Sonic Dip Stick
Sonic Dipstick
This is my project for measuring oil levels with raspberry pi
Background
I have 300 gallon oil tank, just like a lot of homes out in the county. It’s down in the basement, and it has one of those pretty standard tank liquid level gauges. This means I have to go down to the basement and check it every now and then which is not optimal.
So I’m working on using my Raspberry Pi and a PING))) Ultrasonic Distance Sensor to take measurements at regular intervals, and record them to a database. I then display the data on a website using ExpressJS also running on my RPI.
This first step is to create a module specifically for taking the measurements.
Deployment Options
Option 1:Resin.io] (Recommended)
Setup
Follow the Getting Started
When you get to the Deploy Code part, swap their simple-server-node repository with this one
git clone git@github.com:mckaycr/sonicdipstick.git
Once the repo is cloned, change directory into the newly created sonicdipstick directory and add the resin git remote endpoint by running the command git remote add shown in the top-right corner of your application page:
cd sonicdipstick
git remote add resin <USERNAME>@git.resin.io:<USERNAME>/<APPNAME>.git
From there just continue following the Deploy Code guide again, and your oil sensor should be deployed
Option 2:Install yourself on a raspberry pi
Prerequisites
sudo apt install -y python-dev python-rpi.gpio
Setup
cd sonicdipstick
npm install
sudo npm test
sudo npm start
Remember that in order to use the GPIO pins you must run your app as sudo.
Usage
In your browser go to:
http://<IPADDRESS>/check
Results
{ date: '08/05/2016',
  inches: 130.75472259521484,
  time: '01:16:49' }
Home-Assistant Integration
It is super simple to integrate this sensor into Home Assistant.
I’m not really going to go into how to set up home assistant, so follow their Getting Started guide.
Once you are up and running edit your configuration.yaml file by adding the following under sensor:
  - platform: rest
    resource: http://<IPADDRESS>/check
    unit_of_measurement: 'inches'
    value_template: '{{ value_json.data | round(0)}}'
    scan_interval: 3600
Then restart Home Assistant, and you should start seeing your oil measurements.
Cool!
Don’t suppose you’d mind pointing the PING))) at a half-full garbage can would you? One of my idle thought projects is to see if one could tell when a garbage can needs emptying.
I could sure try, however I have never seen my trash half full, its either full or overflowing.
Very cool! I’m guessing that this is the PING))) mentioned. Keep thinking of cases around the house to reuse this - and the Home Assistant integration is a really nice touch!
Yes, the PING))) Ultrasonic Distance Sensor, I point it down at the oil and it measures how far down the oil level is. Based on that measurement and the size of the tank, I get a rough estimate as to how much oil is left.
The Home Assistant saved me from having to develop my own UI, and datastore solution. I know these are all easy tasks, but they just weren’t what I wanted to focus my time on. Home Assistant does both including charting measurements over time.
Here is a picture of my current interface, should you not integrate with Home Assistant
