Hello, I recently installed the Balena Sound on my raspberry pi 3B and I have been using Spotify Connect connected to the Raspberry P2 with the home theater. I noticed that the volume on Spotify Connect is low, especially in relation to other P2 devices or Bluetooth / AirPlay connections.
I’ve tried a few things, for example: DISABLE_MULTI_ROOM = 1, SOUND_VOLUME = 98 and SYSTEM_OUTPUT_VOLUME = 98, but Spotify Connect still has the lowest volume. Any idea how to solve this?
UPDATE: I solved the “problem” as follows, Environment variable -> SOUND_SPOTIFY_DISABLE_NORMALISATION = 1 and SOUND_SPOTIFY_BITRATE = 320. I also set SOUND_DISABLE_BLUETOOTH = 1 (to disable Bluetooth because it is not useful for me, but I don’t know if it made any difference in volume increase)
