I’m having trouble flashing batocera image to a system NVME drive (not windows drive). I’ve formatted the drive, running as admin, windows defender off. Here is the log, any ideas?
Failed to load resource: net::ERR_FILE_NOT_FOUND
gui.js:354 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.18.11, Type = nsis
gui.js:37 Elevating command: C:\Users\DANA4SFX\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\DANA4SFX\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js
gui.js:37 Error: Error invoking remote method ‘disable-screensaver’: No handler registered for ‘disable-screensaver’
at o.invoke (node:electron/js2c/renderer_init:57:526)
(anonymous) @ gui.js:37
gui.js:37 Successfully connected to IPC server: etcher-server-6808, socket root C:\Users\DANA4SFX\AppData\Local\Temp
gui.js:37 Image: C:\Users\DANA4SFX\Downloads\batocera-x86_64-x86_64-38-20231014.img
gui.js:37 Devices: \.\PhysicalDrive0
gui.js:37 Auto blockmapping: true
gui.js:37 Decompress first: true
gui.js:35 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:37 Finish: 0
gui.js:37 Terminating IPC server
gui.js:37 Flash results Object
gui.js:37 Error: Error invoking remote method ‘enable-screensaver’: No handler registered for ‘enable-screensaver’
logException @ gui.js:37
(anonymous) @ gui.js:354
gui.js:37 Finish: 0
gui.js:37 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:37 Finish: 0
