sharda\Downloads\ubuntu-20.04-desktop-amd64.iso”,“drives”:[{“size”:8166703104,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive2",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“hp v165w USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“98fbc7b1-4d30-4ad4-adeb-c7edf8122652”,“status”:“failed”,“flashInstanceUuid”:“98fbc7b1-4d30-4ad4-adeb-c7edf8122652”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“description”:“Please try again, and contact the Etcher team if the problem persists”,“report”:false,“code”:“ECHILDDIED”},“sample”:0.1,“applicationSessionUuid”:“d84ca668-2950-47e0-8f4e-b7bd1d2ab39b”,“flashingWorkflowUuid”:“11644bf5-3469-43d9-a210-e528fbe55640”})
Hi, thanks for posting the log of the failed etcher run. To help us diagnose the issue please try running the following commands and paste the result of each.
diskpartwhere diskpart
Thank you.
Hey.
Did you have success using Etcher in the end?
i did it with poweriso. easy to handle.worked foe me.
