Strange messages in log file
Hi!
I just upgraded to OS v2.12.6+rev 1 (prod) and now I’m getting this strange message in the log file.
05.05.18 15:56:55 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:56:55 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:56:56 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:56:56 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:56:57 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:56:57 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:56:57 (+0100) [TTN Gateway]: Resetting concentrator on pin 22
05.05.18 15:56:58 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:56:58 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:56:58 (+0100) 14:56:58 *** Multi Protocol Packet Forwarder for Lora Gateway ***
05.05.18 15:56:58 (+0100) Version: 3.0.10
05.05.18 15:56:58 (+0100) 14:56:58 *** Lora concentrator HAL library version info ***
05.05.18 15:56:58 (+0100) Version: 5.0.1; Options: native;
05.05.18 15:56:58 (+0100) ***
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Little endian host
05.05.18 15:56:58 (+0100) 14:56:58 INFO: found global configuration file global_conf.json, parsing it
05.05.18 15:56:58 (+0100) 14:56:58 INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
05.05.18 15:56:58 (+0100) 14:56:58 INFO: lorawan_public 1, clksrc 1
05.05.18 15:56:58 (+0100) 14:56:58 INFO: no configuration for LBT
05.05.18 15:56:58 (+0100) 14:56:58 INFO: antenna_gain 0 dBi
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Configuring TX LUT with 16 indexes
05.05.18 15:56:58 (+0100) 14:56:58 INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1
05.05.18 15:56:58 (+0100) 14:56:58 INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
05.05.18 15:56:58 (+0100) 14:56:58 INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
05.05.18 15:56:58 (+0100) 14:56:58 INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
05.05.18 15:56:58 (+0100) 14:56:58 INFO: gateway MAC address is configured to B827EBFFFE8D952B
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Found 1 servers in array.
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Server 0 configured to “bridge.eu.thethings.network”
05.05.18 15:56:58 (+0100) 14:56:58 INFO: packets received with a valid CRC will be forwarded
05.05.18 15:56:58 (+0100) 14:56:58 INFO: packets received with a CRC error will NOT be forwarded
05.05.18 15:56:58 (+0100) 14:56:58 INFO: packets received with no CRC will NOT be forwarded
05.05.18 15:56:58 (+0100) 14:56:58 INFO: GPS serial port path is configured to “/dev/ttyAMA0”
05.05.18 15:56:58 (+0100) 14:56:58 INFO: GPS is enabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Using real GPS if available.
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Upstream data is enabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Downstream data is enabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Ghoststream data is disabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Radiostream data is enabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Statusstream data is enabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Beacon is disabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Monitor is disabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Packet logger is disabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Flush output after statistic is disabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Flush after each line of output is disabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Watchdog is disabled
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Contact email configured to "mariusz_adamczyk@msn.com"
05.05.18 15:56:58 (+0100) 14:56:58 INFO: Description configured to “RPi3-ic880a-2”
05.05.18 15:56:58 (+0100) 14:56:58 INFO: [main] TTY port /dev/ttyAMA0 open for GPS synchronization
05.05.18 15:56:58 (+0100) 14:56:58 INFO: [Transports] Initializing protocol for 1 servers
05.05.18 15:56:58 (+0100) 14:56:58 INFO: [TTN] server “bridge.eu.thethings.network” connected
05.05.18 15:56:58 (+0100) 14:56:58 INFO: [main] Starting the concentrator
05.05.18 15:56:58 (+0100) 14:56:58 ERROR: [main] failed to start the concentrator
05.05.18 15:56:59 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:56:59 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:00 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:00 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:01 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:01 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:02 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:02 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:03 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:03 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:04 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:04 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:05 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:05 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:06 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:06 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:07 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:07 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:08 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:08 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:09 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:09 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:10 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:10 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:10 (+0100) [TTN Gateway]: Resetting concentrator on pin 22
05.05.18 15:57:10 (+0100) 14:57:10 *** Multi Protocol Packet Forwarder for Lora Gateway ***
05.05.18 15:57:10 (+0100) Version: 3.0.10
05.05.18 15:57:10 (+0100) 14:57:10 *** Lora concentrator HAL library version info ***
05.05.18 15:57:10 (+0100) Version: 5.0.1; Options: native;
05.05.18 15:57:10 (+0100) ***
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Little endian host
05.05.18 15:57:10 (+0100) 14:57:10 INFO: found global configuration file global_conf.json, parsing it
05.05.18 15:57:10 (+0100) 14:57:10 INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
05.05.18 15:57:10 (+0100) 14:57:10 INFO: lorawan_public 1, clksrc 1
05.05.18 15:57:10 (+0100) 14:57:10 INFO: no configuration for LBT
05.05.18 15:57:10 (+0100) 14:57:10 INFO: antenna_gain 0 dBi
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Configuring TX LUT with 16 indexes
05.05.18 15:57:10 (+0100) 14:57:10 INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1
05.05.18 15:57:10 (+0100) 14:57:10 INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
05.05.18 15:57:10 (+0100) 14:57:10 INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
05.05.18 15:57:10 (+0100) 14:57:10 INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
05.05.18 15:57:10 (+0100) 14:57:10 INFO: gateway MAC address is configured to B827EBFFFE8D952B
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Found 1 servers in array.
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Server 0 configured to “bridge.eu.thethings.network”
05.05.18 15:57:10 (+0100) 14:57:10 INFO: packets received with a valid CRC will be forwarded
05.05.18 15:57:10 (+0100) 14:57:10 INFO: packets received with a CRC error will NOT be forwarded
05.05.18 15:57:10 (+0100) 14:57:10 INFO: packets received with no CRC will NOT be forwarded
05.05.18 15:57:10 (+0100) 14:57:10 INFO: GPS serial port path is configured to “/dev/ttyAMA0”
05.05.18 15:57:10 (+0100) 14:57:10 INFO: GPS is enabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Using real GPS if available.
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Upstream data is enabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Downstream data is enabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Ghoststream data is disabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Radiostream data is enabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Statusstream data is enabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Beacon is disabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Monitor is disabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Packet logger is disabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Flush output after statistic is disabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Flush after each line of output is disabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Watchdog is disabled
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Contact email configured to "mariusz_adamczyk@msn.com"
05.05.18 15:57:10 (+0100) 14:57:10 INFO: Description configured to “RPi3-ic880a-2”
05.05.18 15:57:10 (+0100) 14:57:10 INFO: [main] TTY port /dev/ttyAMA0 open for GPS synchronization
05.05.18 15:57:10 (+0100) 14:57:10 INFO: [Transports] Initializing protocol for 1 servers
05.05.18 15:57:10 (+0100) 14:57:10 INFO: [TTN] server “bridge.eu.thethings.network” connected
05.05.18 15:57:10 (+0100) 14:57:10 INFO: [main] Starting the concentrator
05.05.18 15:57:10 (+0100) 14:57:10 ERROR: [main] failed to start the concentrator
05.05.18 15:57:11 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:11 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:12 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:12 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:13 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:13 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:14 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:14 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:15 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:15 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:16 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:16 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:17 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:17 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:18 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:18 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:19 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:19 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:20 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:20 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:21 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:21 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:22 (+0100) Applying configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
05.05.18 15:57:22 (+0100) Applied configuration change {“RESIN_HOST_LOG_TO_DISPLAY”:“false”}
How can I stop it?
Thanks in advance.
Hello, can you try removing “RESIN_HOST_LOG_TO_DISPLAY” from config vars?
