There is an issue that continuously arises when I try flashing my SD Card, could I please get some urgent help on the same?
Mon Mar 14 2022 12:40:05 GMT+0530 (India Standard Time) Drive unplugged ({“image”:{“size”:31888244736,“compressedSize”:1308400195,“hasMBR”:true,“path”:“C:\Users\jayanap\Desktop\DCC-400933\fluid_pie1_160318.gz”,“partitions”:[{“offset”:1048576,“size”:104857600,“type”:12,“index”:1},{“offset”:105906176,“size”:31782338560,“type”:131,“index”:2}],“isCompressed”:true,“name”:“fluid_pie1_160318”,“isSizeEstimated”:true,“extension”:“gz”},“drives”:[{“size”:7826571264,“isVirtual”:false,“enumerator”:“PCISTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:true,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“SCSI”,“isCard”:false,“isUSB”:false,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“SDHC Card”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“84e4a265-924f-4ec5-a743-45c1ea9303ce”,“flashInstanceUuid”:“84e4a265-924f-4ec5-a743-45c1ea9303ce”,“sample”:0.1,“applicationSessionUuid”:“e2314944-1202-428b-9061-8e9e51820d4e”,“flashingWorkflowUuid”:“2e372e2d-589c-419f-8182-2ebebea20286”})
gui.js:35 Flashing 0 devices, 24% at 21.90 MB/s (total 0.00 MB/s) eta in 1099s with 1 failed device
gui.js:46 Finish: 7825522688
gui.js:46 Terminating IPC server
gui.js:46 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:46 Mon Mar 14 2022 12:40:09 GMT+0530 (India Standard Time) Done ({“image”:{“size”:31888244736,“compressedSize”:1308400195,“hasMBR”:true,“path”:“C:\Users\jayanap\Desktop\DCC-400933\fluid_pie1_160318.gz”,“partitions”:[{“offset”:1048576,“size”:104857600,“type”:12,“index”:1},{“offset”:105906176,“size”:31782338560,“type”:131,“index”:2}],“isCompressed”:true,“name”:“fluid_pie1_160318”,“isSizeEstimated”:true,“extension”:“gz”},“drives”:[{“size”:7826571264,“isVirtual”:false,“enumerator”:“PCISTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:true,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“SCSI”,“isCard”:false,“isUSB”:false,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“SDHC Card”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“84e4a265-924f-4ec5-a743-45c1ea9303ce”,“status”:“finished”,“flashInstanceUuid”:“84e4a265-924f-4ec5-a743-45c1ea9303ce”,“errors”:[{“name”:“Error”,“description”:“SDHC Card”,“code”:“EUNPLUGGED”,“syscall”:“write”,“errno”:-4094,“device”:"\\.\PhysicalDrive1"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:7825522688,“sourceMetadata”:{“isCompressed”:true,“name”:“fluid_pie1_160318”,“size”:7825522688,“compressedSize”:1308400195,“isSizeEstimated”:false},“sample”:0.1,“applicationSessionUuid”:“e2314944-1202-428b-9061-8e9e51820d4e”,“flashingWorkflowUuid”:“2e372e2d-589c-419f-8182-2ebebea20286”})
gui.js:46 Mon Mar 14 2022 12:40:10 GMT+0530 (India Standard Time) SafeWebview loaded ({“event”:{“id”:25,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.7.7&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1647241810519.112,“resourceType”:“mainFrame”,“ip”:“52.220.193.16”,“fromCache”:false,“statusLine”:"HTTP/1.1 200 OK”,“statusCode”:200,“responseHeaders”:{“Age”:[“11253”],“Cache-Control”:[“public, max-age=0, must-revalidate”],“Content-Encoding”:[“br”],“Content-Length”:[“6201”],“Content-Type”:[“text/html; charset=UTF-8”],“Date”:[“Mon, 14 Mar 2022 04:02:37 GMT”],“Etag”:["“889e46069c50276630a93cda4deea366-ssl-df”"],“Link”:["</webpack-runtime-089d98f9359977565314.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-004503f2df4bb68d43f8.js>; rel=preload; as=script, </50c25a04-a68e3217d6ce65727bd7.js>; rel=preload; as=script, </73ad3401-ecb0d3613fde52e78ca5.js>; rel=preload; as=script, </532a2f07-f1ad28da1825cfcce2c7.js>; rel=preload; as=script, </app-d3f2c796bc2e57a8750f.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-4ae9e03f4545d4f1d61b.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-cea6bfcc846ea7ff6166.js>; rel=preload; as=script, </c974efff6ac245e04f4a26711b42db767846e0e5-b1b7091203b51af325ff.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-98ac1a1084e1d2a478fa.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],“Referrer-Policy”:[“strict-origin-when-cross-origin”],“Server”:[“Netlify”],“Strict-Transport-Security”:[“max-age=31536000”],“Vary”:[“Accept-Encoding”],“X-Content-Type-Options”:[“nosniff”],“X-Frame-Options”:[“DENY”],“X-Nf-Request-Id”:[“01FY3M6ME5AF3FWQHVEC0CEFPZ”],“X-Xss-Protection”:[“1; mode=block”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“e2314944-1202-428b-9061-8e9e51820d4e”,“flashingWorkflowUuid”:“2e372e2d-589c-419f-8182-2ebebea20286”})
This is the error I am getting, can someone please help!!!
