Thanks for the swift response. I’m using an Anker B2620 dual charger capable of supplying 2.4A total, with the balenasound Pi4 and another Pi2.1 connected.
As far as I can tell, the Pi4 shouldn’t draw more than about 1.2-1.3A under full load, and the Pi2 should be under 500mA, which is well within the limits of the charger. Does that sound right to you? I’m happy to try another charger.
Here’s the contents of the /support link:
{“version”:“3.8.4”,“config”:{“mode”:“MULTI_ROOM”,“device”:{“ip”:“192.168.0.38”,“type”:“raspberrypi4-64”},“multiroom”:{“master”:“192.168.0.38”,“forced”:false},“audioBlock”:{"_events":{},"_eventsCount":2,“pulseCookie”:{“type”:“Buffer”,“data”:[115,117,98,115,99,114,105,98,101,0,0,0,0,0,0,0,184,242,127,163,127,0,0,0,32,210,31,163,127,0,0,0,9,0,0,0,0,0,0,0,122,177,233,199,1,0,0,0,91,6,0,0,168,1,0,0,48,210,31,163,127,0,0,0,92,6,0,0,43,0,0,0,8,210,31,163,127,0,0,0,80,210,31,163,127,0,0,0,0,0,0,0,0,0,0,0,248,191,31,163,127,0,0,0,0,0,0,0,0,0,0,0,232,207,31,163,127,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,232,209,31,163,127,0,0,0,0,0,0,0,0,0,0,0,176,210,31,163,127,0,0,0,0,0,0,0,0,0,0,0,192,210,31,163,127,0,0,0,0,0,0,0,0,0,0,0,208,210,31,163,127,0,0,0,0,0,0,0,0,0,0,0,122,6,0,0,55,7,0,0,0,0,0,0,2,0,0,0,2,1,1,129,18,0,0,0,1,0,0,0,127,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]},“connected”:true,“chunks”:,“requests”:,“lastRequestId”:67,“pulseAddress”:{“port”:4317,“host”:“192.168.0.38”},“address”:“tcp:192.168.0.38:4317”,“subToEvents”:true,“name”:“BalenaAudio”,“socket”:{“connecting”:false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{“objectMode”:false,“highWaterMark”:16384,“buffer”:{“head”:null,“tail”:null,“length”:0},“length”:0,“pipes”:,“flowing”:false,“ended”:false,“endEmitted”:false,“reading”:true,“sync”:false,“needReadable”:true,“emittedReadable”:false,“readableListening”:true,“resumeScheduled”:false,“errorEmitted”:false,“emitClose”:false,“autoDestroy”:false,“destroyed”:false,“errored”:null,“closed”:false,“closeEmitted”:false,“defaultEncoding”:“utf8”,“awaitDrainWriters”:null,“multiAwaitDrain”:false,“readingMore”:false,“dataEmitted”:true,“decoder”:null,“encoding”:null},"_events":{},"_eventsCount":4,"_writableState":{“objectMode”:false,“highWaterMark”:16384,“finalCalled”:false,“needDrain”:false,“ending”:false,“ended”:false,“finished”:false,“destroyed”:false,“decodeStrings”:false,“defaultEncoding”:“utf8”,“length”:0,“writing”:false,“corked”:0,“sync”:false,“bufferProcessing”:false,“writecb”:null,“writelen”:0,“afterWriteTickInfo”:null,“buffered”:,“bufferedIndex”:0,“allBuffers”:true,“allNoop”:true,“pendingcb”:0,“prefinished”:false,“errorEmitted”:false,“emitClose”:false,“autoDestroy”:false,“errored”:null,“closed”:false,“closeEmitted”:false,“writable”:true},“allowHalfOpen”:false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"",“server”:null,"_server":null},“defaultSink”:“balena-sound.input”}},“audio”:{“name”:“pulseaudio”,“version”:“15.0”,“user”:“root”,“hostname”:“503f8ba2f194”,“sampleSpec”:{“format”:3,“channels”:2,“rate”:44100},“defaultSink”:“balena-sound.input”,“defaultSource”:“alsa_output.usb-soundcard-1.analog-stereo.monitor”,“cookie”:2217375553,“channelMap”:{“channels”:2,“types”:[1,2]}},“sinks”:,“volume”:100,“constants”:{“debug”:false,“port”:80,“coteDelay”:5000,“mode”:“MULTI_ROOM”,“balenaDeviceType”:“raspberrypi4-64”,“multiroom”:{“forced”:false,“pollInterval”:60000,“disallowUpdates”:false},“volume”:100,“inputSink”:“balena-sound.input”}}
